Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer fine frige to cold
Freezer is 0* frige is 24*
    New Friend:
  • 60 Answers
You must check the door seals are ok and if they are you might have a bit of compressor oil stuck in the condenser pipes somwhere this is a regular problem with alot of new fridges youll need to take it to the agents if thats the case
Posted on Mar 20, 2014
5 Suggested Answers
Krames
  • 18 Answers
SOURCE: Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Posted on Nov 15, 2008
aasc
  • 1606 Answers
SOURCE: blowing cold air but not cold enough to keep frige cold
IF there is frost on the back wall inside the the freezer section about 12 inches from the bottom , you have a defrost problem . If there is no frost on the rear wall , then you probably have a bad overload/relay (part # 2188840 ) . This piece is the part which is plugged onto the compressor , with 2 or 3 wires going to it . Unplug it from the compressor and shake it . If it rattles , replace it .
Posted on Aug 02, 2009
SOURCE: frige is not cold, freezer is fine. 6 yrs old GE
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Posted on Sep 12, 2009
Sea Breeze
  • 4655 Answers
SOURCE: freezer is cold fan running , refrigerator not cold no fan
If it is the pss26msrss or close I can tell you that it is most likely the defrost heater and defrost thernostat that needs changed, Would you like me to show you how to do the test. First tell me if a layer of frost is building on the rear wall of freezer. If yes unplug and remove rear panel until we see the defrost heater at the bottom of the evaporator coil. let me know, Sea Breeze
Posted on Apr 10, 2010
The freezer works fine, but the frige side is not cold at all. the unit is still under warranty, and the service guy replaced the "control board". but that worked for about a week. Everything is...
Hello Patrickbono,
I understand that your are having a problem with your fridge it is not getting cold. However, the freezer is cooling just fine this is a common occurrence when the evaporator fan goes out in the unit. Here is a tip you can follow to help you diagnosis the problem
Fridge not getting cold?
I would suggest you call the service tech as the unit is still under warranty and have them to replace the fan and check the rest of the unit.
Thank you for choosing FixYa.com
justinbur167
May 11, 2011 | Samsung RS265LBBP Side by Side...
The Frige is not cool, only the Freezer is Cold.
Hello Chrofattah,
I understand that you are having a problem with you refrigerator not cooling but the freezer is working fine. I have wrote a tip that will show you how to fix this problem below is the link.
Freezer cold, Fridge Hot
Thank you for choosing FIxYa.com
Justin
May 08, 2011 | Daewoo Refrigerators
Fridgedaire freezer not staying cold. I can
did anyone help you with this problem? i have a similar problem but my freezer works fine in the summer. it does not stay cold enough in the winter. i keep the frige in my garage as a spare but it's not very helpful when it doesn't work! a repair person told me it was too cold in my garage for the freezer to work...not sure why, the frige part works fine. i'm looking into a blanket insulator from appliance zone to see if that will help.
Jul 25, 2009 | Frigidaire FRT17B3A Top Freezer...
Freezers cold but refrigerators warm
see if there is a big block of ice on the back plate in your frige, if there is then your thermostat is set to cold or broken. if no ice in the frige then it has a gas leak!
Dec 27, 2008 | Magic Chef MCBR440 Compact Refrigerator
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge not cold, freezer fine...
look at the back inside wall of the freezer. you might need to put your hand on it to feel it. if you see or feel frost the you have a defrost problem. if its not defrosting the frost builds up and blocks air flow from the freezer to the frige so the frige cant cool. it will either be the defrost element, defrost thermostat or the defrost timer causing the problem
Nov 25, 2007 | Kenmore 71279 Bottom Freezer Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
