Question about Lexmark Z1300 InkJet Photo Printer
Lexmark x2670 won't start up. There is no power and there very quite high pitched hum sound
The printer recently ran out of ink. I just bought the ink cartridges I was going to put them in but the printer won't start up and it's started making a quiet humming noise
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 23 Answers
Hello. First i would check the outlet that its plugged into. If plugged into a wall outlet, check to see if the circuit is tripped. Might have to reset the circuit. Next try a different power outlet. Unplug the power cable from the back of the printer and plug back in. If still not working, try a different comparable power cable. If that don't work either, check to see if the printer is under warranty with Lexmark and call the customer support line and see if they can place service on it. Hope that helps
Posted on Mar 20, 2014
SOURCE: Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Posted on Apr 13, 2007
SOURCE: ink problems lexmark x2500 printer
lexmark ran out of ink replaced cartridge. still saying i am out of ink and wont print anything
Posted on Dec 04, 2008
  • 52 Answers
SOURCE: refilling lexmark cartridges x2500
There are a couple ways to trick it into accepting the cartridge. You can put a different one in, take it out and then put the filled one in. Or you can find a refill kit with instructions on what contacts to cover with tape and you have to do it 2 or 3 times to get the printer to reset. Sometimes you can shut off the computer and printer for 20 min and start it up again. Or you can get the sledge hammer and smash the stupid printer before it sucks up your life savings and vow never to buy from a company that profits from causing problems that they tell you can only be solved by using more of their overpriced solutions.
Posted on May 05, 2009
Roop1980
  • 228 Answers
SOURCE: ink cartridges make a slamming sound from left to right and wont print
The encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and try printing the self test. If it slams to the left again, the strip is not yet set correctly.
If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
Posted on May 28, 2009
mstipps
  • 16 Answers
SOURCE: refilling cartridges
For that printer: there are 4 color and 4 black cartridges BESIDES the #31 photo cartridge. Lexmark has made it so you MUST either, throw away or send to them, the 36 and 37, the 36XL and 37XL. The printer will never again recognize them after they are removed from the printer...
However, the 36XLA and 37XLA AND the 36A and 37A as well as the 31 Photo may be removed from the printer, refilled, and reinstalled.
I have seen some forums that say you can but a piece of BLACK tape, across the bottom row of contacts on the non-refillable cartridges....I believe there are 4 to 7 contacts across the bottom row only.....and the printer will still give you a message that it needs ink.....but it WILL print. I have not tested this theory yet though. I have just gotten the first message saying my black ink is very low.
Hope this helps and I think Lexmark Corporation Sucks for tricking people like this. (This printer comes with the NON refillable cartridges as default, but I did NOT see in the documentation that it couldn't be refilled. Nasty people........:(
Good Luck~~! mstipps@yahoo.com
Posted on Jul 07, 2009
What may cause a high pitch hum.even when muted or volume turned down?
Samsung DLP making a buzzing noise, but works fine - High Def ...
www.highdefforum.com > ... > Rear-Projection TVs
Dec 11, 2009 - 7 posts - ‎5 authors
My Samsung HLP-5063 DLP starting making a loud buzzing noise recently. ... I've only used it to watch TV for a half hour or so at a time, as I have a new LED LCD in my room. ... Other than that, I can't figure out what might be causing it. .... a humming high pitch sound, it will be an issue with the color wheel. RCA D52W25 making high pitch noise - High Def ...
Apr 15, 2009
humming sound in my dlp - High Def Forum - Your High ...
Nov 6, 2006
More results from www.highdefforum.com
High pitched sound coming from my Samsung DLP TV - Open Forum ...
www.dslreports.com > Forums > Social > Open Forum
DSLReports
Oct 3, 2009 - 30 posts - ‎7 authors
Its so high pitched that some people can barely hear it, but I guess I have sensitive hearing. ... Anyway, this seems to be a fairly common issue and it is caused by either the ... You're probably hearing a transformer humming.
Jan 08, 2016 | Televison & Video
How to reset low ink level on lexmark x2670
Please note that when a Lexmark cartridge is refilled, it can no longer register its ink level.
Mar 16, 2012 | Lexmark X2670 All-In-One Printer
Can you connect a printer lexmark x 2760 without a usb?
The Lexmark X2670 can only connect to a computer using a USB cable. Without it, your computer won't be able to communicate to the printer for printing, copying and scanning. If you lost the USB cable, you may purchase one from any retail stores. The USB cable used for your model has Type A plug on one end and the other end has Type B plug. You may also contact Lexmark Technical Support Center for additional assistance.
I hope this information has been helpful.
Jan 15, 2012 | Lexmark X2670 All-In-One Printer
I want a manual for a Lexmark X2670
http://www1.lexmark.com/US/en/view/Printers%20&%20MultiFunction/Lexmark-X2670/catId=cat170005-category&prodId=4922-product
Go to the above link and scroll down. Click on download user guide. Hope it helps. Do not forget to give your high rating if your problem is solved
Sep 27, 2011 | Lexmark X2670 All-In-One Printer
I refilled my Lexmark cartridge but it continues to say I need to install a new cartridge. The printer model is x2670.
Hello there,
The reason why your Lexmark printer keeps on telling you to install new cartridge because the printer have ink cartridge detection. Meaning it will detect whether that particular cartridge is an old one or not.
Each Ink Cartridges have its code and it will be registered to the printer once you have connected it. The printer will assume the ink level and once it is empty, that particular Lexmark Ink Cartridge will be registered to your printer as an empty ink cartridge and needed to be replace with a new one.
I would suggest getting a genuine new cartridge instead of refilling the ink cartridges.
Feb 17, 2011 | Lexmark X2670 All-In-One Printer
My printer has plenty of ink but will not print properly
my lexmark is connected to my pc, my ink is more or less full it is making all the right noises for printing but the paper comes out blank...........please help its a lexmark 1200
Jan 10, 2011 | Lexmark X2670 All-In-One Printer
I didn't get instruction book when bought new so don't know how to copy or scan. can you please help?
If you have already installed the Lexmark X2670 driver on your computer (Windows), try to view the printer's User's Guide by going to the Start menu ? All Programs/Programs ? Lexmark 2600 Series ? User's Guide. If not, you can download the User's Guide for free from the Lexmark website at Lexmark 2600 Series User's Guide. User's Guide gives you some other instructions as well on how to use other features of the printer. Thanks.
Nov 18, 2010 | Lexmark X2670 All-In-One Printer
High pitch humming sound when tv is off.
Better not to interfere with it as it should be under warranty if you have just bought it Either retun it to the store or have their service tech come out and look at it. These units are High tension power and are dangerous to try and fix yourself if you dont know what you are doing
Jul 31, 2009 | Televison & Video
Lexmark Z1300 InkJet Photo Printer Logo
73 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
