Question about Acer Computers & Internet
My lap lap top was placed on wet area, now the screen is black although the computer power light is on, what shall I do
The mouse is lighting up, and my files needed for a work??
    Master:
  • 397 Answers
It sounds like some of the moisture has entered the laptop and caused problems. First of all take the battery out of the laptop immediately and power it down, make sure you do not try to power it up until you have attempted to dry the unit. I would recommend covering any holes/vents in the chassis of the laptop with masking tape and placing it in some kind of storage container buried in dry uncooked rice for at least 24 hours. Hopefully this will draw any moisture from the laptop and prevent further problems. In the meantime, if you are desperate to access the files you might want to extract your hard disk and connect it to another computer. I wouldn't recommend this if it can be avoided, as it will require moving the laptop around which may help work moisture further into the system, the moisture could also be affecting the hard disk, if it is and you attempt to power it you risk losing your data forever.
Posted on Mar 20, 2014
Testimonial: "Thank you will do that right away thanks."
billspeer
  • 180 Answers
SOURCE: My Compaq Presario C500T lap top won't start
Generally speaking, an orange power light indicates problems with the power. You also described to a "T" how a bad battery behaves. To test this theory, take out the battery and plug in the laptop. It should power up and run. If so, it's time to invest in a new battery.
To be doubly sure, if you have anyone with the same laptop as yourself, plug in their battery to your laptop. It should work if their battery is good.
Thanks for using fixya.com. Please rate this tip accordingly if it provides the information you needed.
Posted on Jan 13, 2009
djnick989
  • 1067 Answers
SOURCE: TOSHIBA LAP TOP A135-S4656 SCREEN WENT BLANK BLACK
over heated the video area in it will have to cheak video card inside or motherboard chips on it got to hot when u play games on labtops u must ua labtop cooler never set it on your bed
Posted on Jan 27, 2008
Kidyubyub
  • 143 Answers
SOURCE: Boot to black screen fpr hp pavillion dv2000
Solution by CJ and Brian is most likely the best answer.
Posted on May 15, 2008
steve6375
  • 395 Answers
SOURCE: Power Light on but screen black
Try powering up with no battery connected. If that works then the battery may be faulty or too old.
Posted on Feb 15, 2009
Geekman
  • 32281 Answers
SOURCE: Why is my lap top just intermittently beeping with a black screen
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Posted on Oct 08, 2012
My Acer AL2216W monitor this morning went blank. I woke up, turned on pc and went to sleep like an hour more, when I woke up, the screen was black and light orange, as usual, when pc is not used for a...
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
Apr 04, 2017 | Acer AL2216W LCD Monitor
Hello My acer 1916W LCD Monitor Screen will not light up after turning my desk top Computer on.. Although the start light lights up okay My Screen stays Black. It only lasted over 6 months I am now using a...
you need to reset the bios in the computer take the littel battry out inside with the power of then wait a min or two re insert boot and c if that works
Apr 05, 2011 | Acer AL1916W 19" LCD Monitor
The mouse pad area has stopped working and the cursor is frozen on the screen. However we can use the computer by plugging in a mouse to the usb port. Please advise best course of action. Thanks
get a reg. computer mouse plug in your port then go to start then go to programs and files tool bar put the mouse in you will see 2 mouses go to your lap top mouse click on now change settings around then restart laptop.
Feb 04, 2011 | Acer Aspire One Netbook 8.9" Notebook
When I connect my monitor to my lab top the green power light comes on then turns orange and I get "no signal" message on the monitor
you may need to tell the lap top to display from that screen the new screen has no image or signal so goes to sleep to save power.on your lap top try the (FN) key on your laptop then select a blue picture on the keyboad of to squears one black one blue this will alter the display.OR in windows look at Start>controal pannel>display
Jun 03, 2010 | Sharp LL-173C-B (Black) 17" LCD Monitor
Computer won't start
When the screen is black, try pressing Ctrl + Alt + Del; a soft reset should kick it back into gear. Did the laptop shut down unexpectedly due to power loss/overheating/etc..?
Apr 20, 2009 | Acer Computers & Internet
Screen black wont boot up
If it is new and under warranty. Use its warranty.
Apr 14, 2009 | Acer Aspire 5100 Notebook
Feb 15, 2009 | Computers & Internet
Screen size too large
One way is to right mouse click on the Desktop click on properties then Settings and change the screen area
Jan 23, 2009 | Acer TravelMate 2300 Notebook
Grand-ma knows best
It won't switch on at all, the power light is on at the front and the battery light shows re-charging. But when I press the power button on top nothing happens
Nov 22, 2008 | Toshiba Satellite M35X-S111 Notebook
Computers & Internet Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
