Question about Home
How do you connect from Grohe universal rough in to dual ell for hand held/tub spout
    Problem Solver:
  • 6 Answers
If you are going to have both you are probably going to need an optional diverter valve.
Luckydog
Posted on Jun 05, 2014
4 Suggested Answers
  • 297 Answers
SOURCE: Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
Posted on Jul 26, 2009
housejess
  • 317 Answers
SOURCE: I have a movatio shower head with a grohe allure
not the shower head ..its the hot and cold handles...
Posted on Nov 17, 2009
  • 1044 Answers
SOURCE: low water pressure in grohe hand held. Is there a
1 Check if the holes in the hand held shower are not clogged with scum which generally happens over prolonged use. Clean them with a pin. 2 If this does not help, then check the the pipe connecting the shower to the water outlet. It should be clean and not clogged with foreign material which restricts the flow of water. 3 It still it does not help then you may have to fix a booster pump or raise the level of the water reservoir.
Posted on Dec 20, 2009
Why is there Rust from tub spout and shower head
When you turn off faucets other than your tub or shower you will note that the water stops fairly abruptly. Not so with a shower head or tub spout. Some water always dribbles out even after you have turned it off. This small amount of water then evaporates leaving behind the iron that was dissolved in your water. This also happens if any faucet has a slow drip. There are products that will easily remove the rust stains. CLR, Iron Out, or Iron Ike are all good products that will remove the stain. Available at hardware stores, plumbing supply houses, and, ugh, Home Depot or Lowes. Please support your local business owners by purchasing there.
Aug 06, 2014 | Grohe Home
How do I replace pieces that fell out of my tub spout?
Replace tub spout. Remove screw undertub spout .it could be hard buy it will come off.take to hardware stor and get new one . Goes on in reverse order .hope this helped.k
May 31, 2014 | Grohe Seabury 6" Tub Spout 13 603 000 / 13...
HOT WATER FROM TALIA FAUCET IN BATHTUB WAS RUNNING A GOOD STREAM AND SLOWED TO A DRIBBLE. WHAT NEEDS TO BE FIXED?
I called the Grohe customer support line and they told me the part I need and that it is under lifetime warranty.
Jun 19, 2009 | Grohe 25 597 Talia Tub Filler w/Personal...
Installation problem: Grohmix shower valve 1 1/2'' extension
This is what you should have... Grohe Grohmix Thermostat Valve & Trim - 34436
  • Paraffin cartridge
  • Lever volume control
  • Grip ring temperature control
  • 1/2" NPT female connections
  • Service stops
  • Includes rough-in valve and trim
  • Integrated temperature and volume control
  • Requires Twin Ell (03 671) for shower/tub combinations with diverter spout Note:
  • Grohe Grohmix Thermostat Valve & Trim - 34436
    Mar 26, 2009 | Grohe Grohmix Thermostat Valve & Trim -...
    Feb 18, 2009 | Grohe Eurosmart, 3-hole Roman Tub Filler...
    Ghroe Seabury 25502 roman tub filler leaking at liftrod control
    It can be repaired.
    You can see an exploded diagram here
    I can post more if you need more specific instructions.
    Nov 22, 2008 | Grohe 19.045.000 Seabury Thermostatic...
    Home Logo
    Top Home Experts
    Donni Steen
    Tom Chichester
    Are you a Home Expert? Answer questions, earn points and help others
