P3015 beep Why does my hp laser jet p3010 beep when it prints
Here are some possible reasons why your printer is beeping:
1. Your printer is connected to a UPS (Uninterruptible Power Supply). When the printer goes through the printing cycle it uses a massive amount of electricity. During those few seconds of power usage, the UPS will beep indicating that it will not be able to sustain that power output for any period of time.
How to fix: Move your printer to another outlet and don't connect it to a UPS
2. You have an MFP (multi-function printer) that is attempting to fax again and again. When sending a fax, it's typical that the printer makes noises (dialing, connecting, etc). One of these noises is a fax response beep.
How to fix: Check your printers menu and turn off/down the fax volume
3. Some printers with an LCD menu and keypad make noise when keys are pressed or the printer encounters an alarm of some type. This can become annoying when typing keys for a phone number or by changing a menu setting.
How to fix: Check the menu settings for the printer and turn off/down the sound that's occuring. As an example, the HP LaserJet MFP series printers have the following sounds.
  • The alarm sound that the printer makes when it requires attention, such as when the all-in-one
    door is open.
  • The beeps that are emitted when you press the all-in-one control-panel buttons.
  • The phone line sounds for outgoing faxes.
  • The ring volume for incoming faxes.
As an example, change alarm volume by following these steps (using a 305X series printer)
1. Press Menu
2. Use the < or the > button to select System setup, and then press the green checkmark button
3. Use the < or the > button to select Volume settings, and then press green checkmark button
4. Press the green checkmark button to select Alarm volume
5. Use the < or the > button to select Off, Soft, Medium, or Loud
6. Press the green checkmark button to save your selection
Posted on Mar 20, 2014
  • 2072 Answers
SOURCE: Laser Jet 5550DTN printing problem
I am reading your question and coming up with 2 different thoughts.
Are you wanting multiple prints of one page, or are you wanting to print out a 5 or 10 page document?
I am not sure how to answer.
Posted on Mar 01, 2008
POCBM
  • 121 Answers
SOURCE: Printed confirmation on faxes sent form HP Laser Jet Fax M1522nf
To get confirmation page do this:
1. On the control panel, press Setup ( ).
2. Use the arrow buttons to select Reports, and then press OK.
3. Use the arrow buttons to select Fax Reports, and then press OK.
4. Use the arrow buttons to select Fax Confirmation, and then press OK.
5. Use the arrow buttons to select the option for when you want the fax error reports to be printed.
6. Press OK to save the selection.
To iclude first page with report:
4. Use the arrow buttons to select Include 1st page, and then press OK.
5. Use the arrow buttons to select On, and then press OK to confirm the selection.
Posted on Mar 25, 2009
  • 44 Answers
SOURCE: print en enveolppe with hp color laser jet 2600n
Envelopes can be printed from tray 1 or 2. Select the type of envelope you are using from the PRINT dialog box or the driver. In your program, set the margins. Typical margins for a commercial #10 or DL envelope would be: Return Address Top margin 15mm(0.6 Inch) Left margin 15mm(0.6 Inch), Delivery Address Top margin 51mm(2 Inches) Left margin 89mm(3.5 Inches). For the best print quality, position margins no closer than 15mm (0.6 Inch) from the edges of the envelope. Avoid printing on the seams of the envelope. Envelopes with a peel-off adhesive strip or more than one flap that folds over to seal must use adhesives that are compatible with the heat and pressure of the printer fuser. the extra flaps and seals can cause wrinkling, creasing and feed jams, could even damage the fuser.
Posted on Apr 19, 2009
niquose
  • 198 Answers
SOURCE: how i print a watermark picture in hp 1020 printer
To change the default settings for all future print jobs in Windows XP
1. In the Windows task bar, click Start, select Settings, and click Printers and Faxes.
2. Right-click the HP LaserJet 1020 printer icon.
3. Click Properties, or click Printing Preferences.
4. Change the settings, and click OK.
5. On the Effects tab, select the watermark you want to use.
NOTE Not all printer features are available from all drivers or operating systems. See the printer
properties (driver) online Help for information about availability of features for that driver.
Posted on Jun 23, 2009
  • 39 Answers
SOURCE: my HP color Laser Jet 3000/3600/3800 is sqeaking
You need to clean the carriage ride path for the cartridge.
Posted on Aug 12, 2009
I printed several documents and then got a 51.10 error on my HP P3015. It tells me to turn the printer off and on, but this does not resolve the issue.
This error means that the laser scanner assembly has failed. That you are able to print a couple of pages is a pretty common symptom. Eventually it will fail entirely, so time to replace it. Part Number should be RM1-6322-000.
Aug 26, 2014 | HP P3015 Laser Printer
Hello! I have a HP P3015 LaserJet Printer show
you need to go to the printer on computer, then to the port settings and use the usb dot 4 port - will be that
Oct 22, 2013 | HP P3015 Laser Printer
Hp laser jet p3015 not powering on
41.2 error hp laser p3015 printer
Mar 25, 2013 | HP Laserjet P3015X Printer
Configure ip adress to hp laserjet p3015
This model does actually have embedded network functionallity.
To configure the IP Address, follow the menu map as below:
1) - (4) I/O
2) - (4-2) Embedded JetDirect Menu
3) - (4-2-2) TCP/IP
4) - (4-2-2-1) Enable (Make sure this is 'On')
5) - (4-2-2-3) IPV4 Settings
6) - (4-2-2-3-1) Config Method (Auto = DHCP, Set to Manual in order to specify an IP address.)
7) - (4-2-2-3-2) Manual Settings (This is where you can set the IP Address, Subnet Mask, and Default Gateway.)
Apr 28, 2011 | HP P3015 Laser Printer
My HP 3015P will no longer print PDF files. This is a new issue. Anyone have a solution?
I'm having the same problem with three networked P3015 printers on a Windows 2003 server. They stopped printing PDF files last week. The universal PS driver from HP works, but it's a pretty ugly solution. I'd like to know why the PCL driver just stopped working.
Btw, we're printing from Acrobat 9.4.2. Word, Excel, and other office printing is fine still.
Feb 17, 2011 | HP P3015 Laser Printer
How do I stop the duplexing on the P3015. CD installed a P3010 driver. We have change the printing preferences to NO for duplexing but it still duplexes.
Make sure that in both the printer preferences no multiplexing is set up and that no multiplexing is set up in the the printing preferences of the software you are printing from
Dec 23, 2010 | HP P3015 Laser Printer
51.10 ERROR
i cant print my document my hp laserjet p3015 print display error message 51.10. please slove this imdy.
Dec 13, 2010 | HP P3015 Laser Printer
Open Questions:
444 people viewed this question
k24674
jasbo
jasbo
