Question about Sony Dvcam DSR-PD170 DV Digital Camcorder
I keep getting a badly focused picture with my camera
.once you zoom in the picture becomes unclear.
4 Suggested Answers
darntoothysa
  • 489 Answers
SOURCE: Internal Zoom Malfunction
Hi
Do you mean the 'digital zoom' when you zoom in as far as possible on something or do you mean even with the camera zoomed all the way OUT it still does it?
Yes you should always avoid the 'digital zoom', but if it still doesn't work when zoomed all the way out you need to have the lens cleaned, repaired, or replaced.
We are a digital camera repair business with AFFORDABLE prices. If we can help with your repair then please let us know. Google: darntoothysam
Good luck from Darntoothysam com
Thomas
Posted on Oct 08, 2008
  • 586 Answers
SOURCE: Won't take pictures when zoom
Most common problem in al the digital camera's. Slide motor start malfunction and the massage appears"Turn off the power and on again". In this situation you have to replace slide motor or lens block assembly, And your camera work fine again.
Thanks for using fixya.
Posted on Jun 27, 2009
lock123
  • 6831 Answers
SOURCE: My camera's LCD screen doesn't show the picture on
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 14, 2010
How can I keep the picture sharp when zooming in macro
When you zoom in macro with a Coolpix camera, you must change the camera to subject distance to compensate because as you zoom in and out, the depth of focus of the lens changes dramatically.
Jun 10, 2014 | Nikon COOLPIX Cameras
Once u zoom into the picture that is very far away how do u keep the picture zoomed in after u snap the shot ...
Once you've framed your shot (zoomed in) and taken the picture. That's it, the picture you've taken is the one in your view finder, and that's the way its kept.
However, if you want to zoom in further, you can using the software you were provided with your camera, you can, you can also zoom in using your camera menu. Once happy you can then save the edited picture. But this time its a digital zoom and it will reduce the resolution. The picture won't look quite as fine. It will be a balance between picture quality and the extent you want to zoom in.
Apr 19, 2011 | Olympus PEN EPL1 Body only Digital Camera
Brightness of the monitor screen changes when a picture is taken, the final picture looks blurr. Is there any solution?
Are you pressing the shutter button half-way and giving the camera time to lock in the focus before pressing the rest of the way? If not, the good pictures were just luck.
The overall image is out of focus
If Pan focus is being used, the image may be out of focus; use Auto Focus Mode.
Pan focus uses a focus range of several feet, so the image might be blurry but will be captured faster. This could occur in the EX-Z30, EX-Z40, EX-Z50, EX-Z55 and EX-Z57.
If digital zoom was chosen and the image becomes unclear, only use optical zoom, and move closer.
Check the owners manual; hope this helps.
Jan 12, 2011 | Casio EXILIM Digital Camera
Focus error? The camera won't focus. Focus Error is displayed in the viewing screen. Zoom action & everything else seems to work fine. Won't focus, won't take pictures.
This is a known issue with Fuji S3000 cameras caused by dust and dirt that get in through the loosely mounted lens mechanism, there are only three solutions.
  1. If under warranty you can send the camera in for repair.
  2. Saturate around the lens with WD40 and wiggle the lens until it becomes responsive again every month or so.
  3. Dismantle the camera and clean out around the internal gear-box and lens components about once a year.
May 03, 2010 | Fuji FinePix S3000 Digital Camera
I'm having problems with I focus the camera out. It becomes burrie
The camera has limited ability to zoom out. I believe you have a 3x optical zoom, and a 7 x digital zoom. Once you go beyond the optical zoom, the camera attempts to digitally render the zoom which can cause pixalation, or bluriness. This should never be an issue inside the optical zoom range as the image is going directly through the lens.
Dec 19, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
The lens keeps trying to focus it zooms in and
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Dec 02, 2009 | Nikon Cameras
Out of focus especially noticeable in digital zoom
Digital zoom only enlarges the pixels causing the picture to become fuzzy. Don't use it. Only use optical zoom.
Oct 14, 2009 | Nikon Coolpix 8700 Digital Camera
WHEN I ZOOM IN (CLOSE UP HOWDO I GET A CLEAR
When you zoom in, you have to re-focus. If you get too close, you need to switch to "macro" mode. And, it becomes harder to hold the camera steady.
Sep 30, 2009 | Olympus Camedia C-755 Ultra Zoom Digital...
Zoom feature
Could be the battery is old and not charging well. Happened to mine & once I got the new battery everything was fine again!
Jun 02, 2008 | Kodak EasyShare DX6490 Digital Camera
Sony Dvcam DSR-PD170 DV Digital Camcorder Logo
18 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
