Ricoh SPC240 DN Error SC543
We have this error code. We need instructions for this particular machine to get into the service mode. We also need to know if this error can be reset? Please advise. Any other instructions we have found on this site for other machines have not worked. Thanks
SOURCE: Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
Posted on Jun 23, 2008
  • 58 Answers
SOURCE: code error sc543 ricoh aficio
SC-543
Heating roller fusing lamp overheat
The detected fusing temperature stays at 200 °C or more for five seconds.
Replacetment the PSU. Got it here: http://www.websitetoolbox.com/mb/copierquestions
Posted on Jan 13, 2009
SOURCE: Error code sc 552 on Ricoh CL7100
To clear any code on a Ricoh / Savin copier that will no reset by turning the power off / on you need to first enter the service program mode. This is a safety feature installed when repeated resets of some codes could cause damage to the machine or possible fire hazard. Most of the time these codes deal with the fusing unit. The fusing units operate at around 180 degrees celcius. Thats pretty near the point where paper catches fire so you see the need for safety there. Anyway, you can sometimes get a false fuser code if the room is cold in the morning when you first power up the copier and the machine takes longer than normal to reach operating temp. Another reason can be that maybe you didn't push the fuser back in good enough after clearing a jam and the electrical contacts did not make good contact. In these instances you can clear the code and go back to copying. Should the code come back after doing one of these resets then it means there is a bigger problem with your fuser and you need to call for a service visit to have the problem fixed.
Here is the reset for it:
1. Press the Clear Modes (yellow on most machines)
2. Press the numbers 1,0,7
3. Press and hold the Clear / Stop (red on most machines)
after a few seconds on machines with an LCD display screen you should see the screen change to display "SP mode" with a few selections. On older or smaller machines without an LDC display screen you should see a flashing "0" on the panel. This lets the machine know its ok to reset the code. Do not make any selections in this mode. SP mode if for making electrical adjustments to the copier and taking the machine out of spec can cause a lot of problems for you. Once you enter the SP mode you just need to turn the machine off / on. (make sure you do so with the main switch that you have to rock back and forth and not the button that just gets pressed to shut down the machine, the main rocker switch is often located on the front door or on the left side of the machine, sometimes covered by a swinging cover you have to lift first)
If you do not hit the keys in the right order, the machine will not go into SP mode. You can just start over with step one untill you get into SP mode.
After doing this and the code resets but then comes back again or gives you another code, you'll have to place that service call. If not then happy copying to you.
Posted on Jan 14, 2009
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
  • 2072 Answers
SOURCE: what is error code sc548
SC548 means the machine it not seeing the fuser unit. Open the Right side and front doors. Check the fuser unit to see if it is mounted properly.
There is some connection on the fuser module not making good contact. Reseat the fuser and power the machine off and on.
If you need to reset. Press Clear all, 107 and hold the pink button until you cee copy sp page displayed. Press copy sp, then while on that page turn the machine off and back on.
Posted on Jul 19, 2010
Iam getting sc543 for ricoh aficio printer SP C220N,Kinly help
Its a fuser error code Must be reset sp 5-810 in service mode.-Carl
Sep 18, 2017 | Ricoh Office Equipment & Supplies
Sp210 sc543 error cod
might be fuser is bad repair or replace then reset code. To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
Mar 23, 2017 | Ricoh Office Equipment & Supplies
Sir ricoh sp310dn sc543 error /but 2 key no display
This is related to SP311 models.
Execute "Fuser SC Reset" to recover the machine after completing the
recovery procedure. Otherwise, the machine continues to issue this SC
code and cannot be operated.
Fusing related SCs
To prevent damage to the machine, the main machine cannot be operated until the fusing related
SC has been reset by a service representative.
? Enter the "Engine Maintenance" in the "Maintenance mode".
Press "Execute" in "Fuser SC Reset" with engine maintenance mode, and then turn the main
power switch off and on.
Ricoh sp310dn sc543 error
SC 543 is fuser over heat error. Check the thermistor it may be dirty. To reset the error you have to go to service mode SP5810.
What to do with error sc543?
fuser error will need to fix fuser first then reset code
Oct 08, 2014 | Ricoh Aficio SP C231SF SPC231SF SP C232SF...
Error sc543 sp c320dn
SC542, SC543, SC544, SC546,
These codes are related to fuser temperature. Make sure that power source voltage are not low. check thermisters, fusing lamps etc. To reset this code press "All clear" yellow key, enter 107 and press the red key for some seconds. Sevice mode will be displayed, enter SP 5-810 (SC code reset) and select "1". Then hold down the Photo mode key and the # key at the same time for at least 3 seconds
Feb 17, 2012 | Ricoh SP C320DN AllInOne Laser Printer
I have a ricoh Aficio 3025 all in one, it is now giving me a fault code of SC543 please advise
its temp. or fixing error. try to clear it in service mode.
yellow 197 red when it says SERVICE MODE turn off and on machine, if it does not help you need to call service to replace thermistor, or lamp, or rise temp. ,or ...
Nov 12, 2009 | Ricoh Aficio 3025 All-In-One Laser Printer
Desperate!!! Ricoh AP3800C error Need to print for christmas!!!
Fuser is not reaching operating tempurature. turn off the unit. Take the fuser out and reseat it. Power it back up. Ricoh Printers Error Codes Normally there are 3 levels of service call conditions in Ricoh printers.
Level A is the highest level. Machine can not be used until code is reset. The printer cannot be operated at all. Here is a list of common error codes.
Level B: The SC might be reset by turning the main switch off and on in some conditions.
Level C: The printer can be operated as usual except for the unit related to the service call.
SC302: High voltage power supply error
SC306: Charge roller home position error
SC320: Polygon mirror motor error
SC500: Main motor error
SC542: Fusing temperature warm-up error
SC543: Fusing overheat error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 23, 2008 | Ricoh Aficio AP3800C Laser Printer
142 people viewed this question
jasbo
jasbo
