Question about Soyo MT-SYTPT3218AB 32 in. LCD Television
How to remove the rear panel from soyo mt-sytpt3218ab tv
Im trying to remove the rear panel but the connection box that,s mounted externally seems to hold the panel in all is loose but that box keeps me from removing the panel please help
  • 3 Answers
SOURCE: cannot remove the stand on the 26 inch LCD tv (soyo)
Hello you remove the last four screws on the back of the tv located down at the bottom theres two on each side the stand will slide out...
Posted on May 09, 2009
  • 814 Answers
SOURCE: I need to remove tv stand from my Soyo DYLT032D to
Remove Back plate screws and match up the holes on the wall mount device with the holes on the back of your television. Attach the television to mounting devise, Then mount both to the wall. Hope this helps you with your problem.
  • 16 Answers
SOURCE: What screw do I remove from the back on my soyo 32" to mount ??
the screws are already removed the should be plugs little ccircles on the back to remove for a wall mount if not check the tv manual
Posted on May 12, 2009
SOURCE: Soyo DYLT032D - grey box in corner, no main picture or sound
I am having the same problem. Does anyone know the solution?
Posted on Jun 13, 2010
SOURCE: have a soyo mt-sytpt4227ab for
take the back off and get to the power supply most likely you will find some bad capacitors in it they will probaly have the tops of the caps bulgeing.
Posted on Nov 08, 2010
CAN'T TURN MY SOYO TV ON. HAVE REPLACED BATTERIES STILL WON'T COME ON. WHAT COULD THE PROBLEM ? TV MODEL SYTPT3218AB-6L0611
If you are using a universal remote control with this set, you should set up it again with setup codes to Soyo, after the replacement of batteries. If you wish to get more details about setup procedure, check these links. http://electronicshelponline.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 07, 2013 | Televison & Video
What wall mount fits a Soyo TV...MT-PRTPT3208NB
Contact the authorized dealer for Soyo. They can provide you details.
Jul 01, 2013 | Televison & Video
Remote code for the Soyo Model # MT-SYTPT4218AB What's your problem?
These are setup codes for Sanyo: 0049 0097 0110 0004 0268 0012 0108 0180
Oct 25, 2012 | Soyo SYTPT4218AB LCD TV
Soyo tv Mode MT-SYTPT3227AB will not turn on
It might be the power supply board. There is a repair service which addresses any problem with the power supply board, not just bad capacitors: http://www.coppelltvrepair.com/p/783/soyo-mt-sytpt3227ab-power-supply-board-repair-service-no-power-shutdown-etc
Jul 11, 2012 | Soyo SYTPT3227AB 32 in. LCD TV
I have SOYO MT-+SYTPT3227AB TV and cannot locate mounting holes to wall mount the TV.
This TV is not Wall Mountable as the Control Box protrudes and is therefore not suitable for a VESA Wall Mount.
Jun 10, 2011 | Soyo Televison & Video
TV will not turn on green light is on, Is there a reset button on this some where?
You reset it by unplugging it for about an hour, if it still does not work, you will need in-depth troubleshooting.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Apr 28, 2011 | Soyo MT-SYTPT3218AB 32 in. LCD Television
When I turn my TV on It displays but really dim and I am not able to see anything. I took the TV appart and found out that one of the lamps was bad the changed its posotion and now that one is good and the...
This problems is the causes by the board that call the T-CON decoders board,this board sit at the middle bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Dec 15, 2010 | Soyo MT-SYTPT3218AB 32 in. LCD Television
How do you set up the Soya TV. Is it cable ready?
Yes, your TV is cable ready. To set up, you will need to use the original remote and complete the following steps.
1. Connect your cable box to your TV using either antenna (RF) cable or component A/V
2. Press the "MENU" button on your remote
3. Select "CHANNELS" using the up/down arrow buttons on your remote and press "OK"
4. Select "SCAN CHANNEL" and press"OK".
5. Select "CABLE" as the source and press "OK" to tune
The TV should now automatically tune the cable stations and exit the menu. If you need to exit the menu and/or start again just press "MENU" on the remote again.
If you have no picture, press the "INPUT" button on your remote repeatedly until the input is on "TUNER" if you are using an RF cable or "COMPONENT" if you are using component A/V cable.
Your TV should now be setup for watching cable.
Please post back if you need further assistance.
Regards,
BElectric
Dec 05, 2010 | Soyo MT-SYTPT3218AB 32 in. LCD Television
Tv wont turn on
I have the same problem. I took off the back panel and the power circuit board was fired. You can see burnt brown marks on the components and the circuit board. I did a google search and I can get a new power circuit board for around $55. Very easy to install.
May 05, 2010 | Soyo MT-SYTPT3218AB 32 in. LCD Television
My Soyo 32 the problem start on the right side were the pic seems to be scrambled then the whole goes scrambled
kind of sounds like a panel problem, t-con brd which is usually only available with the panel anyways. panel is pretty typically more expensive than the tv is worth(if its even available). you might be able to search around and find a service center that has a free estimate take a look at it. other possibility is the main brd
Mar 18, 2010 | Soyo MT-SYTPT3218AB 32 in. LCD Television
Soyo MT-SYTPT3218AB 32 in. LCD Television Logo
63 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
