Question about Dual Car Audio & Video
Poor stereo signal when using headrest dvd player
When my kids are watching movies or playing games on the portable dvd players, my stereo does not have much of a signal.
  • 7 Answers
SOURCE: lost remote
Fairly easy and resourceful fix for this. Spent the past hour on the net looking, and no one had any info. So, we post here!
Our remote was lost, and were in the same unable to use the input port situation on our Durabrand BH1304D. Tried 3 universal remotes with no luck. However--- we are back in business now, Houston!
My fix-- grab a DirectTV remote (we had a white one-- RC 32 is the model). It's compatible with this 13" Durabrand TV, and most people a neighbor probably have one!
To program it to the TV (at least in our case), you have to slide the top switch to TV, then hold and press MUTE and SELECT until the green light flashes twice under the TV switch. Then press numbers 11034 and the light should flash twice again. Ta-da! Should be in business. We were!
The input button also worked as is, no need for the other step listed in the remote manual. But if your TV is changing channels and volume, but no input button, quick easy fix there too apparently. Didn't have to use it, but the input button can be activated or deactivated as needed. Simply hld SELECT and MUTE down again, the hit 960 on the keypad. That should be the activate/deactivate code per the manual.
Hope this helps someone, as the durabrand remote situation stinks, but thanks to the power of internet and users like us, there's now a solution in your reach! :)
Steve
karaokestl.com
Posted on Feb 02, 2008
SOURCE: DVD player reloads after 5 minutes into the movie
I have a K715 that was having the same problem. The "line select" had been switched from "in" instead of "out". Once I switched it back to "out", the player worked normal.
Posted on May 12, 2008
  • 7 Answers
SOURCE: Philips Pet706 portable dvd will no longer play sound without earphones
try connecting it to small external multimedia speakers (usually played with computers) that come with a small jack simmilar to that on earphones.
Posted on Sep 26, 2008
SOURCE: Played French movie on region-free player and American movies won't work
Try changing back to region 1. Let us know if it works
Posted on Oct 20, 2008
SOURCE: jensen vm9311
Need to know and bypass codes for the jensen 9311 but dont have the remote...
Posted on Dec 19, 2008
Headrest monitor says no video. I have 10 inch power connect headrest monitor/DVD player. One plays DVD and the other is a monitor. The DVD player headrest plays movies but the monitor screen is blue and...
Those cables can go bad easily. If you have a meter and know how to use it, try to test continuity on each pin. If that isnt the answer, then either the input of second monitor is faulty, or output of main screen.
Jan 05, 2015 | Car Audio & Video
No video signal comes on screen when watching movies and playing games in video 1 signal
Look for any loose contacts in RC jacks/sockets/Cable. Try changing the input device to something you are sure, works such as a DVD player.
Aug 04, 2012 | Toshiba Televison & Video
Wont lode movies
Please check weather the DVD which your inserted i supported by the player.?
If someother movies plays then the problem is with the DVD which your inserted.The DVD might have not burnt in correct formatt.
Thanx
Jul 23, 2010 | Durabrand PDV-705 Portable DVD Player
I just bought the dual headrest from walmart and can not get the sound to work the passenger side. can anyone help me with this?or possibly tell me how to get the sound through the stereo.
The monitor only headrest does not have audio handling circuitry in it. the wire harness for that side is the one with the red and black wire, and the two video inputs, not the harness with the red and black wire and the three RCA jacks. It will function on the wrong harness, but it is not the correct one.
The DVD headrest has two harnesses. One of them is for power and output, the other is for input only from another source. The harness with the red and black wire has the three RCA outputs... the video lead goes to the other headrest, and the audio can be fed to an aux input on a stereo or amplifier. The input harness is designed to be Video 2 input from either a gaming system (a Game Cube is a nice option), or another DVD or video source (hand held video device such as iPod or Smart Phone like a HTC Touch Pro 2).
To get sound out of the stereo, either run the audio output from the headrest to the aux input on your stereo, or cycle the FM transmit options using the FMTX button on the DVD player unit to a station you can tune to on your car's FM radio.
Apr 26, 2009 | MT&V Dual 7" Headrest Monitors & DVD...
Volume is not working
get a splitter that allows you to plug 2 sets of headphones in the portable dvd player.
The sound is the only place were this machine falls short. The sound is okay at best with the built in speakers, but any background noise makes it nearly impossible to hear anything from them even with the volume all the way up. Not surprising since due to the size of the player the speakers are only a little bigger then headphone speakers, but with headphones or portable plug-in speakers the sound is superb. Besides the sound the only 2 complaints are that you can not control the volume with the remote and that the power switch is too easily turned on by accident (do not travel with the battery attached or you will find you have no charge when it comes time to watch a movie). The battery lasts 3.5 to 4 hours, long enough for 2 short movies or 1 long one.
also checkout The volume button is on the right side of the uint.
, headphones are a must, or get a device to play the audio through your car stereo ($15-$25). The player has the option to either input or output the A/V so you could play video games on the run or you could hook up a VCR and watch VHS...be creative
Apr 01, 2009 | Shinco SDP-1850 Portable DVD Player
Wireless Headset with DVD
Yes you can use the wireless headsets (you might need a cheap adapter from radio shack) and it can play only one dvd at a time but most models let you plug a video game into the screens so one kid can watch the movie and the other can play thier game
I hope i was of help!
Dec 11, 2008 | TruTech Televison & Video
What do you think is much better to have; PSP, Portable DVD Player or Iphone?
psp get boring dvd players only play videos and music. i phone does everything get the iphone all the way and iphone but it ends up costing so much moeny.. psp - pictures movies music games and wifi web browser
portable dvd player - dvds on the go
iphone - pictures movies music games data apps phone, etc
the dvd player will be the cheapest, one time fee, then after that you just need dvds, the psp will be good for more than one thing, making it superior to the dvd player, and then theres iphone. well, with a monthly fee, it may not be what your looking for. but if you need a phone its the best..
Oct 12, 2008 | Computers & Internet
Screen won't play movie
sound like the wire to the parking brake may not be getting a ground.if it not get a ground it will no show a picture on the screen. it so you cant watch the dvd while driving.
Feb 11, 2007 | Concept DVD-168C Car Video Player
Car Audio & Video Logo
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
