Question about Ricoh SP C430DN Laser Printer
Function Error My printer is showing function error SC899 with the instruction to turn off and restart, well I have done that and the error messages is still there. Any suggestions on what this might be and how to fixes it. Thanks
  • Ricoh Expert
  • 393 Answers
Best case firmware upgrade, worst case bad board. -Carl
Posted on Mar 29, 2014
SOURCE: Error Message: Replace Black PCU
I'm not sure how to obtain one, but "Black PCU" stands for Black Photoconductor Unit, and according to a manual for a different Ricoh printer model, it should be fairly simple to replace if you can find one.
Posted on Nov 16, 2006
SOURCE: Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Posted on Jun 23, 2008
  • 86 Answers
SOURCE: function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Posted on Mar 02, 2009
SOURCE: error function sc120
The following are the possible causes of this error -yes you will need a technician:
• Scanner home position sensor
defective
• Scanner drive motor defective
connector defective
• Scanner drive motor connector
defective
• IOB board defective
Posted on Mar 23, 2009
  • 393 Answers
SOURCE: error message replace/ supply
If you open an internet connection and an the top address bar type in the IP address you will see you printer and be able to see the supply that needs changing
Posted on Jun 23, 2009
Sc899 00
You must clear the print cue. SC899 is from printing from the Internet (typically). With the paper trays open, turn on the machine. Push the Printer button and reset all the print jobs.
You need to update all the firmware on your machine.
Sep 08, 2014 | Ricoh Aficio Office Equipment & Supplies
Error SC899
Here is the answer from the Ricoh Service Manual...
An SC899 occurs if the MFP is accessed from WIM (Web Image Monitor) after receiving an IP-FAX.
Because a firmware bug in the Network Support firmware is causing this symptom.
Call a Ricoh tech and have them update the Network Support firmware to ver.10.55 or later.
Aug 14, 2014 | Ricoh Aficio Mp-C3001 Multifunction Color...
How do i fix error code C-3502 on a konica minolta bizhub500 photocopier
C 3502 - fusing high temperature abnormality.Check the fuser unit electrical components,wires,thermistors,thermofuses,heater lamps.To reset the error code turn OFF the copier.Press and keep pressed the function key and turn ON the copier.Keep pressed the function key until Trouble reset message appaire on display.Release the function key ,touch the message and turn Off and ON the copier.
Dec 27, 2013 | Konica Minolta bizhub C450P Laser Printer
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    Dec 06, 2010 | Dell 962 Photo All-In-One InkJet Printer
    Canon image runner 4570 in error code E000100-0001
    Ok here is how to reset the error if that doesn't work... you really need to call a tech... you are going to need some serious work done on your copier... ok... here are the instructions
    press additional functions
    press 2 and 8 at the same time
    press code error
    press copier
    press function
    press clear
    press error
    press ok
    press reset
    Dec 21, 2009 | Canon ImageRUNNER 3570 Copier/Printer
    Error message stating "unable to clean" and won't complete any function. Any suggestions? Thanks
    Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 - defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
    Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
    Nov 24, 2009 | Brother Multi-Function Center MFC-240C...
    Lens Error. Restart Camera. Camera gives this error message and then shuts off. I can't access photos or function buttons. What can I do?
    Press the "MENU" button and navigate to the reset command and reset the camera. That may get the camera to function properly.
    May 10, 2009 | Canon PowerShot SD1000 Digital Camera
    Remove and check cartridge
    Replace all ink cartridges at the same time.
    Jan 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
    Ricoh SP C430DN Laser Printer Logo
    303 people viewed this question
    Top Ricoh Office Equipment & Supplies Experts
    OfficeServiceAjnc
    OfficeServiceAjnc
    fares
    Level 1 Expert
    CheckitRight
    CheckitRight
    Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
