Question about zune.net
Not instal zune
Another installation is in progress,please wait until thr installation is complete,then try again, error code is 0*80070652
Does anyone know how to fix error 5 code?
Many Zune users will tell you of the dreaded error 5.
When the error occurs it means that the Zune has encountered a problem that it cannot recover from and informs users to contact customer support.
Usually to fix this error, the Zune must be sent to Microsoft. If the Zune is under warranty and the owner is within the US, this is little more than an inconvenience.
If the owner is outside of the US this is not and option and if the warranty has expired, the fix can come at a high price.
However, before sending a Zune off to Microsoft for fixing, there are a number of things to try.
The first thing to try would be to restart the Zune.
The steps to restart the device vary based on Zune model. For the Zune HD player, the user should press and hold the on/off button for roughly ten seconds and the player will reset.
For the non-touchscreen models of Zune, the user should unlock the hold switch.
Then, press and hold the back button and the top button of the Zune pad. The device should restart and the user can release the buttons.
If this does not fix the error, then the user should try reinstalling the software on their Zune device.
To reinstall the software on a Zune HD, the user should press and hold the on/off button for about ten seconds.
When the device restarts, the user should press and hold the "Media" button until the message "Connect Zune To Your PC" displays on the screen.
The user should make sure they have the most up to date Zune software installed on their computer and connect the Zune.
Update the Zune and it should be ready for use again. If the user continues to experience problems, then the Zune HD software may have to be completely deleted and reinstalled. Doing this will completely delete everything on the Zune, so anything that has not been backed up will be lost, including purchased items.
To do this, the user should hold down the on/off button again until the Zune HD restarts.
Upon restarting, the user should immediately press both the "Media" and the "Home" buttons until "Connect Zune To Your PC" displays.
The user should then connect their Zune HD to a computer with the most up to date Zune software and update the Zune.
For the non-touchscreen Zune models, the following step will erase user data (including purchased items), so a backup is recommended.
First, the user should unlock the hold button.
Then the back button and the top button should both be pressed and held down.
The next step varies by model. For owners with a Zune 4GB, 8GB, 16GB, 80GB, and 120GB, the Back button, Zune pad, and Play/Pause button should all be pressed and held down.
The user should continue to hold them until they get a "Please wait" message.
For owners of the Zune 30GB, the Back button, the left side of the Zune pad, and the center of the Zune pad should all be held down until "Please wait" displays.
After data is cleared, the message "Connect Zune To Your PC" will appear.
The user should connect the Zune to a computer with the most recent version of the Zune software installed on it.
After the software is installed, the Zune should be ready for use.
If these measures fail to fix error 5, then the Zune owner will likely have to send the device to Microsoft as the problem is deeper than a software issue.
Sadly, it is not always clear what causes error 5 to occur. In these cases, there are few other options than to leave it to the experts.
hope this helps
Oct 05, 2012 | Microsoft Zune JS8-00001 Digital Media...
Error code 5 and 3
hold the back button and the up button until you see the Zune logo then release. if this doesnt work then you are going to have to reset your Zune....however this will loose all the data on the zune so your music/movies will be completely gone. you are going to need to press and hold the back and up button until the zune logo appears then hold the back,play/pause, and the center button until you see "please wait"
if this doesnt work you have some serious issue. Contact customer support
Sep 05, 2011 | Microsoft Zune JS8-00001 Digital Media...
Have a 80 GB Zune. It froze one day and was showing the message 'Connect the player to your PC'. I did that but then some error message started appearing in the Zune PC software. I tried formatting the...
Try the reset procedure...
Jan 02, 2011 | Microsoft Zune JS8-00001 Digital Media...
How do I restore my devices firmware for my zune 30gb
How to restore your Zune device software:------------
When you restore your Zune device software, the startup partition and the data partition are removed and rebuilt. In addition to removing the Zune device software, this process also erases all audio, videos, podcasts, and pictures that are stored on the Zune device.
Warning To restore the Zune device software, you must have a Windows-based computer that has an Internet connection. That computer must have the Zune software installed. And you must be able to connect the Zune device to a USB port on that computer by using a Zune Sync Cable. Do not perform the following steps if you do not have any one or more of these things immediately available.
After you start to restore the Zune device software, you cannot again use the device until you complete all the steps. You will not receive any confirmation or warning on the Zune device after you start the following procedure.
To restore the Zune device software, follow these steps:
1. Set the Hold Switch to unlocked.
2. Press and hold the Back button at the same time as you press and hold the top of the Zune Pad. When the Zune device begins to power up, release the buttons.
3. Immediately after you release the buttons in step 2, press and hold the following special button combination, depending on your Zune model:• If you have the 4GB Zune, the 8GB Zune, or the 80GB Zune, immediately press and hold the Back button at the same time as you press both the left side of the Zune Pad and the Play/Pause button. Continue to hold these buttons until your Zune device restarts and "Please wait" appears on the screen.
• If you have the 30GB Zune, immediately press and hold the Back button at the same time as you press both the left side of the Zune pad and the center of the Zune pad. Continue to hold these buttons until your Zune device restarts and "Please wait" appears on the screen.
Note "Clearing contents. Please wait" appears, followed by “Connect Zune to your PC."
4. After “Connect Zune to your PC” appears, connect the Zune device to the computer that has the current Zune software installed, and then update the device to the current Zune device software.
----------- Click this link directly for more troubleshooting:-- http://support.microsoft.com/kb/944909 -------- If error problem while restoring then click this link below:-- http://support.microsoft.com/kb/945278 ---------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 03, 2010 | Vacuums
Error code c00d124d appears on my zune while sync
You may have to attempt a Hard Reset if this issue is persistant.
This will erase everything on your device, as a warning please be certian you have backup copies or this is a last resort.
Here is the original post:
WARNING: A hard reset will delete everything on your Zune.
  1. Press and hold the back button
  2. Press and hold up until it reboots
  3. Depending on which Zune you have, immediately do one of the following:
    1. If you have a Zune 4 GB, Zune 8BG, or Zune 80GB, immediately press and hold the Back button Back at the same time as you press the right side of the Zune pad and the Play/Pause button. Continue to hold these buttons until the Zune device restarts and you receive the following message: “Clearing contents. Please wait.”
    2. If you have a Zune 30GB, immediately press and hold the Back button Back at the same time that you press the right side of the Zune pad and the center of the Zune pad. Continue to hold these buttons until the Zune device restarts and you receive the following message: “Clearing contents. Please wait.”
    Good luck, Let us know
Apr 14, 2009 | Computers & Internet
Help
I can scan but I cant save it to my computer.. What will I do?
Aug 16, 2008 | HP Officejet 5610 All-In-One InkJet...
Problem with intalling zune's software
Uninstall all zune software and download and install it again. Possibly a bad download.
Or run error check on your computer then try it again.
Go to my computer, right-click on C: - go to properties- then go to TOOLS tab. Click on Error check - make sure you have both boxe(s) checked to fix errors as they are found then hit start. You will have to restart your computer for this check to happen. Usually takes a a few hours, but recommended to do at least once every few months.
Hope this helps!
Aug 03, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Frozen zune 80gig 2nd gen, error 5
One last ditch effort: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
And, yeah, as far as the international replacement - that is how all the manufacturers are - they are not willing to pay the cost to keep their customers. Also, they have no process in place for fulfilling such a request, even if they have offices in both countries (which most of them do). Sad, really.
Jun 02, 2008 | Microsoft Zune JS8-00001 Digital Media...
I NEED HELP ASAP
if u havnt already go to www.zune.com/support. thats all i can help with. sorry.
Mar 19, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Software problem
computer wont download zune 8GB software
Jan 09, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
zune.net Logo
12 people viewed this question
Top zune.net Computers & Internet Experts
David Payne
David Payne
Are you a zune.net Computer and Internet Expert? Answer questions, earn points and help others
