Question about Insignia IS-LCDTV32 32 in. Television
How to connect tv to home wifi
Do I need a wifi adaptor for the tv?
    Top Expert:
  • Insignia Master
  • 75,599 Answers
Contact the authorized dealer for Insignia.
Gopakumar Gopalan Google
Posted on Mar 20, 2014
Is it possible to upgrade the wifi adaptor in a Westinghouse wd55uw4620 smart tv?
Just get a WiFi extender...this will definitely increase the signal..the tv adapter is generally built-in, but the software might be upgradeable...cheers
Jan 25, 2018 | Westinghouse Computers & Internet
Lost wifi connection over night
You need to reinstall the wifi drivers.
Alternatively you can use the Microsoft troubles shooter by going to the control panel, picking network and sharing centre, then adaptor settings and selecting your adaptor. Then right click and from the menu, select diagnose. This will reset the adaptor if it has become locked up.
Jun 25, 2014 | Toshiba Computers & Internet
How i can connect WiFi
You need this.
Accessories
Apr 12, 2014 | Samsung UN46C6300 TV
Can not connect tv to my home wifi
A what stage does it fail to connect?
As general advise double check your wifi connections settings, that your wifi router is on and connected to the internet.
Mar 20, 2014 | Insignia IS-LCDTV32 32 in. Television
Wont allow me to share my internet , its hooked up to wifi i want to run a cord to my xbox to give it internet possible?
Yes this is possible. You will need to bridge connections between your WIFI adaptor and Ethernet ports.
Navigate to Network connections, select both your WIFI adaptor and Ethernet adaptor. Now right click and select "bridge connections"
Take care!
damnor01
Sep 11, 2012 | eMachines E620-5885 Notebook
Just bought an open box LG LED 42 inch TV. I got a couple questions. 1. What is the recommended way of cleaning the screen? 2. How do I get it to recognize my wifi? 3. Please provide me a link to an...
Hi Rob,
Here's the link to the product support webpage for your TV. The full manual can be downloaded here (Click "Support," and the link is under "Documents" on the right side of the screen.)
http://www.lg.com/us/tv-audio-video/televisions/LG-led-tv-42LE5400.jsp
From the manual, here's what it says about cleaning:
thomascha103_1.jpg And in order for the TV to recognize your wifi, you'll need to plug in a wireless network adaptor to one of the USB ports. (network adaptor sold separately.) Follow these instructions to establish a wifi connection, and then follow the on-screen instructions for wifi/network settings. Or for details on how to adjust your wifi/network settings, see pages 58 and 59 of the manual.
thomascha103_2.jpg That's kind of hard to read, but it says.
"The LG Wireless LAN for Broadband/DLNA Adaptor, which is sold separately, allows the TV to connect to a woreless lan network.
The network configuration and connection method may vary depending on the equipment in use and the network environment. Refer to the setup instructions supplied with yur access point or wireless router for detailed connection steps and network settings.
1. How to connect
Connect the "LG Wireless LAN for Broadband/DLNA Adaptor (sold separately) to the USB IN 1 or 2 port on the TV.
2. How to use
Select "Network Setting" in the NETWORK menu
After connecting, you can use the NETCAST menu"
Best of luck!
Jan 12, 2011 | LG 42LE5400 42 in. LCD TV
I have a toshiba x300, it always connect to other wifi connection? how can I block the other wifi signal? I already uncheck the automatic settings of the other network and delete it from my preferred...
REinstall wi-fi adaptor in device manager
Just go to device manager and expand network adaptors.
Right click on wireless adaptor and select UNINSTALL option
REstart laptop and connect to your network
Thanx
Sep 14, 2009 | Computers & Internet
Connect pc to tv
you can connect it to a modern flat panel via the vga port but you won't get 1080p resolution.I would suggest upgrading sound card and go for the fastest network possible for streaming wifi i'd suggest 802.11n (although 802.11b can stream with minimal network traffic).gigabit is ideal for high definition streaming.If you decide to upgrade acer makes a nice small pc the ax1200 perfect size for a nedia center though no wifi has hdmi dvd burner for less than $400 comes with 20"monitor.
Jun 26, 2009 | Computers & Internet
Verification and signal problems
Hi Sir F,
You don't need to do a re-install of the DLink WiFi adaptor since I believe it is running as it should (as you posted). All that is needed is to configure it to exclusively select only your NetGear WiFi Router. This could be done in the DLInk Wizard (Start/All Programs/DLink.../) set the DLInk to connect only to the SSID of your NetGear. Though it may pick up your neighbors WiFi, the DLink will only acknowledge the presence of the other WiFi but connect only and always to the NetGear.
A couple of other things that may help improve your WiFi connection. Use static IP add in your PC to match that of the NetGear, disable wireless security (WEP or WPA) but rather enable MAC filter and input that of your PC's WiFi Networking Card.
Should you need a more detailed instructions, pls post back the model of your router and the make/model of your PC as well as your OS.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 07, 2008 | D-Link Air DWL-122 802.11b Wireless...
Insignia IS-LCDTV32 32 in. Television Logo
61 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
