Check balance see what current balance is
How many minutes do I have left?
From Your TracFone Step 1 Look at the home screen of your TracFone device, your Airtime Balance Display is shown directly on the home screen of your cell phone. Navigate from any menu or application directly back to the home screen to see your updated balance.
Step 2 View the balance by going to "Menu." Click on "Prepaid" followed by "Airtime Info." This menu will also show your current airtime balance and expiration date.
Related Reading: How to Check Your Prepaid Balance for T-Mobile
Step 3 Add additional airtime to your account by calling 1-800-867-7183, refilling the minutes online or by visiting a participating retailer (see Resources). Enter the PIN number on the back of your refill card to add additional minutes to your account.
From Your Computer Step 1 Check your minute balance by logging in to your account on the TracFone website. Once you are on the homepage, click on "My Account." You'll be prompted to enter your username and password. If you don't currently have a TracFone account, you can register your phone number by clicking on "Register."
Step 2 Find the minute balance of your account displayed in the middle of the "My Account" homepage.
Step 3 View the account expiration date on the "My Account" homepage (see Resources). Your balance expiration date varies depending on the amount of the airtime refill card.
Oct 14, 2015 | Samsung Galaxy Centura Smartphone -...
Can you show me my hra account current balance?
Not here, and you will need some kind of ID to get any account from anyone.
Feb 21, 2015 | Computers & Internet
The settings for welding aluminium using a Tig200P AC/DC inverter
If you are using a remote then you would set the machine in standard for controlling output and also to AC output, HF tig, contactor and control in remote position. I don't know if this helps or not but I pulled it from an owners manual.
1/16" (.062) - pre-flow .1 sec., hot start 20, amperage 70, Hz 100, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 100, background current 30, Hz 1.0
1/8" (.125) - pre-flow .1 sec., hot start 20, amperage 150, Hz 80, balance 20%, post-flow 6.0 sec.
For pulse settings - set pulse width 60%, peak current 150, background current 50, Hz 1.0
3/16"-1/4" - pre-flow .1 sec., hot start 20, amperage 185, Hz 60, balance 20%, post-flow 8.0 sec.
For pulse settings - set pulse width 60%, peak current 185, Background current 125, Hz 1.0
Mar 14, 2014 | ARC Thermadyne Inverter Stick/TIG Welder...
I want to check my loan and balnce to sss
You can check your total loan balance online at any time by logging into your myIR Secure Online Services account. Once you're logged in, you can access your account, see your current loan balance, repayments, interest charges and/or write-offs. For more details http://www.myhardmoneyschool.com/about-our-company.php
Mar 04, 2014 | sss.gov Computers & Internet
How to know the gprs balance in idea
Please press *212# and call button. Your entire balance will come. Remember it and then open internet and do whatever you want to do. After that close internet and check the balance in the same way.
Jan 08, 2011 | Cell Phones
C++
This is a homework problem. You should not expect folks to answer this. There are multiple questions here, as you know.
If you want to do it, you first need to do is start at the sentence, "Create a class ACCOUNT..."
So, "How do you do create a class?" would be one question.
Answer: It is done with an editor creating two new files, one the file ACCOUNT.h (where the class is declared) and two the file ACCOUNT.cpp (where the class member/functions are defined).
All these answers are in your text book.
THEN, work on the next part, "... that stores customerName, accountNumber, etc."
Do it one part at a time and you can program. The next part is to create two new classes, CUR_ACCT and SAV_ACCT. Like the first one, these will go in their own file, like CUR_ACCT.h and CURR_ACCT.cpp.
Take it slow and do one piece at a time.
Only this way can you learn.
May 27, 2010 | Computers & Internet
Non Sufficent fund scheme
Write to the bank stating the situation on ground. Attach your teller in which you had deposited your money, the teller would show the date and time of depositing your money for them to be able to rectify it,
Regards
Aug 26, 2009 | ACCPAC Simply Accounting 2005 Basic...
Timeslips 2008 - The New Balance in Billing assistant does NOT match the balance in A/R List! How can I make them match?
The balance in Billing Assistant also includes the most recent slip activity, whereas the A/R balance is just the Previous Balance. If you subtract the current actvity from the Billing Assistant, it should match the A/R list. If it does not, you need to run Data Verification, "update A/R Balance" and select the client with the out-of-synch balance. This will usually correct the problem
Jul 08, 2009 | Sage Timeslips 2008 Full Version for PC...
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
