Question about Garden
Sanwa yx360trd circuit diagram
Accidently i tested 230ac in mA range and one resisror is burnt.how could i fix it?
  • 1,162 Answers
Well replacing the component is easy, just unsolder an solder new one in. But that is the easy part. The part is most likely a priority part specific for the meter. If you can even find one you will be lucky. Your best bet is to get another meter. You might do a search an find a schematic with the resistance value.
Posted on Mar 24, 2014
2009 pont. g6 3.5L cyl. 1misfire code .replaced plugs coil didnt help
Fuel injector bad , or the control circuit . Do you know how to test for B+ voltage at the injector ? Test for control from the PCM - engine computer . Does that cylinder have compression ? Burnt valve ? Injector Circuit Wiring Diagram
Jan 31, 2017 | Cars & Trucks
Frigidaire model number Fef386cc and serial vf41228055 burners work and clock and light in the oven but the burners do not heat up how do u fix that
CAUTION 220-240 VAC may be encountered!
FIRST check your power at the plug.
With a properly insulated voltage meter, IT MUST read 230AC between the two flat holes. 120VAC between the third, usually round hole.
If that is verified proceed to the power cord and trace the poere internallyl
I am providing manuals and schematics according to your Model Fef386cc.
Frigidaire 30 Freestanding Electric Range
Oct 02, 2015 | Frigidaire Kitchen Ranges
Where can I find & download drivers for this unit?
There is no driver for. It is a plug-n-play hardware, just plug it and done.
Mar 29, 2015 | Sanwa SUPPLY PC Trackball Mouse USB...
Oven will not work only the burners are working. Could it be the electrical panel. I've already checked the circuit breakers
Oven not working causes are;
Oven element open circuited - need to test for continuity;
Burnt wiring at oven element terminals;
The electronic timer is in auto. mode - it must be in manual mode for the oven to work.
Feb 17, 2011 | Maytag MER6772 Gemini Electric Kitchen...
I have a GB Instruments GMT-19A. I want to measure current under 500ma. Scale selections are 500ma, 50ma, and 5ma. The scale readings include 250, 50, 10. What scale reading do I use to read the...
You would use the 500ma range to read anything that is under 500 ma. If the reading comes up below 5o ma, then you can disconnect and change the range to 50 ma. I say disconnect before you change the range because it can damage the instrument otherwise. ie: do not use the switch to change the range while it is already connected in circuit and measuring in progress.
Remember that to measure current, you have to have the meter in series with the load and the supply.
Oct 08, 2017 | Gardner Bender GB Electrical GMT-19A 19...
Oven stopped working.top works fine.noticed chard insulation in back of stove.burnt wire seems to be connected to electrode in oven. any ideas?
Hi, Check voltage or continuity on the bake element. If you test voltage, there should be 240V to the element. If you check continuity, unplug the range and test the element to see if it has an open circuit. In either case, you should replace the wire connectors if they ae burnt.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 09, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Overdrive light flashing No lock up
There are several things that can cause the flashing light. sometimes a simple fix is the change the RABS, this sensor is on the rear differiential and is not too expensive. Change it. Pull th epositive cables off of your batteries fro 15 minutes. Hook them back up and see what happens.
Here are some codes for your truck. :?) DRRXR
  • P1704 Digital TRS Failed to Transition State
  • P1705 TR Sensor out of Self Test Range
  • P1711 TFT Sensor Out of Self Test Range
  • P1713 TFT Stuck in Range Low-Below? 50'F
  • P1714 Shilt Solenoid A Inductive Signature Malfunction
  • P1715 Shift Solenoid B Inductive Signature Malfunction
  • P1718 TFT Stuck in Range High-Above? 25OF
  • P1728 Transmission Slip Error
  • P1729 4x4L Switch Error
  • P1744 Torque Converter Clutch System Performance
  • P1746 EPC Solenoid Open Circuit
  • P1747 EPC Solenoid Short Circuit
  • P1754 CCS (Solenoid) Circuit Malfunction
  • P1760 EPC Solenoid Short Intermittent
  • P1780 TCS Circuit Out of self Test Range
  • P1781 4x4L Circuit Out of Self Test Range
  • P1783 Transmission Overtemperature Condition
  • Apr 08, 2009 | 1997 Ford F250 SuperCab
    Garden Logo
    259 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
