Logik tv troubleshooting
When switched on 'No Signal' shows, but alternative TV is working perfectly off same aerial
    Top Expert:
  • Televison & ... Master
  • 74,185 Answers
If the tuner is faulty, this kind of display can occur. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Posted on Mar 20, 2014
5 Suggested Answers
JDeRuvo
  • 48 Answers
SOURCE: New Logik TV Standbymode
If you're relying on cheap cables - like the ones that are usually tossed in with electronics - you could be running into a signal issue because they aren't shielded and they lose alot of signal due to leakage.
You don't have to overpay for Monster cables, mind you, but cables that are shielded - in gold is even better - should help improve your signal.
J. DeRuvo
[url=http://www.digitaladvisor.com]Digital Advisor[/url]
Posted on Dec 04, 2007
  • 5 Answers
SOURCE: no TV signal
try a different aerial if that doesnt work do a factory reset and then redo your first time installation
Posted on Jan 04, 2010
  • 54 Answers
SOURCE: Cannot get the DVD to work on the Logik TV
DVD cannot work an aerial cable just scart cable.
Posted on Mar 13, 2010
vinceisaac
  • 2432 Answers
SOURCE: Hannspree TV tuning from aerial problem.
do you mean if you hooked up the tv with the aerial antenna can not get any channel? ok if just a white raster only and doesn't scan or tuned even manually and auto search, the cause is bad tuner.
Posted on Sep 07, 2012
I hope so I have a Logik Msn 30009831 HAD SKY TV IN WORKED fine, no sky now but cant tune in comes up no signal
make sure your tv aerial plugged in back of tv and your tv is on the dtv setting before trying to retune it. the sky box is usually on the scart or hdmi setting. hope this helps
Oct 07, 2016 | LG 32LD550 32 in. LCD HDTV
Initially looking for logik spport logik tv support. cannot now tune in tv.
This could be too much signal thanks to the Freeview retunes going on. Your aerial is more sensitive at some frequencies, so there's more signal power higher up the frequency range.
A simple and inexpensive diagnosis tool is a variable attenuator. The MA1620 on this page is perfect for that job:
Splitters amplified splitters and attenuators
It will give you a way to reduce the signal level at one TV without affecting the other TVs in the house.
Sep 08, 2014 | Televison & Video
Why does my tv show no signal
It likely has a weak tuner, made that way, not a product fault and will work with catv, devices and boosted signals. Other than that, check inputs on setup menu and see if there's an option to switch from cable to aerial as well as settings for a default channel setup that switches between clear signal and a set top box for scrambled channels.
May 10, 2014 | Televison & Video
Panasonic dmr xw385
Have you got the tv aerial connected into the dvd?
Oct 09, 2013 | Panasonic Televison & Video
Hi, I have a digital tv plugged into an extension cable in an upstairs (Toshiba) bedroom; it works perfectly - receiving all channels. I have a digital tv downstairs (Samsung) where it seems the wall...
Hi Fiona
Somewhere along the line from the aerial there must be a signal splitter that feeds the upstair and downstair terminals.
Try to find that splitter and switch the output to see if the problem goes from up to downstair.
If it does switch then you know the problem is with the splitter block, and if it stays the same then the problem is with the cable and/or the connectors that run downstairs.
Also the reason you get a pixellated(snowy) picture is because of signal loss during the length of the cable you ran downstair.
If running a cable downstair becomes the best option to fix your problem , then you could buy a cheap 10db signal booster/r.f amplifier to correct the signal loss and a cable splitter to feed both tv`s
That booster would be installed upstair in your case(near the source of the signal to be amplified).
I could send you a small diagram if need be. Hope this will help and Merry Chrismas
Dec 14, 2009 | Televison & Video
Logik LCD 32 Signal problems
Have you tried having your outdoor antenna upgraded? and do you have an antenna booster in the back of the tv where all the antenna cables connect into.
Nov 05, 2009 | Televison & Video
Just got logik ldvr 1608 dvd but it cant find any
You need an aerial to tune the freeview.
However, to record from satelite you can connect a scart lead from the satelite vcr out to the dvd in and it will record vie the av "channel" on the dvd.
Depending on your location, regarding signal strength, you can purchase an indoor, boosted aerial to tune the freeview.
Also, if the scart connection on the dvd is a 2 way connection( allowing a signal to the tv as well as from the tv) you can connect the tv to the satelite and the dvd to the satelite only and the dvd will play through the satelite even when the satelite is off.
Aug 26, 2009 | Televison & Video
No picture sound only
your lcd tv is most likely not getting enough reception for the visual signal, try switching your tv back to analog signal (not digital) if you can by switching off av on remote, do you get your picture back, if yes thats your problem check your aerial, aerial leads and plugs, also do you have an aerial amplifier plugged into a power point, is it turned on to aplify signal.
Jun 22, 2009 | RCA L26HD32D 26 in. LCD HDTV/DVD Combo
Bush TV Model No 5693D
Try using the source button to switch through different inputs.
If that does not work try connecting a signal booster to the aerial, they cost about ten pounds at Argos.
Mar 06, 2009 | Bush 5693D 24" TV
Televison & Video Logo
117 people viewed this question
Top Televison & Video Experts
Electro Med Services...
