Home | Tomtom | GO 700 GPS Receiver | Replacing the screen
Tomtom GO 700 GPS Receiver
Problem for Tomtom GO 700 GPS Receiver
By gowingj on Jun 18, 2009
I have a GO700 (1) with a cracked screen and a faulty GO700 (2) with a good screen.
Is the screen be removed from the metal frame or is it easier to change the faulty board on (2)
Comments:
Jun 19, 2009
- I have dismantled a GO700 with a good screen but faulty with a faulty board. I was about to replace the board with good one from a GO700 with a cracked screen. I wondered if it was easier to just replace the screen but can't readily see how to. The worst part of the dismantling is the aluminum tape which cocoons the GPS.
Solution #1
posted on Jun 18, 2009
Not Rated)
e-Guru
Rank: Wiz
Rating: 84%, 258 votes
There is a website that shows you how to replace GPS screens, parts are usually availabe on www.ebay.com. The repair tutorial is a : GPS Repair Guide. This third party repair service for GPS devices will charge you about 50% of a new one.
Take a look inside your tomtom go . The photo's uploaded are of the GO and Go 300 / 500 / 700 series so yours might not look exactly the same but will be similar to these. SEE PHOTO of the IC's highlighted RED. U24 is on the same side of the circuit board as the card reader. U25 is on the same side of the board as the power socket. These are the 2 chips / IC's that will be blown if reversed supply or more than about 6 volts has been applied. The blown components are usually blown due to attaching the WRONG charger or a faulty charger. ( the tomtom cigarette lighter leads often go faulty ) These IC's are very very small ( just 3.5mm across ) and the 10 pins ( 5 on each side ) are even smaller and very close together therefore normal soldering ability will not allow a novice to replace them. Special soldering irons are needed , magnifying glass or special microscope for electronics + a steady hand and good light. Its highly unlikely that a home repair is possible. Besides that , even engineers with years of soldering experience have great difficulty replacing these components and it often takes me 30 minutes just to replace one of these IC's and I have a steady hand. Most normal electronics repair companys cannot repair this type of component as they will normally deal with bigger things. So unfortunatly, your "corner of the street" TV repair shop won't be able to fix it for ya either. As far as I know TomTom don't repair these IC's either as its too fiddly and time consuming and for them not worth the effort. Your only hope is one of the repair people offering this service on online . Try a look on ebay under "faulty tomtom" .
Replacing the board will cost $500+.
Therefore I would go for the Screen replacement.
Thanks for contacting Fixya.
Solution #2
posted on Jun 19, 2009
Not Rated)
manojro
Rank: Wiz
Rating: 81%, 290 votes
call the service dealer , he can pull out screen and put it to the working one. You can get the new screen from ebay also. It will cost you around $20.
Popular Solutions for Tomtom GO 700 GPS Receiver
Questions and Unsolved Problems for Tomtom GO 700 GPS Receiver
Do you recommend Tomtom GO 700 GPS Receiver?
Answer
Answer
my tomtom navigation system is not responding
Answer
can't navigate a new address beause the safety lock is enabled, how can i fix this? thanks.
Answer
i ave a tom tom 710. it went dead, but when plugged into the charger it shows green but the screen... (More)
Answer
Hi my Tom Tom GO 700 has stopped working. I have tried resetting it but to no avail. Is there... (More)
Answer
I have a Tomtom Go910 and noticed recently that the battery wasn't charging in the car. Now it's... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Tomtom GO 700 GPS Receiver:
Top GPS Device Experts
Rank: Guru Guru
Solutions: 14023
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more GPS Device Experts
Top GPS Device Repair
(281) 371-2722
GeoQuip is a "One Stop Trimble Repair...
Gulf Coast GeoQuip
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
