Question about Food Mixers
How to strip kenwood bl597
How to stip unit
Repair Hand Mixer
the head gears are not engaging properly
could be the selector knob or stripped gears
get a quote from an appliance repair shop but if the mixer has a few years on ti then it will probably turn out cheaper to get a new one
Feb 25, 2016 | Kenwood Food Mixers
Kitchenaid ksm90ww stand up mixer while mixing my aunt put in another mixing tool and it just stipped mixing wont turn on nothing I assume she blew the motor but does anyone know if theres a reset button...
It sounds like stripped gears, does the mixer still turn on? The beater just wont spin anymore?
If that is the case the worm gear probably stripped out, that is part number w10112253, or for a quicker easier fix you can get that gear in an assembly for a couple more dollars, that would be part number 240309-2.
Here is a link to those parts on our website:
http://www.mendingshed.com/kawormgear.html
http://www.mendingshed.com/kitchenaidgearassy.html
Jan 16, 2014 | Food Mixers
Mine is a Chef Stand Mixer but really don't know model no. Where to find?
This kind of unit are lubricated with grase paste. If the unit stays inactive for a long time, or if the motor and gears are overheating the grease paste gets melted into thin oil, and that will cause leaks.
To lubricate the unit, you need to spread again the grease in the gearbox, using special foodsafe grease paste.
Disassemblying the gear box is not that easy, you will need previous experience and a gear puller to do the job properly and safely.
This appliances are also held with security screws to prevent the users from taking apart the unit, and can only be disassembled using a Security screwdriver tip.
The grease can be purchased here, check at the bottom of the page: Kenwood chef food mixer Grease.
May 26, 2009 | Kenwood KM300 Chef Stand Mixer
Food Processor stopped spinning
sounds like you may have stripped the gear that drives , or thrown teeth off the cog.
Jan 25, 2009 | Kenwood Food Mixers
Noisey
You have to take off the top on the gearbox, then you have all gears in front off you.
It´s correct that you should use vegetable based grease, the spare part number Kenwood use for this is: KW630879
Jul 05, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Blakeslee (Kenwood) A717 mixer speed control
I had the same problem. Had to strip the machine down to get to the motor. On the top is a moving plate with various capacitors etc mounted. On the front side there was a Capacitor (At least I think it was) with the wire broken.
I resoldered it and the machine now works fine.
I hope this helps
Jun 28, 2008 | Kenwood KM305 Stand Mixer
Kenwood chef.mixmaster
This kind of unit are lubricated with grase paste. If the unit stays inactive for a long time, or if the motor and gears are overheating the grease paste gets melted into thin oil, and that will cause the leak.
The oil leak is usually coming from the gear box inside the appliance.
To fix the problem the unit must be taken apart, and cleaned. After this step, there is need to spread again the grease, using special foodsafe grease paste.
Apr 04, 2008 | Kenwood KM300 Chef Stand Mixer
How do I remove and refit a motor to my KM300?
What you need is a service manual which is difficult to get for any Chef regardless of the KM300. Ive got a KM310 model but the user manual is similar to this if it helps:
http://www.kenwoodworld.com/datasheets/KM336--KW89421iss2%20KM330-KM630%20%20English%20-0.pdf
Sep 11, 2007 | Kenwood KM300 Chef Stand Mixer
Food Mixers Logo
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
