Question about HP PSC 1315 All-In-One InkJet Printer
Everything printed is offset like margins are not correct, kind of like printing a photo on paper w/a tab. Is it possible to set printer back to default settings?
  • 867 Answers
Go to control panel, printers, right click your printer icon.click properties, try setting to default settings
Posted on Jun 19, 2009
Can I print on both sides of the page
Here are the instructions for duplex printing.
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
1. Open the printer driver setup window, and check the Duplex Printing check box on the Page Setup tab.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note
sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper or Photo Paper Plus Double Sided is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
You can download a users manual for your MX310 at
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#BrochuresAndManuals
Please rate this solution. Thanks.
Sep 27, 2011 | Canon PIXMA MX310 All-In-One Printer
HP Photosmart C6100 All-in-One
Just click below;
Set Up the Printer Hardware
Remove packing materials, check contents of the box, connect the power cord, set the menus, load paper, and install the print cartridges. s.gif » Product Specifications
Minimum system requirements, connectivity, print cartridges, specifications for print, copy, paper, print margins, paper tray capacity, memory card, scan, physical size, power, and ... s.gif » Printing Instructions for 4 x 12 and 5 x 7 Inch Paper
Generic printing instructions. s.gif » Creating Borderless Photo Prints with the HP All-in-One Software
... 4 by 6-inch photo paper with tab (snapshot paper) ... Remove the paper from the paper tray and load the snapshot paper. Insert tabbed paper with the perforated, tear-off ... Click Photo Prints . The HP Photo Prints window will appear. ..
hope this may help;
Regards,
VOTIT
Jul 31, 2008 | HP Photosmart C6100 All-In-One Printer
Can not get printer to print information that on top to be copy on bottom of same page.
  1. Select 'Properties' from the Print dialog.
    Note: Properties may be indicated as Advanced, depending on the application software.
  2. Click the Page Setup tab.
  3. In the Printing Type section, select 'Normal-size Printing', 'Fit-to-Page Printing', 'Scaled Printing', or 'Page Layout Printing'.
  4. Select 'Duplex Printing'.
    Note: When a media type other than Plain Paper, Photo Paper Plus Double Sided, or Postcard is selected in the Media Type menu, duplex printing cannot be performed.
  5. Specify Staple Side.
    1. The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position.
    2. Click the Staple Side drop-down arrow and select the setting. If you want to change the setting, select another value from the list.
    3. If necessary, click Specify Margin... and set the Margin width
  6. When the setting is completed, click the OK button at the bottom of the window.
    Note:
    The document will be printed on one side of a sheet of paper when printing starts. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
    The document will be printed front and back alternately for one sheet at a time, when printing starts. Load the paper according to the displayed messages.
  7. You will be prompted, while printing, to remove the printed page and reload it in the ASF.
  8. Dependent on the number of pages to print, you will need to repeat step 7 until all pages have printed.
Feb 10, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
5. Click OK.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
Print is not centered on paper
There are two possible culprits for this problem.
1. The wrong driver is being used for your printer.
2. The paper thinks it is printing to different sized paper than it actually is.
To solve the first case:
Verify that the correct driver is being used. Go to the Control Panel (Start, Settings, Control Panel) and open up the Printers and Faxes component by double-clicking on it.
Right-click on your printer and go to Properties.
A new window will pop-up. Go to the Advanced tab and verify next to where it says 'Driver' that it lists your model of printer.
To solve the second case:
Exactly as you did above, under the Advanced tab, click on the 'Printing Defaults' button.
Then click on the Paper/Quality tab on the new window.
Under the Paper/Quality tab click on the 'Advanced' button.
A new window will pop-up. Where it says Paper/output, expand it (click the plus) to list Paper size. Change Paper size to match the size of the paper you are printing (Letter is the default 8.5" x 11").
Nov 22, 2008 | HP Photosmart C3180 All-In-One InkJet...
CLX-3160 image offset or margin shift
Dear
Please contact samsung Call center in your region. fothis type of support.
Apr 20, 2008 | Samsung CLX 3160fn All-In-One Printer
Epson Aculaser C1100 - misaligned printing
Your application will actually override the settings of the printer, what i can suggest is for you to check if you are using the correct page length and margin setting in your software program.
Try using Laserjet 3 emulation driver as well
Feb 08, 2008 | Epson Aculaser C1100 Printer
Margins not recognised
Hi lerona - I have a 5600C series HP printer. You might try these tips:
Do a Print Preview to be sure the document looks right on your screen, then in Print Setup, down in the Zoom box check the Scale to Paper Size to be sure it isn't set for the wrong paper size. There's an arrow to scroll to the size you're printing on.
Then click Properties, then the Paper Quality tab. There's an item that says "minimize margins". You could try printing with the box checked (if it's not now), or unchecked (if it IS now) and see the difference. Click the Effects tab and be sure the "normal size" box says 100%, and that there's no check mark in the "borderless printing" box.
I print documents all the time, as well as photos, smaller sized items, cards, etc., and have had no trouble with the margins printing differently than my Print Preview shows on my screen. I hope these tips help you. Good luck, and feel free to email me if you have any success with my suggestions.
Jo
JokerGirl524@aol.com
Oct 28, 2007 | HP DeskJet 5150 InkJet Printer
Cannon MP160 How to Print both sides of the Paper???
Set Duplex Printing (Windows) For details on how to set duplex printing, see below: 1. Select 'Properties' from the Print dialog. Note: Properties may be indicated as Advanced, depending on the application software. 2. Click the Page Setup tab. 3. In the Printing Type section, select 'Normal-size Printing', 'Fit-to-Page Printing', 'Scaled Printing', or 'Page Layout Printing'. 4. Select 'Duplex Printing'. Note: When a media type other than Plain Paper, Photo Paper Plus Double Sided, or Postcard is selected in the Media Type menu, duplex printing cannot be performed. 5. Specify Staple Side. 1. The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. 2. Click the Staple Side drop-down arrow and select the setting. If you want to change the setting, select another value from the list. 3. If necessary, click Specify Margin... and set the Margin width 6. When the setting is completed, click the OK button at the bottom of the window. Note: If a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab: The document will be printed on one side of a sheet of paper when printing starts. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side. If Photo Paper Plus Double Sided is selected for Media Type on the Main tab: The document will be printed front and back alternately for one sheet at a time, when printing starts. Load the paper according to the displayed messages. 7. You will be prompted, while printing, to remove the printed page and reload it in the ASF. 8. Dependent on the number of pages to print, you will need to repeat step 7 until all pages have printed. Back to Top
Sep 10, 2007 | Office Equipment & Supplies
HP PSC 1315 All-In-One InkJet Printer Logo
220 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
