Question about Solis Palazzo Espresso Machine
Solis Palazzo doesn't turn on
My Solis has stopped powering on. It has been sudden as yesterday it was fully working but today it isn't. I have checked the fuses and they seem fine. There doesn't seem to be any power going to the main power switch but I'm not sure where to look next. any help would be appreciated. thanks
LLoydstarr
SOURCE: Solis Palazzo Espresso Machine
The machine is still stuck in the descaling cycle. You must open the steam valve and let all the liquid drain from the tank. This takes approx. 45 min. because it comes out intermittenly. After this is complete all the front buttons will flash. Close the steam valve, rinse the tank, then fill it with fresh water. Open the valve again and let all the water drain from the tank again. This time it will only take a couple of minutes. After it has completed close the valve and the machine will return to normal operation.
Posted on Jul 05, 2007
Richie_asg1
  • 1036 Answers
SOURCE: Solis Palazzo - Coffee grinder seems blocked
Hi there!
This is most likely due to a build up of ground coffee at the edges, and the whole lot has become a solid lump.
Disconnect the machine and clean with a small stiff paintbrush.
This is caused by damp beans, or using dark roast beans, or keeping beans refrigerated. Often it is the coffee oil that causes it.
If there are beans in there and the unit is not rotating, please contact here again.
Thanks......Oh, and rate as Fixya! if it helps you.
Posted on Jun 19, 2008
SOURCE: Power switch will not turn on machine.
There is a power switch at the right rear of the machine. Is this on?
Posted on Jul 28, 2008
erguel
SOURCE: Solis Pallazzo espresso machine - need maintence manual
Hi, check under: http://www.solis.ch/franzoesisch/kundendienst/kundendienst_f.htm
and choose your machine, under E (english) column, you'll get the pdf.
Posted on Feb 01, 2009
  • 1089 Answers
SOURCE: brewer part for solis palazzo
Hi
What part do you need? I have some.
Posted on Jul 06, 2010
Super automatic espresso machine leaks water into drip tray and onto counter when I use the frother
The stream valve is leaking and probably needs to be replaced. If you remove the top cover it is visible.
Sep 12, 2013 | Solis Palazzo Rapid Steam Palazzo Fully...
Container leaking water
Ther is tank seal that is at the base of the machine where the tank goes on . it will dry up , waer out and leak overtime.
Apr 20, 2013 | Solis Palazzo Rapid Steam Palazzo Fully...
Indicator showing a water droplet sign on the left lights up red. What does that means? How to solve the problem?
could be one of two things
the machine is asking to be primed or ventilated , where you turn the hot water on till the light goes out.
or is asking for tank to be filled. There is a magnet float in water tank sometimes it stops floating making the machine think there is no water. to check fill tank with water and look to see if float is floating it will be grey/black in bottom corner of tank
Feb 07, 2013 | Solis Palazzo Rapid Steam Palazzo Fully...
Solis palazzo not producing coffee
I think the blockage might be at the brew unit, remove unit and check the screen under the red o-ring, connected to that is the chute that leads to the espresso spout. That tube might be blocked, there are 2 screws holding that piece together, be careful when you remove them do not lose the spring and ball in the fitting. Clean tube and reassemble.
May 24, 2012 | Solis Palazzo Rapid Steam Palazzo Fully...
Solis Palazzo : turn on machine the brew group does not position it self to prepare coffee.powder coffee, coffee, and espresso lights blink. Brew group is not removable from machine. machine has had light...
Hi
This is for a Vienna but it should work for you Palazzo. It will help you get the brew group out and reset so you can reinsert it.
http://www.fixya.com/support/r2296970-brew_group_stuck_t_get_out
Aug 04, 2011 | Solis Palazzo Espresso Machine
Brewer part for solis palazzo
Hi
Jul 05, 2010 | Solis Palazzo Espresso Machine
Does not warm up
HI
If you don't have any other lights on, it could be 1 of 2 things. Your boiler is bad or your power board is bad. Can you get steam or hot water?
Oct 25, 2009 | Solis Palazzo Espresso Machine
Aug 30, 2008 | Solis Palazzo Espresso Machine
Standby
I turn mine on in the morning and off at nite.
Oct 20, 2007 | Solis Palazzo Espresso Machine
Solis Palazzo Espresso Machine Logo
48 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Colin Stickland
Colin Stickland
AZBen
AZBen
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
