Question about HP Computers & Internet
What to do if i have a motherboard which doer not support ddr3 ram
What to do
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 39 Answers
You can either look for the correct ddr memory for your system or upgrade your current board to a ddr3 compatible one
Posted on Mar 21, 2014
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • 32 Answers
Purchase a new ddr2 ram for your motherboard or
Purchase a new motherboard for you to use your ddr3 ram
HOpe that helps you
Buy now to HPParts us Computer Parts Power Supplies Electronics Hard Drives...
Posted on Apr 06, 2014
3 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: Ram Upgrade
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
you will need to select your motherboard
hope it helps you
Posted on Feb 11, 2012
byteguy
  • 2229 Answers
SOURCE: In the Manual the Gigabyte GAZ68XUD3HB3 Motherboard says to put RAM in slots DDR3 1 and 2 or DDR3 3 and 4 if you use 2 sticks. Several posts on- line say this is incorrect, and to use DDR3 slots 2 an
Slots 1 and 2 or 3 and 4 are correct. Be sure you are using the correct kind of RAM for your computer and that both sticks are the same size and type.
Posted on Mar 22, 2012
Testimonial: "The type of RAM i used was not on the QVL list. I will purchase some from that list. It is Corsair RAM that has the same specs as RAM that was tested, but a different serial number, as well as not having XMP."
Which is the correct DDR2 or DDR3 How many pin connections are required
Both DDR2 and DDR3 RAM modules have 240 pins, BUT the notch in the memory modules are slightly different positions in the DDR2 and DDR3.
The notch in the DDR2 is in the middle of the RAM module BUT the notch in the DDR3 is offset slightly off the middle of the RAM module.
Jul 03, 2011 | Computers & Internet
Will my shuttle fd30 plus motherboard support a ddr3 gt 430 video card and a ddr3 memory card?
Yes it will support DDR3 GT 430 Graphics card.
But it will not support DDR3 RAM.It only supports DDR2 RAM.
Thanks for using FixYa.
May 26, 2011 | Computers & Internet
I have a m4a78lt-m motherboard will kingston ddr3 1600 4gb khx1600c9d3b1k2/4gx memory work with 32bit os I am putting a system togather have purchased the mother board and memory now i am questing if it...
This motherboard uses DDR3-SDRAM, ECC and non-ECC, unbuffered, PC3-10600(1333mhz) or PC3-8500(1066mhz), dual channel architecture (two sticks at a time), and a max memory of 8Gs.
This are the specs for your ram: 4GB 1600MHz DDR3 Non-ECC
(Kit of 2) Intel XMP HyperX = DDR3-1600
Default = DDR3-1333 CL9-9-9-27
CL9-9-9 1.65V
1.5V
In other words, Yes! This should work just fine. The ram will just run at its default speed of 1333mhz.
Jan 28, 2011 | ASUS M4A78LTM LE Motherboard
GA-X58A-UD3R what ram does it support ???? gigabyte site is hard to find anything about their suport list of ram options
Each memory slot can hold DDR3 PC3-10600, DDR3 PC3-8500, DDR3 PC3-12800, DDR3 PC3-17000, DDR3 PC3-14900 with a maximum of 6GB kit (2GBx3) per slot.*
  • 240-pin DDR3 DIMM Banking: 6 (2 banks of 3)
  • Chipset: Intel X58
  • DDR3 SDRAM Frequencies: PC3-6400, PC3-8500, PC3-10600 and PC3-17600
  • Error Detection Support: Non-ECC only
  • Graphics Support: Quad PCI Express x16
  • Max Unbuffered DDR3 SDRAM: 24576MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR3 SDRAM only
  • USB Support: 2.x and 3.x Compliant
  • From crucial.com
    Dec 19, 2010 | Gigabyte GAX58AUD3R Motherboard
    Can i upgrade my ram to ddr3 if so what would you recomend .cheers
    Thank you for the clarification sir.
    NO, the Fujitsu Scalio 600 Media Center uses the Gigabyte GA-8ISXT-FS motherboard, and it only supports DDR Sdram.
    This is a PDF Motherboard Manual for the GA-8ISXT-FS mobo, from Fujitsu Support,
    http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/Boards/Motherboards/GigaByte/ga-8isxt/Man_8isxt-fs_uk.pdf
    This is the support page for the Fujitsu Scalio 600 Media Center,
    http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/consumer/MediaCenter/Scaleo%20600/Scaleo%20600.htm
    Uses either DDR Sdram at 333MegaHertz, or 400MHz.
    (PC2700 and PC3200 respectively)
    DDR Sdram has 184 gold plated contact pins on the bottom.
    DDR2 Sdram has 240 gold plated contact pins on the bottom.
    DDR3 Sdram has the same amount of contact pins as DDR2.
    The voltage and signal contact pins are in a different place, from DDR2 to DDR3.
    This is why the locating notch on the bottom of the ram stick, is in a different place, comparing DDR2 to DDR3.
    So you can see, DDR3 not fit in a DDR2 slot, because the locating lug in the bottom of the ram slot, and the locating notch in the bottom of the ram stick. Keeps people from trying to put DDR3 in a DDR2 slot, and vice-versa.
    You can also see why a 240 pin ram stick, will not fit in a 184 pin ram slot.
    Bumping up from DDR to DDR2 does make a difference in my book. (Requires using a motherboard that supports DDR2 however, so you would need a different motherboard)
    Going from DDR2 to DDR3? Not so much IMHO. The frequency rate is higher, but there is a trade off with slower ram timings.
    Sorry if I have been too 'Windy', but I thought I would give you more information, than just,
    'No, won't work', or No won't work because your motherboard uses DDR Sdram'.
    Nov 18, 2009 | Televison & Video
    Which is better 1gb ddr3 rams or 3 gb ddr2 rams?
    No dubt about that! I would have take the 3gb ddr2 ram!
    In a couple of years from now, when everything supports DDR3 i would have taken the DDR3, but today i take 3gb DDR2!
    Nic
    Jan 28, 2009 | Asrock P4I45GV R5 Motherboard
    Computers & Internet Logo
    81 people viewed this question
    Top HP Computers & Internet Experts
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
