Question about Kingston 8GB Data Traveler - 108: DT108/8GBZ
My pendrive no runned
The pendrive was no runned when put in my PC, how to fix it?
  • 4 Answers
Try updating USB drivers :)
Posted on Apr 29, 2014
Testimonial: "thank you :)"
How to Install a Computer Operating System Using a Pendrive?
First You have to have a pendrive were you can save the operating system at least 16 gb I use a 32gb pendrive next you can run the install file you have to format the pendrive and make an iso file from original dvd. or download it from microsoft. copy te iso file in your pendrive and run it
Oct 18, 2016 | Computers & Internet
Pendrive can detect but cannot read
Pendrive was problem.
When you click properties for pendrive then you will find capacity for your pendrive is zero.
However you can try to use other usb port. sometimes, usb port have problem. If you check properties it have capacity. mean not zero, then try check disk tool to fix error.
May 25, 2011 | Computers & Internet
I have a DT 100 8GB usb pendrive I put my pendrive in USB and copy pictures from my PC to pendrive after I can see my pictures on pendrive but when I go to properties I can see that I am using some space...
I would tick in one box automatically fix files then return after it has repaired then tick the other box
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start or you might tick one box then return after its finished the first repair the tick the second box
hope this helps don
Mar 01, 2011 | Computers & Internet
4gb Kingston pendrive isnotworking it is the new pendrive
Your pc already affected by virus ,you will need another pc to put the pen drive.then you will format the usb drive.Actually an autorun programe is running in your pc you can manuallly remove the virus .follow the instruction.
http://amiworks.co.in/talk/how-to-remove-new-folderexe-or-regsvrexr-or-autoruninf-virus/
Or you can another do it another way.
You should better to install quick hill and install for scan your HDD .
Here is the link =http://www.quickheal.co.in/downloads.asp
Feb 19, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I am unable to access pendrive at my laptop but at others it is working fine
Open RUN from the Start menu, type DEVMGMT.MSC and you can able to view the Device Manager window once you press enter. There you can able to view the USB Controllers. Expand that and Right Click and select Un-install. Do this for all the USB listed there and reboot your PC.
Connect Pendrive and check whether working or not.
If NO, do the next step. Remove the power cable, remove the battery and press and hold the Power Button of your PC for 60 seconds. Put the battery back and turn on your PC. Check whether now the Pendrive works or still facing the issue.
Please let me know the status.
Thanks for using FixYa.
Jan 29, 2011 | Computers & Internet
I have a kingston 8gb pendrive i had tried to make a bootable pendrive by using command prompt and i failed. I also made my pendrive partition so capacity of my pendrive falled from from 8 gb to 3.44 gb. I...
Most of the time running a disk check first will fix your problem.
Right click on your drive's icon in "My computer"
Select properties. Go to the "tools" tab, select "check for errors".
Depending on the operating system you use, this could also be called "run scan disk", "run disk check" or "check for errors".
Jan 25, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How to remove shortcut virus in my laptop
Run Norton Anti Virus to remove viruses.
Jan 22, 2011 | Computers & Internet
How i can make xp proff service pack 2 bootable pendrive, cd,sdcard
helo frind
1. Windows Xp installation disk
2. Access to PC with working CD Cd-ROM DVD drive.
3. This file solution.rar
This guide is for people with basic knowledge of PC hardware and system software
Let's start.
1. Download solution.rar file
2. Unpack solution.rar file on drive C, you should have a folder named C:\Dos
3. Put your pendrive ( at least 1GB) into working PC USB port
4. Go to the folder C:\Dos and run HpUSBformat.exe file
- it should auto detect wyour pendrive disk, if not select form the list ( my pendrive is a drive G: )
- set other options like on the image below and click start.
- now you have a pendrive with bootable dos on it.
5. Copy all other files from C:/Dos to your pendrive. ( you can overwrite existing ones)
- your pendrive should look like that
6. Put your Windows Xp installation disk into Cdrom and copy all files from CD to pendrive.
good_lk
Oct 12, 2007 | Microsoft Windows XP Professional With...
Kingston 8GB Data Traveler - 108: DT108/8GBZ Logo
89 people viewed this question
Top Kingston Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Kingston Audio Player and Recorder Expert? Answer questions, earn points and help others
