Question about GE Televison & Video
Mitsai tv When watching through HDMI after a while it jumps back to scart
    Top Expert:
  • GE Master
  • 74,243 Answers
Main system control memory IC fault. Contact any service technician. This is not a user repairable fault.
Gopakumar Gopalan Google
Posted on Mar 20, 2014
Testimonial: "So if TV still under warranty take it back to where it was bought"
Got a double picture on my TV which is going through a bt u view box
If you are not getting a tidy pic first thing I would check or change is scart lead make sure they are firmly in back of TV and your viewing box if so try another scart lead, the thicker the scart lead is the better they are apparently. Or if your using hdmi lead instead of scart try another hdmi port at back of TV as these ports tend to break easy in TV as they break off the mother board.
Apr 12, 2016 | Televison & Video
How to watch a dvd
Check out what kind connections are in the DVD and Flat TV.
In the DVD usually you can find 'S-Video' , 'RGB', 'VGA' or 'SCART'
Flat TV usually have 'SCART', 'HDMI'. So, perhaps you can use 'SCART'
Apr 05, 2016 | Televison & Video
I have a UK satellite receiver with Roa input and scart output and want to connect it to a hdmi TV. Are there any scart to hdmi connectors and will that work or do I need a convertor as well?
Simply using a cable with a scart connection at one end and an HDMI connection at the other will not work as scart is an analogue signal and HDMI is a digital signal and so you will need to buy an HDMI to Scart Converter/Adapter to change the signal.
There no such thing as Scart to HDMI Cable HDMI Hero Splitting HDMI pictures has never been easier
Dec 22, 2014 | Televison & Video
How do I connect a dvd player to tv with no scart connection
Make and model of TV would help.
Very odd TV with no SCART and only a single HDMI. You sure it's not a computer monitor? happy.gif
If the TV really does not have any sort of analogue input you will either need to buy a disk player with HDMI or an analogue to digital converter (the former may well be cheaper!), And if there is only a single HDMI you can but switches to expand the number of HDMI inputs if necessary.
User manual here
http://documents.knowhow.com/TV-Home...nal_120524.pdf
Refer to page 15 which states:
"Use a included SCART adapter cable to connect
between the TV's SCART input socket and a SCART
cable to an external AV device's SCART output socket."
Dec 12, 2014 | Televison & Video
I HVE a ilo tv WHT do I go to in menu to watch my dvd
hi if your using hdmi select hdmi on the tv if your using scart lead select scart on the tv, to get these setting press the source button the remote,the symbol is a box with a line in it. hope it helps
regards
shaun
Jan 30, 2014 | Televison & Video
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Jul 04, 2017 | Televison & Video
Have NO picture only sound WHEN TRY TO WATCH A dvd.help
do you use a scart lead? or hdmi cables if its a scart lead its either not pushed all the way in on the back of your dvd player or tv or a cable inside it has snapped have you got another one to try it??
if its hdmi again try another cable as new cables can be faulty
Hope this helps
John
Mar 12, 2011 | Televison & Video
CAN I STILL WATCH SKY TV THROUGH MY TV WHICH HAS FREEVIEW BUILT IN
yes...via scart or hdmi (depending if you have sky hd) tv will need to be set on AV1 or HDMI channel when watching sky tv. normally selected on your tv remote with a button with a square and an arrow pointing into it or simpally AV written on the button.
Mar 19, 2010 | Sanyo Televison & Video
Vhs dvd combi panasonic dmr ez47
If you select the HDMI channel to watch a dvd does it do it then, if not disconnect both ends of the scart lead and reconnect or replace. If the scart lead is not in properly this could happen, when you switch on the player and play a disc your tv will automatically switch to the AV/Scart channel, but you are better off manually turning the TV over to the HDMI Hi-Def channel for DVD.
Dec 24, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Watching digital tv using a Panasonic DMR-EZ47VEB
PLEASE NOTE THIS INFORMATION COVERS PROBLEMS FOR ALL DEVICES CONNECTED UP BY STUPID scart LEADS. I HOPE IT HELPS EVERYONE.
This is a common problem, the problem is caused by the fact your device is connected to the TV via a scart lead. The way it works is this: If you press the AV button on your TV remote your TV will turn over to the first scart channel. If you actively do something on the device connected via scart in this case the dvd player, (this includes things like playing a DVD or Video, or going into a menu), the device sends a signal down pin 8 of the scart lead and turns the TV over automatically to the AV channel, BUT as soon as you come out of the menu or stop the DVD/Video the signal stops and the TV will revert back to the channel it was on.
So you have 3 choices......maybe 4...
1. press the AV button on your TV remote directly.
2. Buy yourself and HDMI lead IF your TV supports it (note: you will have to select the HDMI channel on your TV remote because the auto thing is only on scart leads).
3. ONLY DO THIS IF YOU HAVE A SPARE LEAD look up a diagram of a scart lead on Google so you can find pin 8 and cut it out with a pair of wire cutters. YOU will have to still press the AV button on your TV remote to go to the channel though,
4. Connect your TV and DVD with an aerial lead and tune channel 6 on your TV into the DVD player. ps then disconnect the scart lead.
(Go for choice number one!)
Oct 14, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
42 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
