Question about JBL Duet Computer Speakers
Cant remember how to set up speakers,am left with the other end of the usb cable,where does it go
  • Elisa Hall Jun 18, 2009
    Hi respect,thanks for the help,I have the usb end into the tower of the pc but its the other end I cant find where to plug in
    Thankyou
    E
    what do you mean by desktop?
  • 157 Answers
That USB cable needs to be plugged into a USB port on your computer.
Posted on Jun 18, 2009
  • Jordan Hansen
    Jordan Hansen Jun 18, 2009
    Ok if it is a green connection then you need to plug it into your speaker output which would be located on the back end of your desktop.
  • Jordan Hansen
    Do you have a laptop? Contact me on messenger at pizzaman8166@yahoo.com yahoo will work with msn messenger.
Can I buy a replacement charging cable?
not sure as this speaker uses a Y usb cable
I found a cable but not sure if it is the required cable as the cable has a 3.5mm stereo cable that goes into p.c. and a usb cable that then plugs into pc on one end and a micro usb plug that goes into the speaker.
http://www.aliexpress.com/store/product/2pcs-3-5mm-AUX-USB-Male-TO-Mini-USB-Y-cable-for-Portable-Speaker-Audio-Cable/723272_1821834677.html
check it out and decide if it looks like the same cable. ???
Oct 12, 2015 | Genius Sp-i160 Mini Portable Usb Speaker...
I got a set of Sony SA-VA15s from a yard sale. They didnt come with the 13 pin ribbon cable. Will the left speaker work without this cable? I tried to hook it up and nothing.
no you need the ribbon this connects the all together to get the sound usless with it get in touch with sony tell them what you haver they usuall have spare parts they will send you a new one, worth a try if not ebay is the answer
May 04, 2014 | Audio Players & Recorders
I have a Kenwood stereo receiver model k2 3600 , the left speaker keeps going out , the right speaker works fine. I've tried adjusting the speaker wire for the left speaker, and I always end up having...
HI,
BASED ON THE INFO YOU GAVE I HAVE SOME SUGGESTIONS BELOW..
1, switch the working right speakers cable to left output and problem left to right (from the back of receiver -not from the speakers it self..) to see if problem continues..
2.After switching them ,if it (old left new right one ) still stops left speaker cable may have short ( a tiny cable inner pieces may touching to other side ) at either at the back of receiver output or at the end ,at speaker input .
make sure you control it carefully...if the problem persist please contact to me..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Thanks
Jun 17, 2011 | Kenwood Audio Players & Recorders
There is not a subwoofer input jack on the back of this subwoofer. There are a set of input (negative and positive) terminals and a set of output (negative positive) terminals like would hook speaker wires...
On the back of the sub woofer you have two sets of binding post / some have spring clip terminals ( red & black ) labeled Speaker In ( sometimes High Level In ) and Speaker out.
Take 2 pairs of speaker cables and connect one end to the speaker out socket of your amplifier ( left & right ) . The other end of the cable should be connected to the sub woofer's Speaker In socket , Red to red and black to black. Now on the Speaker Out socket of the sub woofer connect your existing pair of speakers using another pair of speaker cables. If your sub woofer has a Hi Pass filter built in , you may not hear bass coming from your existing speakers with this kind of connection. Good if you have small satellite speakers.
Mar 12, 2011 | Audio Players & Recorders
How do i connect the boston BA745 comp. speakers to my gateway desktop?
Assuming you have the BA745 2.1 speaker set up, all of the cables connect to the subwoofer and then to the computer or the satellite speakers (these are built into the speakers IIRC). Take the cable with the black box (2 pins) to red and green. The red and green plugs go into the matching color ports on the computer and the pins on the black end fit into the jacks between the those for the two satellites. Plug the single end speaker cable into the subwoofer port all the way to the right on the back of the subwoofer. Plug the wire with the two plugs into the matching color jacks (blue to the left, red to the right). Then plug in the power adapter cable in the farthest left jack and plug in the other end to a surge protected power strip (that is plugged in and turned on).
Oct 24, 2010 | Boston Acoustics BA745 Computer Speakers
How do I hook them up. Moved and can't remember how to hook them up. I have them on the side of the computer with plug in , one on the left side and 2 plugs on the right side...no sound
speaker A should two cables running from it plug one end into speaker B a large RCA jack,
Plug the other end into your PC Sound card (speaker out ((( )
then if it's a active systems plug Power converter into A/C port on back of Speaker A
Aug 24, 2010 | HP JBL Platinum Computer Speakers
How do I connect external speakers
    Connecting Full-Size Speakers
  1. Step 1 Insert the red and white plugs on a set of RCA audio cables into the right and left audio "OUT" jacks on the back of the TV.
  2. Step 2 Connect the other ends of the cables to a free pair of audio "IN" jacks on the amplifier.
  3. Step 3 Strip 1/2 inch of insulation from the speaker wires, and connect a pair of wires to the left and right terminals on the back of each speaker using the red wire for the right audio connection and the other wire for the left.
  4. Step 4 Connect the other ends of the speaker wires to a pair of stereo speaker terminals on the back of the amplifier. The wires attach by raising spring-loaded clips on the back of the amp to reveal a hole for inserting each wire.
  5. Step 5 Set the amplifier selector to the set of audio jacks connected to the TV to enjoy stereo sound from the television.
  6. Connecting Self-Powered Speakers
  7. Step 1 Insert the RCA plugs on the Y adapter into the TV's Audio "OUT" jacks.
  8. Step 2 Connect the mini-plug on the wire attached to the right-hand self-powered speaker to the mini-plug jack on the Y adapter.
  9. Step 3 Plug in the audio cable and mini-plug from the left-hand speaker into the Audio "OUT" jack on the back of the right-hand speaker.
  10. Step 4 Connect the AC adapter to the power jack on the back of the right-hand speaker, then plug the adapter into an electrical outlet.
  11. Step 5 Switch on the external speakers and adjust the volume.
Jun 01, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Mazda 323 1996 wiring
this is for 1996 mazda protege i hope this can help
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Pink/Black
Car Radio Ground Wire: Black/Yellow
Left Front Speaker Positive Wire (+): Blue/Orange
Left Front Speaker Negative Wire (-): Violet/White
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Yellow/Red
Left Rear Speaker Positive Wire (+): Orange
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Green/Black
Right Rear Speaker Negative Wire (-): Green/Orange
Mar 27, 2010 | Mazda 323 Cars & Trucks
Left channel will not play
Firstly try swopping over the left speaker to the right channel . If still no sound then either the speaker cable will have a break in it & need replaced or the actual speaker will be open circuit. If you get sound from the speaker on this channel then the the speaker is ok. Check your PC's audio set up... Go to Control Panel/ Sounds & Audio devices/ In volume Tab, click in Device volume area... Advanced & then check the Balance settings are not set to one end.
Jul 22, 2009 | Dell A525 Computer Speakers
I Do Not Know How To Connect Boston Micromedia To My Computer
The Boston Micromedia speaker set comes with two speakers (right and left),a subwoofer, and a complete set of cables to connect everything up.
1.) Position the speakers. The two small speakers typically are spaced equal distance apart on a desk/table top to the benefit of the listener. The sub-woofer typically rests under the surface, on the floor for example.
.) Connect the cable sets to the back of the two small speakers along with the speaker feet.
Note: the small speaker with the volume control knob will have three cables coming from it. This will be the "right" speaker. The other speaker will have a single cable and will be the "left" speaker.
2.) The cable ends will be color coded to match the jackson the sub-woofer. Match up the color coded cables to the respective colors on the subwoofer as follows:
(a) White cable end (left speaker) to white jack on sub-woofer.
(b) Red cable end (right speaker) to red jack
(c) Purple cable end (input) to the purple jack
(d) Green cable end (computer out) to the computer's microphone output jack.
Note: if any of the cables are too short to reach their jacks for whatever reason, an extender cable with a female and male end can be purchased relatively inexpensively to make up the difference in distance.
3.) Power up the system (plug in power cables to the sub-woofer and wall), play some music, and adjust the sub-woofer sound (control knob) to suit listening pleasure.
A nice little set of speakers, I had mine for some years now and continue to enjoy them. Good luck!
May 17, 2009 | Boston Acoustics MicroMedia Computer...
JBL Duet Computer Speakers Logo
147 people viewed this question
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
