Question about Siemens Computers & Internet
Op27 conversion how to convert op27 to op277 in protool??
Convert 6.490'' into inches
with a double quote ( " ) after the 6.49 it is already inches? Roughly six and a half inches.
Conversion of inch to centimeter (cm)
www.calculconversion.com/conversion-inch-cm.html
Convert or calculate inch to cm or cm to inch. Free online converter of inches and centimeters (cm).
Millimeters to Inches conversion ' mm to inches - Metric Conversion
www.metric-conversions.org > ... > Length Converter > Millimeters Conversion Bookmark Page inches to mm (Swap Units) Millimeters to Inches table - Click here for table options. ... The millimetre is a unit of length in the metric system, equivalent to one thousandth of a metre (the SI base unit of length).
convert 6 490 into inches Google Search
Mar 19, 2017 | Office Equipment & Supplies
Pst to Mbox and Eml Conversion
You can go for third party tools available for this kind of conversions. These tools are good and efficient enough to fulfill your needs of transferring mails successfully. I also had this issue once but was saved by Pst Converter protool. This tool works great without any hassle. I think this will help you to solve your problem. THANKS
Apr 15, 2013 | Computers & Internet
Is there a software for edison scratch 2500
You could buy what's called a "Midi to USB" and then you could use many programs, such as Virtual DJ, Sonar, ProTools, Reason, and so much more. So yes, there is a ton of software out there for your board, you just need the software, and the unit for the midi conversion. :] Hope this helped.
Feb 23, 2013 | HP Computers & Internet
What i/o do i need to hear my tracks through protools
It depends on what version of Protools you are using. And also on what it is running on, PC or MAC. Starting with v9 Protools is hardware independent. Which means and audio interface (I/O) should work just fine for listenning to tracks from protools. Depending on your computer it will support direct audio or core audio. make sure the interface supports ASIO as that is the standard and default way to go
Dec 26, 2011 | M-Audio Fast Track USB (FASTTRACK) Audio...
Mbox cannot start new session or load in old sessions.
Digidesign website had the answer....go to windows,show workspace and change the settings for your relevant disc from transfer T to R...record in the A..audio column.
Thanks  Bobcat8
Oct 07, 2008 | Digidesign Mbox External Sound System
Mbox problem (no input,output)
i'm running os 10.5.6 w/ protools 8.0 and the original mbox. i had the same problem. protools opened and seemed to work except there was no sound from either analog outputs or headphones. this worked for me:
1. shut down computer
2. unplugged all usb cables except keyboard/mouse
3. restarted computer
4. re-plugged usb cable from computer to mbox
5. opened protools session
6. hit play and now i'm hearing sound and everything seems normal.
i hope this helps everyone else
Oct 03, 2008 | Digidesign Mbox External Sound System
2488 to pro tools
There is no way to 'sync' with protools from the 2488. In order to use your 2488 tracks in protools you have to first export your tracks as wav files and move them to your computer via usb and then import them into protools.
To get Protools files into your Tascam 2488 you'll have to export your Protools files into mono wav files first. They must also have a sampling rate of 44.1KHz and can be either 16 or 24 bit. Then load these files into your 2488 via usb and import them into tracks on the 2488.
Nov 21, 2007 | Tascam 2488 Portastudio Multitrack...
Computers & Internet Logo
99 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
