Question about Pentair Meteor Above-ground 22" Sand Filter System w/ 1 HP Pump
Pentair filter need to know where backwash, rinse & filter settings are
  • 83 Answers
I am sure that you already have an answer to this, but IF you can not read the valve label sticker, call the Pentair Customer Support 1-800 number. They will send you out a new label, free of charge.
For referrence, the waste position is ALWAYS over the waste port on the valve.
Posted on Jul 01, 2009
How do I backwash pentair ccp420 system?
you cant backwash that is a cartridge filter you have to take the big ring off the center drain water out of the filter then remove cartridges soak them in a solution of tsp Tri sodium phosphate (you can buy at hardware store soak of rinse with this solution then rinse with water then use filter cleaner on them then rinse then put back together
Jul 14, 2014 | Pentair Clean Clear Plus Ccp420 Pool...
How do you backwash your pool
if you have a sand filter or de filter turn system off then turn multiport to back wash turn back on let run until the backwash glass is clear turn off then turn to rinse turn back on for about 20 sec then turn off then turn multiport back to filter then turn back on
Oct 20, 2013 | Pentair 1.0 Hp Whisperflo Pump
How to backwash a pool with a pentair intelliflo vs + svrs pump and pentair cartridge filter
if you want to backwash put in service mode after then put back online you cannot backwash a cartridge filter
Sep 02, 2013 | Pentair Pool & Spa
I need to know what all the settings are like bacwash filter on the valve system
FILTER is the valve position when the system is in the normal filtering mode.
When you backwash the filter you first need to turn off the pump, place in BACKWASH position, and run the motor for 45 seconds (or until the backwash water is clear). Turn off pump and run in the FILTER position for 15 seconds. Repeat twice more.
The RINSE position is to clear any dirt in initial start-up cleaning, plus resetting filter bed after backwashing.
The WASTE
position is for vacuuming directly to waste, lowering pool level, or draining the pool.
The CLOSED position is for shutting off all flow through the valve.
The RECIRCULATE position allows water to flow from the pump through the valve and directly to the pool.
You will probably only to use the FILTER, BACKWASH and maybe the RINSE valve position. The RINSE position is not as important as indicated by the fact that many backwash valves don't have a RINSE position.
I hope this helps.
Sep 05, 2011 | Hayward SAND FILTER, PRO SERIES
I was backwashing the pool and put it back to filter and it will not ****. Thanks Rob
After your pool filters on the "backwash" setting, you should move it to the "rinse" setting. With the pump off, set valve to rinse. Start pump and operate for about 1/2 to 1 minute. This ensures that all dirty water from backwashing is rinsed out of the filter to waste, preventing possible return to the pool. Stop pump, set valve to "filter", and start pump for normal filtering. If it still won't start, check for restrictions in the intake and discharge lines.
Oct 06, 2010 | Hayward SAND FILTER, PRO SERIES
I need a picture of where the valves are to backwash on a Pentair filter.
if filter cartridges no backwash need to clean them if sand or DE backwash on multiport
Mar 17, 2010 | Pentair FILTER TANK BOTTOM, 48 SQFT
How do i drain my pool with a hayward variflow pump?
To Flush out the filter with the backwash setting. The backwash setting releases trapped particles from the filter back into the swimming pool. You may need to alternate between the rinse and backwash settings until the water runs clear in order to unblock your filtration system and flush out clogs. To Rinse away dislodged items from the backwash setting. The rinse setting flushes clean water through the pipes and carries away any particles or clogs freed during the backwashing. To Drain the pool select waste on the multiport valve. This sends the water directly to the drain rather than back into the swimming pool. Close the filtration equipment and stop the pump with the closed setting. You should only use the closed setting when you turn the pump off. This function allows you to remove the strainer basket, clean the filter tank and perform other swimming pool maintenance on the filtration system.
Aug 08, 2009 | Hayward 1.5 Hp Northstar High Performance...
How do I backwash my Pentair Vertical Grid DE filter?
For instructions on backwashing and other trouble shooting, you need an Owner's Manual. You can find one online at the following link:
http://www.pentairpool.com/pdfs/FNSPlusVerticalGridDEFilterOM.pdf
The way you backwash this filter is easy once you get the hang of it!
The first thing you will do is turn off the system, change the valve position to the Backwash position. If you have a Multiport Valve, you will press down on the handle and spin it so that the knotch is pointed to BACKWASH. If you have a Slide Valve, only has two positions, up and down, you turn the handle so that the metal pin is out of the holder and move the handle in the opposite direction. You will need to turn the handle to lock the pin into position.
Once this is done, you will turn on your pump. Pentair recommends that you backwash for 1 minute, then turn off the pump.
If you have the Slide Valve, you will put it back into the FILTER position and then turn the pump back on for 1 minute. If you have the Multiport Valve, you will put it in the RINSE position and then turn the pump back on for 1 minute.
Pentair recommends that you do this cycle a total of three times, backwash/rinse, backwash/rinse, backwash/rinse. AFTER the third time, you will need to open the Air Release Valve at the top of the filter while the pump is OFF and the valve position in back on FILTER. Once this is done, turn on the pump. When you have a steady stream of water coming out of the Air Release Valve, close that up. This way you have no air in the system.
Now, you will mix your DE "Slurry" in a bucket. Depending on your model of filter, you will measure out your DE and mix with water to the consistancy of milk. **IF it is just a backwash, you will only add 80% of the original amount of DE. You only add the total 100% of DE when you completely take the filter apart and clean it out.**
You will slowly pour the slurry into the skimmer that is closest to the pump. This will allow the DE to evenly coat the grids in the filter. Wait about 5 minutes and then check the pressure gauge on the filter. Once the PSI reaches 8 to 10 PSI above this number, it is time to backwash.
Jul 09, 2009 | Hayward EC-40 DE Pool Filter with pump
Missing filter ring
First, let me inform you that if you contact Pentair, either through email or phone, and let them know that you can not read the valve label on your filter, they will send you one through the mail.
One thing that helped me remember the position of the valve handle was that the WASTE position is always located over the Waste Port on the filter. If you know where the FILTER position is, stand by the filter so that FILTER would be at the top, or the "12 o'clock" position. Now, going to the right, clockwise, the positions are as follows: FILTER, RINSE, RECIRCULATE, BACKWASH, CLOSED, WINTERIZED, WASTE.
To change the position of the handle, you will need to stop your pump, push down on the handle-lifting up the pointed end- spin the handle so that the pointed end will sit pointing toward the position you want.
If you do no have an Owner's Manual, you can find one online at the following link:
http://www.pentairpool.com/pdfs/Cristal-FloOM.pdf
Jul 01, 2009 | Sta Rite Sta - Rite Mod Media 450 Sq Ft...
To back wash my filter
The drain is the black cap that is on the side on the tank near the bottom. To backwash this type of filter you do not need to drain it. Turn off pump, move multiport valve handle to backwash, run pump for 30 seconds to 2 minutes, turn off pump, move valve to rinse, run pump for 10 seconds, turn off pump, move handle back to filter. You may need to repeat depending on how dirty the filter is...
Apr 08, 2009 | Hayward SAND FILTER, PRO SERIES
Pentair Meteor Above-ground 22" Sand Filter System w/ 1 HP Pump Logo
201 people viewed this question
Top Pentair Garden Experts
Charles T Nevin
Charles T Nevin
David Burbee
David Burbee
David Spradling
David Spradling
Are you a Pentair Garden Expert? Answer questions, earn points and help others
