Question about Refrigerators
Westinghouse freestyle refrigerator
I have a westinghouse freestyle cyclic defrost fridge RP423. The ap thermostat appears to have gone is it possible to get a new one and to replace it myself?
2 Suggested Answers
Sea Breeze
  • 4654 Answers
SOURCE: Westinghouse RP423 Freestyle fridge cooling failure
I am going to assume you are in the UK. the voltage is higher than most household refrigerators here in the USA. Disconnect power to refrigerator and check continuity on two of the three terminals of the compressor at a time until you measure the resistance in the windings all the way around. The terminals should be marked R, S and C. (Run, Start and Common) you should get a reading with your multimeter all the way around. When you have done this and have the readings I want you to touch one end of your multimeter to the metal pipes or any clean metal outside the compressor and the other to one of the three terminals one at a time like you tested before. With your multimeter set up the same, see if you get a reading from metal housing to the three pins, or terminals c, r and s. You should get no reading. If you do, the compressor is a burn out and on the first test if you don't get a reading on the two at a time test between two post that is considered to be open or broken windings. The compressor does have an internal overload that may be open also. But if cool at time of test, and it shows up the compressor in bad. Let me know what you find...Thanks, Sea Breeze
Posted on Apr 24, 2009
How old is my fridge
most electrolux/ westinghouse products you can use the serial number to identify the production date ( eg: 345978 ) the first number represents the year( eg: 3 45978 )( 1993 or 2003 ) hope this helps
Apr 08, 2014 | Westinghouse Refrigerators
Westinghouse freestyle fridge &freezer work but warm after being turned off fo 90 days
What happens in that 72 hours is the evaporator coil get's so much frost built up on it that the fan in the evap. freezer fan has no where to circulate the cold air (where the cold is produced). Basically you have a restriction between freez/fridg. sections you have defrost problem> It is one of three things d heater,d t stat, or your d timer.I need the model # to tell you what my sugestions would be and where to start.
Nov 15, 2013 | Refrigerators
Westinghouse freestyle fridge. Fridge compartment not staying cold, freezer compartment working fine.
likely a malfunction somewhere in the defrost system, i.e., the defrost timer control, the defrost heater assembly, or the defrost bimetal thermostat
Mar 01, 2010 | Refrigerators
My westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
Nov 08, 2009 | Westinghouse Refrigerators
Where abouts is the thermostat inside the fridge there are white and yellow wires that go to either side of the fridge and the yeallow ones are broken what are these wires for it is a kelvinator C375vm
It sounds like you have a cyclic defrost fridge,Kelvinators were originally fitted with heat assist thermostats,so in order for the fridge to come back on a yellow wire heater was run around the cooling evaporator in the fridge compartment start running again at approx +4C so when the element fused the fridge did not start again until approx +12C.So instead of replacing heater a different thermo was used that came back on at +4c deg regardless.Kind Regards.
Jul 09, 2009 | Refrigerators
Apr 23, 2009 | Refrigerators
Westinghouse 410l fridge trips new RCD's in fusebox
Tripping an earth leakage would indicate a break down of insulation in the windings of the compressor, the possibility of a short circuit in the wiring system or the defrost element down to earth. I recommend you have a certified technician check it out before you have a fire. If the Hoover is in good condition there is no reason not to replace it. Rate me please.
Mar 11, 2009 | Refrigerators
Noisy fan in fridge
most likely to be a buildup of ice around the fan
Dec 08, 2007 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
