Xerox Workstation 6132 is giving a repetitive "paper jam" error message even though there is no paper jam. What is the most likely cause of this particular problem?
A Xerox Workstation 6132 is giving a repetitive "paper jam" error message even though there is no paper jam. What is the most likely cause of this particular problem?
    Filmmaker:
    Uploaded 5 video answers.
  • 30 Answers
Fuji Xerox cm205fw keep getting paper jam message
Just for any others with this question, I have been plagued with the same problem with my CP205 and CM205 printers, and discovered with the CM205 that it does still have a small scrap of paper left in the end of the paper path, near where it ejects. This can't be seen if you are looking inside the printer from the back door, hence anyone thinks it's clear, but if you open the main top door, by lifting up the control panel, and shine a torch down there, that's where you will probably find the small scrap of paper, which is stoping the printer from working. I managed to remove mine with a set of small tweezers. It would help if the machine could give you a more accurate error message, eg, lift the TOP door and remove paper jam.
Cheers, Vaughan
Jun 25, 2012 | Xerox Office Equipment & Supplies
We keep getting the message that the document feeder is jammed but there is nothing in there and as soon as you put even one piece of paper in the error message pops up. Is there an easy fix?
Hey, if you're getting the Jam at Document feeder error even though there is no paper jam. First try turning the machine off and back on, if the problem continues you most likely need to replace the DADF assembly (document feeder) part# 004K07270. The part is a little expensive, but you can buy it as an exchange for your bad one from iteminc.com to save you money. Replacing the part is pretty simple, here is a video that shows you how.
Jul 04, 2011 | Xerox WorkCentre C2424DN All-In-One Laser...
Illusionary Paper Jam;-(
yes first u open all cover of your printer carefully.than u clean all sensor of printer,,if there r dust in sensor than its give error msg,
Apr 14, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Paper jam 11
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Nov 07, 2008 | Copystar CS-1815 Printer
Xerox 5837 with 08-310 Error
If you donot find paper in the machine check for a stuck actuator or a bad sensor.
Jun 03, 2008 | Xerox 5830 Copier
Paper jam
There are several things that can cause a paper jam error, even though there is no paper stuck. The most common is that the paper pickup rollers are worn or dirty, and can't grab paper. Even though there is no paper jammed in the machine, it will show the error message. The solution is to clean the roller with alcohol and a lint-free cloth (don't use paper towels). If the roller is very worn, you will need to replace it.
Feb 04, 2007 | Canon Image Runner 1630 Copier Copier
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
