Will the 3v battery cause my screen to go blank on my cctv cnm H264 4 channel if it needs replacing
  • 790 Answers
No the 3Volt battery is a CMOS battery for keeping data and setting.
example: Boot sequence, time, password ect.
Posted on Apr 09, 2014
How do i re set my qvis cctv system
Open the case. There is a button cell inside. Remove that for about 12 hours with the CCTV disconnected from the mains. The password should be reset.
Feb 20, 2015 | Sharp Qvis Apollo Hd 16 Channel Security...
I've got a problem with my cctv cnm 160GB H 264 4 channel DVR I have 3 cameras set up on it and 1 of the cameras have stop working I've checked all power and cables and they are all working fine the...
Remove all the cameras then reboot. If it boots up normally then shut down dvr and add a camera and repeat. If it doesn't solve the problem, the issue is probably a video card or motherboard issue and will need to be repaired or replaced.
Mar 20, 2014 | Televison & Video
Cnb dvr password reset
Welcome To CNB Technology.
www.cnbtec.com/en/html/support/faq.php?classify=B
Ex-factory ID and Password. Ex-factory ID and ... When running DVR program, an error message comes up and the program stops. Check if the driver is installed ...
CNB DVR hard drive failure/password reset - • CCTV Forum
www.cctvforum.com/viewtopic.php?f=3&t=45061
Mar 2, 2015 - 11 posts
Hello all, I purchased/had installed for my home a camera security system using theCNB HDE2424DV and Nuvico dome cameras. It has 8 ... CNM Secure Primus (8ch) password
Feb 13, 2013
Is Q-See Equipment any good?
May 1, 2012
CnM Secure 4 Channel H.264 DVR
May 5, 2011
I need help selecting a DVR
Jan 18, 2010
More results from www.cctvforum.com
Feb 14, 2014 | Home Security
RESET A PASSWORD ON A CLOVER SECURITY SYSYTEM
remove motherboard battery 5 minutes ... reinstall ... causes checksum reset ... default passcode for most is 11111111 eight ones ... done ... enjoy!
Oct 02, 2013 | Clover Corporation Clover 17" CCTV...
I have a rapport 337. It won't work with the batteries it tries but screen goes blank. It works fine if it is plugged into the wall. Any help with this would be appreciated. than you
Production of this tester has been discontinued by the manufacturer.
I read a review of this tester, and that person cautioned on the tool's short battery life. He said you need to use high capacity NiMH batteries. He says he's lucky to get an hour of life out of a freshly charged set. Furthermore, the tool does not like to even power up if there is less than a 3/4 charge left of the batteries. He recommended removing the batteries when done using the tool and placing them in a smart charger until needed again. ALL NiMH batteries self discharge even when not in use. You should always have and install freshly charged batteries when you need to use the tool.
If the batteries are old (had many recharge cycles) or were not charged in a smart charger the useful life may have become significantly reduced and in need of replacement.
Mar 05, 2012 | RTO Wonwoo Rapport337 Professional CCTV...
Hi.. I have Rapport 337, I got problem screen on it, the screen is blank like no power but other functions work normally. I don't have idea why the blank screen occur because two days before we...
I have also RAPPORT337 with the same problem mention above about black screen.Since i am a TV technician, I tried to open it and check and I notice that there's no voltage supply on the screen. I found the regulator 7805 has no voltage input, what I did is looking for temporary input 12v, connect to the input of 7805 and it has a screen light. I was used it normally by using 12v AC adapter, BUT if I used DC battery, again it return to black. NOW, since the manufacturer is using 3layer circuit board, this is very hard trouble for us to look the exact location of the problem.I urged the manufacturer to send us complete diagram for this unit so that we can help other people to solve this problems.Send it to my e-mail address: primester_25@yahoo.com.
Sep 18, 2011 | ACT Rapport 337 - CCTV Multifunction...
My tv is giving me the 10 blink issue. Can I buy an ABoard online and replace it myself or do I need to know how to solder?
found this tonight:
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Dec 12, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
No picture on my tv from cctv camera
it is neither clear what sort of output your cctv cameras produce, nor what sort of input your dvr accepts. but, for the most part, dvrs record digital tv signals, whereas cctv cameras output analogue signals. so, even though you may be able to plug a cctv camera "straight" into a tv via a scart connector, it is unlikely that any scart connectors on a dvr have the necessary circuitry to accept such signals.
May 24, 2009 | Sharp Cameras
Trying to locate a service/user manual for the motherboard
Remove the onboard battery out for about 30 minutes, this will cause the bios to go back to the default settings!
Or look on the board for CMOS RAM clear.
Pins 1 & 2 are normal mode and pins 2 & 3 will Clear the BIOS.
Here is some info from Compaq.
Mar 15, 2009 | Compaq Presario S4000NX (DF213AR) PC...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
