Question about Mr. Coffee Coffee Makers & Espresso Machines
I was cleaning the coffee maker. The next day the lights wouldn't turn on, so I think water got inside it. But now it's working. Is it ok to plug it in unattended or could it short?
I cleaned the coffee maker and transported it to another house. The next day the lights wouldn't come on, so I figured water got inside, so I left it to dry for several hours. Then it started working just fine. My concern is plugging it in unattended. Is this safe even though water was inside the electronical parts?
  • 4 Answers
Dry it well. Then it *should* be fine.
You might put the cm with a desiccant, like microwaved rice or those little moisture boxes that come in pill bottles. Leave it for a day or so to soak up any remaining moisture.
The lights/controls of the cm actually run at a low wattage; a malfunction there should not be dangerous unless something causes the heating elements to come on. They are built to be okay if they're on with no water/dry pot, so as long as the cm is away from anything flammable--standard procedure for a cm anyway--it shod be fine even if it turns itself on.
Another option, and the one I recommend, is to go buy a new cm. You should not have to worry about the antics of your small appliances. A new cm will be cheap--and safe--and would set your mind at ease.
Posted on Mar 24, 2014
Junoon007
  • 1011 Answers
SOURCE: Coffee maker not working
Dear Sir/madam,
Please contact our Customer Service department at 1-866-901-BREW (2739) to make service arrangements.
and Try also
PREPARE
Step 1: Make sure you have 48 ounces of white vinegar on hand. You will also need an empty sink and a ceramic mug (do not use a paper cup.)
Step 2: Empty the water in the Water Reservoir b. FILL AND CLEAN
Step 1: Pour the vinegar into the Water Reservoir and fill it to the top edge of the clear viewing area.
Step 2: Place a ceramic cup in the Drip Tray and run a brew cycle. DO NOT USE A K-CUP…just press the Large Cup Button. Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the Water Reservoir is empty, pouring the contents of the cup into the sink after each cycle. Remember to open and close the lid between each cycle.
Step 4: Now fill reservoir with fresh water and let the Brewer stand for 4 hours while still on.
Step 5: Rinse the Water Reservoir thoroughly and fill with fresh water. c. RINSE Step 1: Ensure the Water Reservoir is filled with fresh water.
Step 2: Place a ceramic cup on the Drip Tray and run a regular brew cycle. Pour the contents of the cup into the sink.
Step 3: Repeat the brew process until the Water Reservoir is empty. Step 4: You may need to perform additional brew cycles if you notice any residual taste.
Regular cleaning (de-scaling) will prolong the life of the appliance. Scale is harmless, but left unattended, it can hinder optimal Brewer performance. De-scaling your Brewer regularly helps maintain the heating element, water reservoir and other parts of the Brewer that come in contact with water. Better water quality and water heating means a better cup of coffee. We recommend de-scaling your Brewer at least every 6 months (every three months if you are using hard water). The descaling process involves using 48 ounces of undiluted white vinegar.
Regular cleaning of the Brewer’s external components is recommended for proper operation. We recommend cleaning with a soapy, damp non-abrasive cloth. The K-Cup holder and funnel, drip plate, drip tray and removable water reservoir (on the Elite B40, Special Edition B60, and Platinum B70) are dishwasher safe. NOTE: the removable lid of the water reservoir is NOT dishwasher safe. The brewer should be descaled every 3-6 months.
Check out the Link for more information:
http://www.keurig.com/
faq.asp?mscsid=J5HAXXHH0GNG9LXP576CPCG47B500439#brewer9
Don't forget to rate the solution
Thanks
Posted on Apr 01, 2008
skrbin
  • 121 Answers
SOURCE: Sunbeam 10 cup coffee maker starts and stops brewing spuradically
check water heater
Posted on Feb 16, 2009
SOURCE: standby light is flashing
I had the same problem with my machine and managed to get it working again in a few easy steps. This machine is great but it can be VERY tempermental so here are a few tips:
1.The barcode reader MUST be clean or it will not read what the disc is (It is the little glass screen where you place the disk.) If it is not clean the lights will all flash.
2. The little floaty thing in the water container has to be floating in order to keep the machine running- if it won't float, shake it well to dislodge the air pocket that might be jambing it.
3. If the red stanby light won't go away, it is because the disc you are using is either damaged or leaking and it WON'T go away until you replace the disc...(you might have to do it more then once) if that doesn't work- try hitting the reset button on the back of the machine (the little black switch that has a (- and o) as well as unplugging and plugging the machine back in. Lastly, what worked for me was inserting a new disk and only partially clicking in the disk so the 'heating' light came on- leave it like that for about 10 seconds and then very slowly close the disc completely. Hope this helped!
Posted on Feb 25, 2009
  • 85 Answers
SOURCE: The red cleaning light on my cuisinart coffee
Hello sandra_strat,
There are two possible issues, but easy to do. When decalcifying your unit the solution should be 2 parts water and 1 part vinegar. So if you have a 12 cup maker it would be 8 cups water and 4 cups vinegar. Complete the process with a pot or two of fresh water to rinse. Second, there may be a water filter stick that is removable. Open the lid and look for it in one of the corners, pull it out and remove the carbon filter there. (You can get a new on Amazon). Then replace the stick.
I hope this is a help for you. If it is please leave positive feedback for me. Thanks! NormanZ
Posted on Jul 14, 2009
  • 7 Answers
SOURCE: barely any coffee rises to upper chamber after cooking
It's the gasket!!!!! Store the pot with the two parts screwed TIGHTLY together for about a week. Tighten it up as the new gasket compresses. Problem solved in two weeks or less. Also cook on medium to low heat. High flame seems to make the problem worse.
Posted on Sep 12, 2009
Doesn't work, just beeps
press and hold the power button, that should reset the unit.
Oct 02, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
The coffee grounds lihgt and the descale light flash after I push the brew button on my seaco odea giro.
The sensor inside the water container has either mineral build-up (scale) or a bit of coffee grounds stuck to it.
  1. Run a cycle with a retail coffee maker "cleaner solution" to clean the water reservoir, or let vinegar soak inside 5+ hrs.
  2. In both cases, turn unit upside down and power wash reservoir 2X to dislodge deposits that have loosened during the soak.
  3. Make sure to run a few cycles of plain water thru coffee maker before making the next batch of coffee.
Dec 06, 2015 | Saeco ODEA Coffee Makers & Espresso...
Water light not going out, even when full. Not able to make coffee
the water tank has a float inside, the float has a magnet. the machine senses the position of the magnet and indicates water ok/not. sometimes the magnet rusts inside the plastic casing, renders it less magnetic so it wont work. or the float is missing- fell out while you were cleaning the tank. you will need a new magnetic float to fix the problem.
Feb 11, 2014 | Saeco Incanto Classic Espresso Machine
Coffee maker turns on but will not brew
why question to all of this is with a "self clean" button, why doesn't it every tell you to clean it..... ??
Sep 07, 2012 | Cuisinart DCC-1200 Coffee Maker
My Keurig will not turn on...no lights flashing, nothing...I used it two days ago and it was fine...i came back into work and it wouldn't do anything. I tried unplugging it and leaving it unplugged and...
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Sep 15, 2011 | Keurig Elite B40 Coffee Maker
Just bought the a new Bunn VPR with two heaters for work. Should the unit be unplugged at night? If it is unplugged, how long the next day will it take to brew a pot. Is it safe to leave the unit...
That is one of the best coffee makers ever.It will last for a long time.Yes it is ok to leave it unplugged.Do not ever leave an empty pot on a burner that is on.Once a month,put 1 cup of white vinegar where the water goes,and run the machine.This will clean the inside.After you use the vinegar,run one pot of clean water through the machine.
May 13, 2011 | Bunn VPR Coffee Maker
Coffee not brewing after grinding
After grinding did you hear the brew group goes up and pump start? If you hear the pump start and stopped, itis blockage in the brewunit metal screen. Just needs cleaning.
If you don't hear the pump starting, the problem is with the faulty micro switch inside the gearbox , that is behind the plate of brewunit.(service center job)
Apr 14, 2010 | Saeco Odea Giro Plus Coffee Maker
Dcc-1200 not working
Probably dead, but:
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
Nov 10, 2008 | Cuisinart DCC-1200 Coffee Maker
Coffee Makers & Espresso Machines Logo
135 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
