Question about Sony Video Game Consoles & Games
Adamawww xxxx com
Mali segou
Xbox 360 update fail(from madden 12 disc).. status code : xxxx-xxxx-xxxx-xxxx-C000-003A .
If your system is moddefied with a customer firmware then you must update your customer firmware first and then insert your madden disk.
If your system is not modded then you must finish your update manually with a USB and downloading your update through xbox.com/support
Thanks
www.1RepairStop.com
Sep 08, 2011 | Microsoft Xbox 360 Console
Samsung 710v ima problem zamjenjeni kondenzatori i
Kondenzatori moraju imat mali parazitni induktivitet inace nevaljaju , provjeri mali kondenzator u ispravljaču ( on daje snagu ispravljaču ) provjeri diodu i kondenzator u zaštiti u primaru ispravljača ,
Feb 16, 2010 | Samsung 710V 17" LCD Monitor
I lose registration
From the run command in windows
click Start
Select Run from the menu
The Run window opens.
Enter "regedit" in the text field and click the OK.
The Registry Editor opens.
the serial number is on the left side in the navigation area.
Follow the path
HKEY_LOCAL_MACHINE\SOFTWARE\Nport\Installation\***\***\Info
the serial number is next to the "Serial*" entry. Looks like this:
1K2x-xxxx-xxxx-xxxx-xxxx-xxxx-xxxx or
2K2x-xxxx-xxxx-xxxx-xxxx-xxxx-xxxx
*** text may vary
Nov 28, 2009 | Xitel INport Deluxe
Show the serial number of nero 8
If you have a PC: Go to Start, then Run. The run window opens. Type regedit into the text field and click ok. The registry editor opens. Look to the left.
HKEY_LOCAL_MACHINE\SOFTWARE\Nero\Installation\Families\Nero 8\Info
• Your serial number is displayed next to the "Serial8" entry. It is structured as follows:
Write down your serial number
If your copy is registered with Nero, you can go
login to the Nero website to get your SN:
https://register.nero.com/eng/login.asp
Nov 17, 2009 | Ahead Software 8 Ultra Windows
How do you setup the IP address on a toshiba tec b sx4t printer?
In diag mode (pause and feed key depressed switch on )
go to ip adress and change the value or use the instructions
{IP;2,xxxx,xxxx,xxxx,xxxx'} for the ip
{IP;3,xxxx,xxxx,xxxx,xxxx'} gateway
{IP;4,xxxx,xxxx,xxxx,xxxx'} subnet mask
socket port
{IS;1,09100'} for socket number and activation
{IS;0,09100'} for deactivation
Sep 30, 2009 | Toshiba TEC B SX4T Printer
How can i get my nokia 5220 to work as a webcam
puedes usar el: Mobiola Web Cam For XXXX (XXXX es el modelo del telefono)
saludos compañeros, desde uruguay
x.lautaro@hotmail.com (software an web design)
you can use: Mobiola Web Cam For XXXX (XXXX is the model)
Jul 02, 2009 | Nokia 5220 XpressMusic Cellular Phone
I need a bios password and a one time password so Ican get into the bios
Hello, I can unlock ANY  SONY VAIO bios password (PCG AND VGN MODELS). If anyone have questions feel free to visit www.laptoprebirth.com or send an emailto conradodav@hotmail.com WE SUPPOR OTHER BRANDS LIKE ACER HP COMPAQ TOSHIBA ASUS GATEWAY DELL FUJITSU SIEMENS SAMSUNG
I can also unlock one time password with 16 digit error code:
xxxx-xxxx-xxxx-xxxx
May 10, 2009 | Sony VAIO VGN-FZ470E/B Laptop
When i try to play a and b speakers it says low impedence ??????
I just saw in the title that you're getting a Low Impedance indicator on the receiver...
Following what I said earlier, when you have multiple sets of speakers selected they connect in parallel, effectively presenting a lower impedance than either pair does alone. If your receiver is warning you of Low Impedance you could
A) Ignore it if it doesn't have any audible effects; or
B) Avoid the issue by not running the speakers together or
C) If you must have them running together, wire them in series with each other to present a higher load to the amp and connect each pair of series speakers to the A or B terminals. It would look like this...
spkr A spkr B
XXXX XXXX
L ++++++++XXXX++++++++XXXX
L --------------- XXXX--------------- XXXX
XXXX XXXX
XXXX XXXX
R ++++++++XXXX++++++++XXXX
R --------------- XXXX--------------- XXXX
XXXX XXXX
Apr 02, 2009 | Technics SA-DX950 Receiver
Video Game Consoles & Games Logo
472 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
