Question about Dell Inspiron Mini 1018 Netbook
Hi i bought a dell mini inspiron 1018 and it wont power up. i have tried to remove the battery and press the start botton for 15 second and still the screen seen blank and there is know bleep or HD ru
I also bought a new battery as i was thinking its battery problem. please its there anything else i can do to fix the problem
    New Friend:
    Problem Solver:
  • 5 Answers
If it's connected to a power socket & still the problem persists , the problem is probably with the power supply located in your laptop.
Posted on Mar 20, 2014
Pyrhyc
  • 2028 Answers
SOURCE: Dell Inspiron 5160 Black screen on power up
There is a small board that the power button is integrated into that connects to the motherboard. When this power board malfunctions it will cause this issue with the machine. It can, and quite often does, damage the motherboard when it malfinctions. You should take the machine in for a power board replacement and a diagnostic to make sure that the power board hasn't damaged the motherboard.
Posted on Jul 15, 2008
ArmenianTech
  • 24 Answers
SOURCE: How do I remove the CMOS battery on a Dell
You need to remove keyboard first, and cmos battery is right under it if I'm not mistaken.
Black screen issue I believe is related to video card. Anyways try to update bios too.
Posted on Oct 11, 2009
benwabnick
  • 2404 Answers
SOURCE: dell inspiron 1545 won't boot turn on start up
Unseat and reseat the memory in the laptop one stick at a time in each slot one at a time. Turn on the laptop after each reseat of memory.
If that doesn't work then take out the hard drive and then the dvd drive.
Turn the laptop on again and if you still can't get video on the screen then the motherboard is defective and would need to be replaced.
Posted on Nov 30, 2009
  • 4 Answers
SOURCE: Inspiron 1525..black screen. The screen is black
or screen probably is burned...
or inside crystals are broken..
u have to buy a new laptop
Posted on Apr 11, 2010
  • 4 Answers
SOURCE: dell laptop screen goes blank when ac adapter plugged in
I believe I have found the problem with the 1525 that I am currently working on which has the same problem that you describe. Ultimately I think it's a problem with the inverter in the LCD. When the laptop is powered by battery the brightness is lower than full. When I plug in the power adapter the brightness goes to "full" and I hear a faint sizzle and the LCD's backlight goes off. Same as if you hold the Fn key and press the up arrow to brighten it, it will do the same thing when you reach near the full brightness. So for now I have fixed this problem by going in the Power Options and clicked on Adjust the display brightness on the left. Slide the slider to the left on the "plugged in" part and now when you plug it in it shouldn't make it go blank. I do want to note that I hear a faint buzz coming from the LCD when I plug it in. That must mean the inverter is faulty. WAY TO GO DELL!!!!!!
Posted on Jul 24, 2010
Dell inspiron Mini 1018 wont turn on, power
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problemis with the memory or Video Card. Count the Blinking Lights or Beeps and takenote of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.Maybe your memory is bad or the memory slot is bad.Remove the Power Cord, Remove the battery, remove the cover that houses the memory then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
May 11, 2012 | Dell Inspiron Mini 1018 Netbook
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Mar 25, 2012 | Dell Inspiron Mini Netbooks
My dell inspiron mini 10 wont power up at all with charger and only gives me a brief white light when battery and charger are plugged in. Any suggestions
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps you.
Feb 25, 2011 | Dell Inspiron Mini 10 Notebook
My Dell Inspiron 1545 PC notebook will not load to the WIndows screen. Once booted it just sits on a black screen with a moveable cursor. What can I do to stop this? thanks
Hi pebrouss,
Have you tried power drain? The easiest way to resolve this type of issue is by performing a power drain. Here's how you will do it.
1. First, turn off the unit completely. You may try pressing the power button for about 15-20 seconds.
2. Remove the unit from the power outlet.
3. Take out the battery from the system.
4. Press the power button for about 15-20 seconds.
5. Put back the battery and plug the unit to the power outlet.
6. Turn on the system and observe it.
Hope it helps.
Thank you for using FixYa.
Feb 22, 2011 | Dell Inspiron 1545 Notebook
My Dell inspiron mini 10 is just over 1 year old not used very much at all, last week for no reason there is no display on the screen, I tried to reboot on battery power and ac no luck. Thanks Frank.
There are 3 mini 10 models sold by Dell. The Inspiron 1010 (Mini 10), Insprion 1012 (Mini 10) and the Insprion 1018 (Mini 10v). Depending on which model you have, you can try to connect an external monitor and see if you get a display. The 1012 and the 1018 have a 15 pin VGA plug on the left side of the laptop and the 1010 has an HDMI jack for video. If you get a display then your LCD display is bad and needs to be replaced.
Feb 07, 2011 | Dell Inspiron Mini 10 Notebook
My Dell 1300 Inspiron Notebook will not start up, it gets to two green lights but won't go to Four. I cannot get it to start in Safe mode, it will not recognize the command. It does recognize F2 and F12....
Hi petergreenus,
Have you tried draining the power of your system? Please follow the steps below on how to power drain your computer.
1. Turn off the computer.
2. Unplug the power cable from the outlet and remove the battery.
3. Now, press the power button for about 15-20 seconds.
4. Put back the battery in and plug the AC adapter.
5. Press the power button and try to observe the system.
Hope it helps.
Dec 04, 2010 | Dell Inspiron 1300 Notebook
My dell mini 10 wont start. When I press the start button the white power light comes on and then switches off in a but 2 seconds. The screen doesn't come a live at all. HELP!!!
You will need to see if there is problem in the bios back up battery or the memory.If on start up you cannot go to bios settings you must consult Dell support centre.
Sep 30, 2010 | Dell Inspiron Mini 10 Notebook
My dell inspiron mini 10 won't boot.There is just this annoying sound that wont stop.
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else. I've removed the battery and unplugged the unit and put it back together and it still does the same thing. HELP!
Apr 21, 2010 | Dell Inspiron Mini 10 Notebook
Dell Mini 10 Won't turn on. When I press the
try to power drain pc first. to do that, turn pc off, remove battery and ac adapter. press down power button for 15-20 sec, then but all back in and try to turn pc on. if still no go, you may need to replace battery or ac adapter, f it still wont work, possible motherboard replacement is needed.
Mar 29, 2010 | Dell Inspiron Mini 10 Notebook
Dell Inspiron Mini 1018 Netbook Logo
65 people viewed this question
Alun Cox
