Question about aFe 2006 Toyota 4Runner - 4.0L V6 - Silver Bullet Throttle Body Spacers
2003 Toyota 4runner v6 throttle body - aFe 2006 Toyota 4Runner - 4.0L V6 - Silver Bullet Throttle Body Spacers
  • 3 Answers
Throttle body spacers won't help on fuel injected engines like the 4Runner.
Posted on Jun 01, 2014
Replacing throttle sensor
no. not normally, unless the bushings the shaft rides on are completely shot. remove the sensor and wiggle the shaft.... feels tight then its good
Mar 25, 2014 | 1988 Toyota 4Runner
1991 toyota 4runer MAF mass air flow sensor location
Should be between air filter and throttle body.in black tube.
Feb 19, 2013 | 1992 Toyota 4Runner
How do i replace the left passenger door lock actuator on my 2006 4Runner? Is there a manual or video or step by step guide? Thank you, Jason
There are repair manuals by Toyota which are very well done.
Call: Toyota Service Publications: (800)622-2033
Item P/N Price
Vol. 1 (Diagnostic & Troubleshooting) RM1001U1 $103.13
Vol. 2 (Engine, Body & Chassis) RM1001U2 $103.13
Electrical Manual EWD514U $67.50
V6 Supplement RM1034 $8?.??
If you've got the V6 you need the "V6 Supplement" which is eighty something dollars more.
Interestingly, the owners manual (that covers both the V6 & V8) says nothing about the Electrical manual but does point out the V6 supplement (without mentioning that it's a V6 supplent only).
Sep 06, 2011 | 2006 Toyota 4Runner
The accelerator cable on my 94 toyota 4 runner SR5 v6 is frayed. How do you install a new one?
disconnect cable connection at throttle body by loosening retaining nut and removing cable from attachment. follow cable to firewall and disconnect cable from fire wall a rubber grommet may need to be removed with a flat blade screwdriver and gentle pressure. under dashboard, at top of gas pedal,cable is attached by clip,disconnect. and pull cable through and into vehicle. reasembly is reverse. when connecting to throttle assembly make sure there is about one quarter inch slack in cable.
Jun 07, 2010 | 1994 Toyota 4Runner
2001 Toyota 4runner idle rpm is too low
Hi Seanmcm21,
More than likely the low idle you are experiencing is caused by a dirty IAC valve located right under the throttle body itself. It needs to be cleaned out with carb cleaner. Remove the electrical connector, the two vacuum hoses, and two screws. To put it back, use a little sealant to seal it before screwing it back together but do not get the sealant inside the IAC valve. If this 4 Runner is a V6, you may need to replace the spark plugs if old. Make sure to purchase twin electrode NGK or Denso spark plugs and gap them to .043 with a gapper.
Jan 12, 2010 | 2001 Toyota 4Runner
4runner will not idle
check your air idle control valve on the throttle body.
May 11, 2009 | 1994 Toyota 4Runner
1993 toyota 4runner idle too high problem
check the various throttle controlls. there should be a grey box with an unusual nut on it. have a car guy look it over. the vehicle will have a cold-start high idle for a few minutes before selling down if it's a V6.
Mar 12, 2009 | 1993 Toyota 4Runner
2003 Toyota 4runner dies/won't start
CHECK FUSE FOR START ASSIST RELAY
Nov 24, 2008 | 2003 Toyota 4Runner
My 2003 Toyota Camry is Stalling when I attempt to start it and at low speeds
If V6 camry, remove air duct on the throttle body and spray solvent (carby/ throttle body cleaner) down the opening just before the actuall throttle blade, be generous
Jul 20, 2008 | 2000 Toyota Camry
aFe 2006 Toyota 4Runner - 4.0L V6 - Silver Bullet Throttle Body Spacers Logo
604 people viewed this question
Top aFe Renewable Energy Experts
Marco De La Fuente...
Brian Lee
Kelly C
Kelly C
Level 1 Expert
Are you an aFe Renewable Energy Expert? Answer questions, earn points and help others
