Question about Yamaha Audio Players & Recorders
Piano doesn't make any sound. it worked perfect before. it's plugged in, light comes up when i switch it on but nothing else. did try to change volume and press pedal, still nothing. also have turned it off and on again, nothing. would appreciate any help. thanks
  • 4 Answers
Have you tried headphones to see if the sound is even generated.
An easy cheap soloution if this works is to possiblt use exernal speakers in the aux jack.
Posted on Mar 20, 2014
4 Suggested Answers
Cory5468
  • 125 Answers
SOURCE: RCA Lyra with no sound
Try getting a new headphone jack or try getting new headphones.
Posted on Jun 27, 2008
  • 8 Answers
SOURCE: Creative Zen Vision M 30GB wont turn on
Problem could be the combination of a bug that causes the device to freeze and the battery running out. If...
- the player won't turn on
- the player won't connect to PC
- the standard reset action won't work,
plugging the player in the AC charger may pull up the recovery screen which will allow you to proceed and reboot, provided the player has no other eg hardware issues.
Posted on Aug 20, 2009
carrese04
  • 92 Answers
SOURCE: My 2nd gen shuffle won't play. The green light
try another headset, maybe there is something wrong with your headset
Posted on Jan 10, 2010
Why do I get no sound from either speakers or headphone jack?
Check that the local control is ON
It is set via the function switch
Dec 09, 2015 | Yamaha DGX 530 Keyboard, 88 Full Sized...
Need repairs on Technics SX-PX103-M Model.
Have you had any luck with your Technics piano? I've got the same piano and Mine does not work either. No lights on the control panel, only red power light comes on. Does yours have any led lights besides the power light that come on? I've investigated and I have learned a lot from this piano. 4 main boards. Im pretty sure I've got it down to one board. Interested in selling me any boards from your Piano??
Jan 19, 2012 | Music
I plug in to AC charge for the whole day and try to turnon, with switch on the right hand side, nothing happened
On the occasion it won't chrage the PSP. You should double check that it is charging it. Also, try to see if it'll turn on while plugged in. If it turns on, let it charge, if it doesn't either the battery is shot or the plug-in spot is broken or not responsive.
Sep 12, 2011 | Sony PSP (Piano Black)
My Privia PX-3 will run fine for about an hour. After that, for example, if I am playing a piano sound and want to switch to organ, I press the organ button and the LED shows that I have chosen the organ...
This problem is NOT DIY and will likely require a trip to the repair shop... One possibility is a static discharge... Try running it for hours with no clothes on that can produce a static buildup and see if it behaves. If so, take maeasures against static... no rubber soled shoes, no wool fabrics, gound yourself to something else before touching the unit...
Aug 16, 2011 | Casio PX3 Privia 88Key Digital Stage Piano
The light unit on my fish tank will not come on ive tried chaging the bulbs but still nothing happens
Hi, First try the light on a different plug. If that doesn't work the switch is the problem. Be careful not to drop light in fish tank. (electic shock)
Jun 17, 2011 | Vacuums
Hi, I hope can help me with this problem because I start to get desperate. I have a Clavinova CVP-85A. The sustain effect is always activated, whether the pedals are plugged in or not. I read that to...
It sounds like the inputs from the pedal switches are "floating", that is, not pulled up or down and they are drifting across the logic threshold. If I could find a schematic I could direct you right to the problem. For now, check the voltage across the switch contacts with a high impedance meter. Also check the resistance to ground of the common of the contacts. Without a schematic I am afraid to have you try things lest I direct you to do something that would cause damage.
Jun 07, 2011 | Yamaha Music
My driver side window wasn't working so i replaced the switch but the driver side window still wont go down. Any info on how to repair my problem, thinking its the motor but can't find any videos...
remove your door panel, disconnect the motor plug, grab your car battery with 2 cables one in each terminal and connect them on the motor plug, one cable in each pin, be careful that the cables don´t touch each other. The polarity doesn't matter, cause if you change them they are going up or they will go down ok. If the window it's up and it doesn't move change the polarity and it should go down. If it works then it could be the switch or something electrical from the plug to the switch. If it does nothing then it´s probably that the window motor doesn't work anymore and you should cange the whole mecanism.
May 14, 2011 | 1985 Buick Regal
No sound in my yamaha clavinova cvp 85a electric piano
Ok i hear ya my mother had a clavanova one and i really wonder why the people dont service them at the home. I would check to see if they have a service person within days travel and evaluate the cost. I would way it between the effort to move it and the cost for their visit.the electronics on the keyboard are very complex and i would hate advising someone to do more damage.
Oct 12, 2009 | Computers & Internet
NO SOUND
You posted in the wrong section, you will need to repost.
May 11, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Open Questions:
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
