Question about Acer Computers & Internet
Acer m5-581tg Auto repair loop WIndows 8?
I cant seem to get past that auto repair screen on my Acer. Worst yet, I cant go into bios to change the boot settings to boot into an external media so I can repair it. It's just stuck at this silly auto repair loop. Whatever key combination I use it just doesnt want to either start the bios settings or the safe mode screeb. Whenever I do a hard reset(hold the power button until it stops and then start it again) it never shows me any boot screen it just goes into that loop immediately. I can fix the problem as long as I boot into BIOS but as I said it immediately goes into that loop after a hard reset. Any ideas on how to get to the boot menu ?
It could be a problem with hard drive, try replacing it with a spare hd , if its still the same then maybe you could take out internal battery and put it back in ,even take out mem and put back in at same time of taking out internal battery ,it could help resolving the problems.
Posted on Mar 20, 2014
  • huskos
    huskos Mar 21, 2014
    Those are great possible solutions, I was thinking of removing the battery, even resetting the CMOS. Problem is the laptop is under warranty and if I open it the warranty is voided. I was thinking of something not on the hardware side, but rather a possibility of doing a hard reset so I can boot from an external storage and fix the issue with an external tools. Anyway, thanks for the ideas
SOURCE: EEEPC Stuck in "did not start successfully" loop
I quote this from maddmike71 "ahhh, the infamous blue screen of death. not much you can really do but reinstall windows. if you have data you need you can remove the hard dive and attach it to another computer to copy the files if not take it to a pc shop so they can backup all of your data for you."
Posted on Aug 01, 2009
SOURCE: acer aspire 3000
my Acer aspire 3003WLM didn't see a 250GB HDD while installing WINXP. It can show 131GB only. Why?
What todo to fix the problem?
Posted on Oct 03, 2008
  • 38 Answers
SOURCE: acer 7720 will not boot
Do you want to try and see if a 'Linux LiveCD' boots? This is the way I test if the computer works. You burn this CD to a disk, and then boot off of it when you're computer starts. I will not modify anything on your computer as long as you go to 'Try Ubuntu with out installing'
http://www.ubuntu.com/getubuntu/download
Don't worry, I'm not trying to get you to install anything, just see if it boots into the 'live environment' (means you are running it off of the cd) If this works, that means that it is only your windows installation is messed up, and a reinstallation of windows should work fine with a Windows install CD NOT the recovery cd.
Posted on Jan 31, 2009
zohail
  • 1223 Answers
SOURCE: 7720 will not boot
off course it is repairable dont worry look try to install OS thru the following procedure to factory default state
Acer: When you first turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
if it installs the OS ok then fine if not
pls consider changing RAM take out from beneath the laptop open the cover all screws and take out the L shaped panel then u will see the RAM in front with 2 chips one uper and one lower side try to take out both and then re fit only one in the upper slot and then try to install if hangs again , then try the 2nd chip in the first slot and repeat the procedure if it works ok only try both chips one by one if it resolves ur issue and u find the faulty one replace it with new one with sam specs
in the last case if ur system still hangs then my friend ur hard disk is giving u hard time it needs replacement
when a system boots after bios loading all that is trf from Hdisk to RAM and then OS is loaded if one have problem system will hang or freeze try these solutions and then tell me the results
pls go step by step
and pls rate me fixya if i fixed ur problem
kindly let me know abt it and tell me in detail the messages u get and the system behaviour
Posted on Mar 02, 2009
SOURCE: acer aspire 5315 doesnt boot blank screen
When you power up the laptop press F1 or F2 or "del" key to enter in bios setup.
Then check your harddisk is detect or not?
Then also make sure SATA option is disabled in bios.
Then go to boot option and set first boot device as your harddrive.Then save settings and exit.
But if you even not able to enter in bios then you have reset bios settings and Refix RAM memory .
For that open back cover fo laptop and find cmos cell on motherbord pull it for 10 minutes so all settings of bios goes to factory defaults.
Let me know if you need more assistanse.
Thanks.
Posted on Sep 25, 2009
Auto repair loop on windows 8 samsung lap top
I would reinstall windows at this point. There seems to be a file missing or corrupt.
Oct 14, 2014 | Samsung Computers & Internet
There is missing system configuration option in acer AOD257 bios
Search for a recent update for your bios. You can also try a different bios all together. Google "Acer AOD257 BIOS Upgrade" and "Acer AOD257 compatible BIOS". I remember my old BIOS having very limited options available. The BIOS I use now has two pages of options. Hope I was able to help!
Jan 30, 2013 | Acer Aspire One D255-2670
Cant start acer 5920
Hi Dear,
Check the mention below instruction to solve you problem.
1. Is the boot sequence in BIOS set to boot from CD or DVD, if not I would suggest you to go to BIOS and change the boot sequence to boot from CD and try to boot from the CD
2. Is the computer custom built or OEM built?
3. What is the model number and who is the manufacturer of the computer?
4. Have you made any changes to the computer by installing any new software or hardware?
5. Since when are you unable to boot the computer normally?
6. You need to get Windows Vista DVD to perform further troubleshooting either to scan the computer or to perform repair install, I would suggest you to contact the computer manufacturer to obtain vista DVD.
Thanks
Sep 07, 2012 | Acer Aspire 5920-6423 Notebook
Acer Aspire M3400 Desktop PC. Memory Upgrade Issue
please check the memory timing settings. if your mixing up ram they may not have the same memory timings and require you to go either higher or to the supported settings that either memory can use. for example if corsair runs at 8-8-8-14 and kingston runs at 10-10-10-16 then you will need to bump the settings to 10-10-10-16 since the computer is trying to set the timings for kingston to 8-8-8-14 which it does not support.
Feb 18, 2012 | Acer Aspire M3400 PC Desktop
Acer 5102WLMi 4GB ram windows 7 Resource Conflict PCI in slot 03
I have the same fault in Exploration of the Toshiba laptop I thought that the problem in the BIOS I have to change the BIOS of the motherboard from another device is identical to him, but did not change the message. The device to restart the work or entering the BIOS. Does not enter the Hard disk or the CD-ROM or slots of the USPI. Found that the problem in the cache on the motherboard BIOS that is stored clothing and replied to her and when I unloaded as follows.
Remove the keyboard from the device you will be proud of card Remove the card below it you will notice two signs**88
When you close with some of these points and left it for 24 hours you run the laptop did not show the message again, but this may have eliminated the possibility of a password again from the BIOS as the storage room and place one empty one.
As for this model are points of discharge under the Ram, and marked with .. And be drawn into a small rectangle and the letter written by him j
Mar 06, 2010 | Acer Aspire 5100 Notebook
After installing windows security updates, i could not get windows vista to come up and i don't have a recovery disk from Acer for my Acer Aspire T180 PC Desktop.
I run into this all the time, thank you microsoft!
First, shut it down and take a break, make sure you power the computer completely down to a cold boot. Walk away for ten, fifteen minutes.
Then when you come back boot into your setup (bios) screen, to do this is different for each manufacturer, some require you to hit del, some F2, some F10... when you get there Change your boot order to anything other than what it currently is, and save it. Reboot. let windows try to start. if it does, great! If not, reboot and Go BACK to the setup screen and change your boot order BACK to what you NEED/WANT it to be and save again and reboot. This SHOULD take you back to a windows startup of either a repair or safe startup screen. DO NOT REPAIR! Boot normally. The updates lost a startup configuration that is written INTERNALLY to windows. Since you altered the hardware configuration by changing the boot sequence around, windows had to rewrite this and away you go. On a laptop it gets a bit more confusing as you have to do this without the battery in place or it will continually write the data to the hard drive under the laptops auto powerdown/save features that a desktop does not have. NOTE: if this does not work any other bios change other than clock/calander will force this dmi configuration change. but typically the boot sequence is the safest to alter, as you do not risk messing up critical setting with this one.
Feb 16, 2010 | Acer Aspire T180 PC Desktop
Acer Aspire One loops on start up screen. All it does is show the acer logo, then shows the ''windows was shut down improperly'' screen with all those options and then goes to the windows xp start up...
Try tapping F8 when the acer window shows, when it shows the muliboot option, scroll down to "Last Known Good Configuration" and hit enter. If it does not boot normally, you will have to get an external dvd drive and boot off the drive with a windows installation disc to perform a repair.
Jan 07, 2010 | Acer Aspire One PC Notebook
Acer Aspire 5720 Laptop problem. When turned on
Upon loading press F2 or del to enter bios setup and change the settings to display the acer welcome screen and the one you said about Microsoft logo and white box with green lines, you cant by pass it because it's windows loading screen
Dec 01, 2009 | Acer Aspire 5720-6661 Notebook PC
Windows doesn't load
Here's 2 things i would try:
1. Install the latest bios first:
click here
2. When you install the new card, go into the bios first and disable onboard graphics (seems like theres isn't an option for that unfortunately, but check again anyway) choose "auto" if you have no "disable" feature.
3. If you have another pc, or a friend with another pc i would test the card on a different pc just to make sure its not a faulty card.
Jan 17, 2008 | Jaton GeForce MX4000, (128 MB) PCI Graphic...
Computers & Internet Logo
101 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
