Acer v3-531 cant load and boot to windows 7 it was win 8 just restarts will not run. I have changed all the relevent bios setting and diabled all security in the bios and sett to legacy settings
    Master:
  • 397 Answers
At what stage is it failing to boot to Windows 7? Have you actually managed to boot off the installation CD/DVD or USB?
I suspect you haven't and that's the problem at a guess. You may need to disable "secure boot" in the BIOS. This prevent the system booting from other devices. Once disabled you should be able to boot from the installation DVD or USB. If you are using a DVD and have disable secure boot I would try installing from a USB drive. I have had this problem myself and the workaround was to install from USB.
If getting Windows 7 to install is not your problem, have tried starting the system in safe-mode?
Posted on Mar 20, 2014
How do I download windows 7 os on to a flash drive so that I can up load it onto my Dell laptop as it has a new drive
if you have the cd for win 7 , go to the bios and change the boot sequence from hard drive to 1st cd
save change
insert the cd
shut down then start again from there
the computer will select the cd unit and load the program from there onto the hard drive
when you have finished downloading all drivers from their relevant manufacturers web pages
close down and on opening get back to bios and change the boot sequence from cd back to hard drive as first option
Sep 04, 2017 | Dell Computers & Internet
What stage is it failing to boot to Windows 7? Have you actually managed to boot off the installation CD/DVD or USB?
Mar 20, 2014 | Computers & Internet
My acer aspire 1 725 wont load due to errorcode 0x00000f and cant get into bios to change boot options how do i fix this problem
Shut down your computer completely. Once it has been turned off, press the power button to the "On" position to restart the system. Within the first 10 seconds, press down and hold the F2 button for about three seconds and then release it. Within five to 10 seconds after pressing and holding this button, you should see the BIOS setup screen on the monitor.
Dec 30, 2013 | Acer Computers & Internet
Can asus k42f be ugraded to windows 8?
Windows 8 has updated drivers as much as you would get from Asus built into win 8.
Go to devise MGR, if windows 8 did not load drivers, you will see a flag.
See what hardware did not load a driver and then use the win 7 driver.
You don't do anything to make a win 7 driver work, if the driver is newer, and signed it will install, if it's older then the driver windows installed, it won't install. If you see a flag and windows did not install a driver, then try the win 7 driver, or go to the MFG of the hardware and see if there is a win 8 driver.
You can also run windows update, if win update see's a newer driver out it might pick it up and give you a install option.
Now, your chipset, and most hardware has windows 8 drivers out.
The drivers are the biggest problem, the biggest problem for you is the BIOS was not set for windows 8.
So you could find even with the best drivers, win 8 slower or has bugs more then win 7 will have.
Me, I would bench test all the hardware with win 7, then with win 8 and see which one is better.
Apr 08, 2013 | ASUS K42F A1 Notebook
Intel DQ965GF Motherboard won't load WIN OS (WINXPPro volume disk or Win7) tho an old Dell disk did load. Is there a fix? Thz
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+965+Express+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DQ965GF
Windows 7 is not a supported system, but you can use the drivers from the vista system, but only the 32 bit.
Turn on or restart your computer and watch for a message during the post about a particular key, usually Del or F2, that you'll need to press to ...enter SETUP. Press this key as soon as you see the message.
After the post, BIOS will attempt to boot from the first device listed in the boot order.You need to change that, so the first boot device in the list is the dvd drive. If that device is not bootable, BIOS will attempt to boot from the second device listed, and so on.
Note: The boot order is a BIOS setting so it's OS independent. In other words, it doesn't matter if you have Windows 7, Windows Vista, Windows XP, Linux, or any other PC operating system on your hard drive or other bootable device, these boot sequence change instructions will still apply.
Here is how you do this:
http://www.hiren.info/pages/bios-boot-cdrom
But ofcourse there could be a problem with the dvd drive or harddrive.
To install windows 7, you will need at least 1 gb ram or more, and a dual core cpu.
Best of luck
Feb 12, 2013 | Computers & Internet
Tried to update win 7 to win 8 but when loaded receive message OXOOOOOO5D nowcan,t start computer
windows 8 is far better than windows 7
To install Windows 8 on your PC, the processor (CPU) must support the following features: Physical Address Extension (PAE), NX, and SSE2. Most CPUs have support for these features, so if you receive this error, it is likely because the NX feature is not enabled on your system. To resolve this error, follow manufacturer guidelines to enable NX ("No eXecute bit"), or the equivalent XD ("eXecute Disabled"), feature within the BIOS settings. This feature is typically found in the Advanced or Security tabs within the BIOS settings, and can be referred to by a variety of names, including but not limited to: • No Execute Memory Protect • Execute Disabled Memory Protection • EDB (Execute Disabled Bit) • EVP (Enhanced Virus Protection) If the BIOS setting for the NX (XD, EDB, or EVP) support option is not available on your system, you may need to contact the manufacturer to update the BIOS. Note that some very old processors may not contain these features and will be incompatible with Windows 8 Release Candidate. A whitepaper has been published with further details about the PAE/NX/SSE2 requirement for Windows 8, error cases and scenarios that customers encounter when machines fail to meet the requirement, and what to do to install Windows 8 on their PC's. You can download the whitepaper at http://msdn.microsoft.com/en-us/library/windows/hardware/hh975398.aspx
Jan 18, 2013 | Computers & Internet
Will not recognize extra sata hard drive with win 7 lenovo running win 8
need to go to bios and do change settings. ive never done it with two hdd's i just partition and dual boot. os's were win 7 64 bit and win 8 64 bit.
Dec 14, 2012 | Seagate FreeAgent Computers & Internet
How do you install windows 7 on HP pavilian 754n? plz tell me quick because we just bought windows 7 and it doesnt work on the computer. thx you!
First you will need the Window 7 operating system cd.
place the cd in the cd room and let the auto run take place. this is not a quick process
it will take several minutes. If the operating system is not loading you may have a different problem
Jul 19, 2011 | HP Pavilion 754n PC Desktop
Trying to install ATI FireMV 2400 256mb pci-e card. I have a new pc with asus m4a78lt-m motherboard, athlon x4 645 3.1ghz processor, 3gb ram, windows 7 32 bit os, 500w psu Card installed in pcie x1...
First off all reset the bios to default setting and restart the system. After restarting the system please go to your bios in the graphics segment and select auto option for card selection.
once done save all setting connect your monitor cable to your monitor and restart the system.
hope this will solve your problem.
Apr 14, 2011 | ATI FireMV 2400 PCI Video Card
Cannot install Windows XP Professional on Acer Aspire 4720Z Laptop
yu need to go to the the bios before you start the installation and change the Sata hard disk mode to IDE.then it will detect the hard disk.
May 05, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
