Question about Cycling
How do I install the cable into my shimano xt shifter? They did not come with cables, so I need to use my old ones which are in great shape. I just don't want to take my new shifters apart and ruin them. Any help would be appreciated. Pictures would be great if you have any. Thanks -James
  • jabinafoed Jun 14, 2009
    I need help installing the cable in my new shimano XT shifters for my bike. I believe it requires me to open the shifter up. If you have any pictures available of how to exactly open up the shifter without it completely falling apart that would be great.
    -James
    how do I install the cable into my shimano xt shifter? They did not come with cables, so I need to use my old ones which are in great shape. I just don't want to take my new shifters apart and ruin them. Any help would be appreciated. Pictures would be great if you have any. Thanks -James
You normally only have to remove some panels and thread the cable through. See if this site has your one. This site has a video (advert plays first).
Posted on Jun 14, 2009
    Genius:
  • 1,847 Answers
1. Shift the right STI lever to the point where the chain is on the smallest cog.
2. Take the cable off the rear deraileur.
3. Cut the cable where it enters the front housing.
4. Pull off the front housing.
5. Grab the cable just outside the shifter.
6. Aply the brake sufficient to expose the cable end.
7. Push, twist, and otherwise attempt to remove the cable.
Let me know if that helped..
Thanks
K
  • 3,230 Answers
Please follow the below link -
http://www.mtbtrailreview.com/blog/maintenance/how-to-install-and-adjust-your-rear-derailleur/
Good Luck
Thankd
How to replace cable in vintage shimano XT Deore SL M740 rear shifter...there is no feed hole as with most other shifters
on some of the old stuff there was a small plastic plug screw, Phillips head, near where the shift levers enter the pod. Once that is removed and the shifter is in smallest cog position you will be able to sight through that access hole and see daylight and can fish the cable through it. Hope that helps.
Jan 26, 2014 | Shimano Deore Xt Thumb Shifters 7...
Ive a new rear deore unit cable and housing etc. where does the cable secure in the shifter unit? I can see a small metal arch but cant figure where the end of the cable actually fixes
Not a great picture but if you follow the arched groove back from the cable-housing guide it leads to a little hole. THAT is where you stick the cut end of the cable.
http://techdocs.shimano.com/techdocs/index.jsp
Accounting for physical differences, this should get you going.
http://www.parktool.com/blog/repair-help/shift-levers-shifters
Jun 21, 2011 | Shimano Deore Xt Thumb Shifters 7...
Shifters don't catch and move the cable
These are among the simplest design for shifter on the market. If the cable is taut it WILL pull. Perhaps the cable is broken, grossly loose or rusted inside the housing.
If the model is incorrect look for yous at http://techdocs.shimano.com/techdocs/index.jsp
Procedures... http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Apr 19, 2011 | Shimano Deore Xt Thumb Shifters 7...
My Shimano Deore DX mountain bike up / down shifter is malfunctioning. Any help will be appreciated.
Maybe start here and if you can't figure it out, take it to a Bike Shop. Ther's only so much useful mechanical advice one can remotely lend with no details.
Jul 03, 2010 | Shimano Deore Xt Thumb Shifters 7...
How do I replace rear shifter cable in shifter lever? Older Shimano Deore XT
ok this is a little hard to explain in words but the important thing is to make sure the chain is on the biggest cog, pull the cable through the deralier tight and fasten. don't pull it too tight however. you may need to fine tune using the h/l screws but if it was in tune before then it shouldn't need too much adjustment.
Oct 03, 2009 | Shimano Deore Xt Thumb Shifters 7...
XT shifter will not shift
This link should help:http://www.parktool.com/repair/byregion.asp?catid=53
Sep 01, 2009 | Shimano Deore Xt Thumb Shifters 7...
Deore front derailer cable stay hex nut access
Try unhooking the chain from the ring and pulling the derailleur out far eough to get at the bolt. Make sure your limit screws are adjusted for the travel yuou want and take up the slack. You can use the cable adjuster on the shifter to tighten it or loosen it as necessary. Make sure the adjuster has enough to go in the direction you need. I don't know which model Diore you are talking about so this is the best advice I can give you.
Jul 04, 2009 | Shimano Deore Xt Thumb Shifters 7...
8speed lx shifter to xt shifter
It depends.. Shifter cables are standard and the same one would work for both LX and XT shifters. If the old cable is full of grime etc, it is a good idea to run new cables - it will give you a smooth easy shift.
I am sure if you check www.shimano.com you will find the manual for your model of shifter. Replacing cables is pretty easy.
Jan 24, 2009 | Mountain Shimano Deore Bicycle...
Cycling Logo
67 people viewed this question
Top Cycling Experts
Marvin
Marvin
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
