Question about Chicco Travel cot easy sleep yellow
How to wash
Is it okay for dry cleaning or just wipe it with wet clothes? will it not get rust if gets wet?
How to Make a Non Working Xbox Disk Work?
    1)Take disk out of Xbox
    2)Try turning off Xbox
    3)Choose one of the methods to try and fix disk Polishing disk
      -Use air first (blow across disk, or use a soft brush to remove any specks from disk before polishing)
      -Get a soft, lint-free polishing cloth (make it damp)
      -Use wet side of cloth to clean shiny side of disk
      -Dry whole disk (dry polishing cloth)
      -Put it in Xbox Using soap or water
        -Use soap or windex-slightly wet paper towel to wipe off disk from middle towards outside
        -Use furniture cleaner Using toothpaste
          -Rub toothpaste on disk, dampen a suitable soft cleaning cloth
          -Rub from centre-then move all the way around to edge
          -Wipe toothpaste off with a wet cloth-wipe any dampness with dry cloth
          -Put it in Xbox Using car polish
            -Get a dry cloth and add a small amount of polish to it
            -Rub in a circle motion, then wipe dry
            -Put it in Xbox Peanut butter
              -Put a dab of peanut butter on a lint-free cloth
              -Don't rub it in a circle motion
              -Put it in Xbox Using rubbing Alcohol
                -Pour out a small amount of rubbing alcohol onto a cotton bud
                -Rub from centre of disk, moving outward to edge
                -Wait for it to dry and try again Wax from candle
                  -Get some melted wax from a normal candle
                  -Gently pour wax on scratches-rub in with soft cloth
                  -Wipe off excess wax with a damp cloth
                  -Let disk dry for 5-10 mins and try again Vanish Oxipowder
                    -Cover entire shiny side of disk with powder
                    -Wait 5-10 mins
                    -Clean powder off completely with soft damp cloth
                    -Place disk in Xbox Other possible fixes
                      -Take disk to game/computer shop
                      -If any of your friends has game, borrow disk from them, install it to hard drive, and hope Xbox recognises it
Oct 20, 2016 | Video Game Consoles & Games
Tip
Cleaning Your Washing Machine
<span> <ol> <li>Begin by filling your empty washing machine up with hot water. Make sure the machine is set to the highest capacity setting (large load).</li> <li>While the machine is filling, add some white vinegar or lemon juice to the water (about one or two cups should do it). You can also add cup of baking soda, if you wish, to improve the smell of the washing machine. Run through the wash cycle. Once this step is done, the dirt build-up and mineral deposits that were stuck inside the washer should disappear.</li> <li>Wipe out the empty interior of the washing machine with a paper towel or cloth to get off any loosened dirt or grime.</li> <li>Run another cycle all the way through, this time using cold water.</li> <li>Now that the inside of the washer is clean, you'll want to make sure that the outside matches! Get at all the hard-to-get areas (like around the lid) with a cotton swab or the edge of a washcloth. Scrub away any spilled detergent or dirt that has collection on the surface. Wipe the exterior with a wet wash cloth. Dry off, and your washing machine will be looking great!</li></ol></span>
on Apr 04, 2011 | Washing Machines
What's the best way to clean a tv screen
Mild soap and water with a microfiber cloth with TV off. Then I wipe only water on the cloth to remove any residue then quickly dry with a dry microfiber cloth.
Sep 06, 2014 | Televison & Video
What do I use to clean the screen on a sane flat screen. Model # dp32649
The best is a mild solution of washing up liquid and clean warm water.
Use a clean lint free cloth and wet the cloth, wring it almost dry and wipe the screen over until clean.
Repeat this as often as required making certain not to let the cloth drip down the front of the screen.
Hope this helps
Dec 13, 2010 | Sanyo DP32649 31.5 in. TV
The TRANSFER BELT of my color laserjet 2600n is all smudged with the blue dust powder. 1. How come? 2. Can I just wipe it off? 3. Where can I get instructions to service clean my printer? THANK...
1. How Come? Most likely the blue cartridge is defective/ leaking. FYI.. Check your defective policy that came with the toner as we all know their not cheap.
2. Can I just wipe it off? Yes you can, most service technicans use a toner cleaning cloth. How ever if you can also use a dry, lint-free cloth and/ or brush.
Cleaning a machine:
External - you can use a wet paper towel (Not to wet as you DO NOT want anything to leak inside the cracks of the machines casing.) Also as it's Plastic you can spray non corrosive cleaning liquid on the paper towel and wipe the machine down. Please do not spray the machine.
Internal Cleaning -
Toner Spills - I highly recommend the toner cleaning cloth and a very soft brush (for the cracks and crevices) again you can also use a dry, lint-free cloth.
Paper Dust - Either a Vacuum or use the brush/cloth to clean it out.
Important Note: Never clean the inside of the machine with the power on or the power cord plugged in.
Hope this helps.
Oct 20, 2010 | HP Color LaserJet 2600n Printer
How to clean laptop screen
The best way I find it is to use a screen wiper. If you dont have one you can try to use still water and make a paper towel (kitchen towel) humid.. Do not make it to wet that would cause drops to fall on the screen and then with a dry one clean it over.
If you find your screen is not clean you can use steam from your own mouth.. like you would be cleaning you own eye glasses. I find it quite useful. Then with a dry paper towel clean it in circular movement.
Hope this helps
Oct 05, 2010 | Computers & Internet
I have a Zenith R50W46. How do I clean the screen?
1. Wet a soft cloth in a mixture of lukewarm water and a little fabric softener or dish washing
detergent. Wring the cloth until it's almost dry, and then use it to wipe the screen.
2. Make sure the excess water is off the screen, and then let it air-dry before you
turn on your TV.
I copied this directly from the manual for the TV for you.
Aug 28, 2010 | Zenith R50W46 50" Rear Projection...
Can you wash a wireless keyboard
No! You can clean it but not stick it in a wash machine!! You can clean it with treated compressed air or eletronic cleaning fluid but let stand 24 hours before use.
Thanks
Sep 17, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Washing techno xt
Remove the hood from the stroller and wash it by hand in the sink or bath tub. They usually clean up very well. Open the hood up and hang to dry or put it back on the stroller with the hood fully extended and let it dry. Just remember not to fold the hood back until its completely dry so that it doesnt mildew.
Mar 24, 2009 | Maclaren Techno XT Wisteria Umbrella...
SyncNaster 931B
take a soft cloth (type used for cleaning glasses) and moisten it with a small amount of water on one corner.
gently wipe the wet portion of the cloth across the screen (if you have any weak alcohol based cleaners you can try it. I have used hand sanitizer before on my 931b w/out problems, I wouldn't use any extremely strong liquid cleaners though).
Use the dry part of the cloth to wipe the area dry, then move to another part of the monitor once you are satisfied.
Jan 12, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
Chicco Travel cot easy sleep yellow Logo
27 people viewed this question
Top Chicco Baby Gear Experts
Rommel Balcita
thegtw
Dorel UK
Dorel UK
Are you a Chicco Baby Gear Expert? Answer questions, earn points and help others
