Question about HP LaserJet M3027 MFP Printer
ERROR 49.FF81 WHEN I ON MY PRINTER ON DISPLAY 4/6 AFTER THAT I GET ERROR 49.FF81
  • 85 Answers
From HP support forum possible defective hard drive.
http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-Setup/M3035-MFP-49-FF81-Error-Code/td-p/1272713/page/2
you may be able to disconnect the drive to get the printer operational,
but you lose some functionality
49 errors are communication errors with other devices in printer.
Posted on Mar 21, 2014
5 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: HP laserjet 4650; displaying error 49, FF81 Service Error
Unplug the power cord for 10 seconds
Posted on Feb 03, 2009
seeker5211
  • 1089 Answers
SOURCE: " 49.FF04 Error Turn off
Critical firmware error. Can be caused by invalid print commands, corrupt data, invalid operations or even electrical noise in the cable.
Turn off the printer, then turn it on.
Press Stop to clear the print job from memory.
Turn off and back on.
Print a document from a different software program.
If that document prints, go back to the first program that failed and print a different file.
If the error comes back, that file is corrupt.
If the message persists with different programs and print jobs have the formatter replaced.
Posted on Apr 17, 2011
SOURCE: 49 FF81 error on HP Laserjet 3035xs MFP
49.XXXXX ERROR To continue turn off
then on
A critical firmware error has occurred.1. Turn the device off, and then turn the
device on.
2. Go to www.hp.com/support/
LJM3027mfp or www.hp.com/support/
LJM3035mfp to check the latest
firmware image version. If the latest
firmware image version is newer than
the one installed on the device, upgrade
the device.
3. Try printing a job from a different
software program. If the job prints, go
back to the first program and try printing
a different file. If the message appears
only with a certain software program or
print job, then the error is in the software
program and not in the device. If the job
fails to print using a different software
program, then turn off the device and
disconnect all cables that connect the
device to the network or to a computer.
4. Remove any DIMMs and EIO cards, and
then turn the device on.
5. If, after removing DIMMs and EIO cards,
the device behaves normally, turn off
the device and reinstall DIMMs and EIO
cards one-by-one, turning off the device
off and then on again each time you
reinstall a DIMM or EIO card. If a certain
DIMM or EIO card causes the message
to reappear, replace the DIMM or EIO
card.
6. Reconnect all cables that connect the
7. If the message persists, replace the
formatter (see Formatter on page 116).
Posted on Apr 03, 2012
andi_bunkka
  • 102 Answers
SOURCE: hp colour laserjet 9500hdn has service error 49. FF81
I've seen this exact error a few times on the 4101s & turned out to be a bad EIO hard drive.If you replace the drive, you'll most likely have to download the newest firmware & load it to get every feature back.
You can try & initialize the drive first though:
- Turn off printer
- Press & hold [Start] button
- Turn printer on, wait for all 3 LEDs to stay solid then release button
- Press & release [Left] arrow button (should read "Initialize Disks" on display
- Press & release [Select], then wait for printer to warm up
Listen also to the drive & if you hear it clicking over & over then it's bad & will need replaced.
Posted on Apr 30, 2012
My printer hp laserjet 4350n displayed error 49.FF05 SERVICE ERROR .what is the problem
49.FF04 - in older 4xxx printer it mneans a firmware error - try to do:
1. cold reset
2. updaete firmware
3. remove network card from printer and instert it back - or try to turn printer on without it.
4. reinstall the formatter - phisical connection may be not good ( formater is a "cage" that the networc card is inserted)
go to http://www.hp.com for more information
May 27, 2015 | HP LaserJet 4350n Printer
HP COLOR LASER JET 2605 PRINTER 49 ERROR MSG DISPLAY SOLUTION
49 errors are most commonly caused when the printer receives a print job with commands it does not recognize. You can try updating the firmware as this will often resolve the error. Go to HP's website to find the most recent firmware, however this model is fairly old and likely the firmware update will be fairly old.
Sep 25, 2014 | HP Laserjet 2605dn Workgroup Laser Printer
No display clean ram and switch on ok but not reddy 49.FF05 ERROR in valied nand key press any key
ISSUE: A 49.x service error appears on the HP Color LaserJet 4500 or 4550 printers display, and other unexpected errors may be displayed such as:
  1. Turn the printer off, and then turn it on again. If the 49 error clears, proceed to Step 9.
  2. If the 49 error returns turn the power off, unplug the power cable, disconnect all network cables, and remove the HP Jetdirect card, which is located on the formatter, (see Figure 1 for location), or any third-party devices, if installed.
  3. Wait at least 30 seconds before plugging the printer back in directly to a wall outlet. Do not plug the printer into a power strip or a surge protector.
  4. Turn the printer on, using a cold reset. If the 49 error returns, turn the power off, and unplug the printer. Remove the formatter, and check that the parallel I/O board is firmly installed on the formatter board.
    NOTE: To perform a cold reset, turn the printer off, and hold down the GO button while turning the printer back on. Remember to remove the Jetdirect card (if installed) before performing a cold reset. (The Jetdirect card is located on the formatter).
Mar 28, 2013 | HP LaserJet Office Equipment & Supplies
Hp colour laserjet 9500hdn has service error 49. FF81
- Turn off printer
Apr 29, 2012 | HP Color LaserJet 9500HDN Printer
The error "49. FF05 SERVICE ERROR" is displayed on
If the error can be reproduced, use the following sections of this document:
  • Product-specific documents Product specific document are available on the HP support website at the following url http://welcome.hp.com/country/us/en/support.html . Select your product and use the search string Product specific 49 errors to locate your product specific 49 error troubleshooting document(s).
  • Clearing the error
  • Validating the firmware
  • Stack Trace Random error troubleshooting
  • Hardware troubleshooting (if applicable)
Power-cycle doesn't eliminate error If the error cannot be eliminated by a power-cycle, use the following sections of this document.
  • Hardware
Feature-specific error The error has been narrowed down to a specific feature.
  • Software, Sending, Faxing, and environmental troubleshooting
Oct 26, 2010 | HP LaserJet P3005d Printer
HP MFP 1522nf turns on and display error 49 turn off and on. The printer restarts and gives the same message again and again.
You need to be a little bit more specific nex time, the error 49 its normally related to an internal communication error between the DC Controller and the formatter board on the unit
Now we need to know if the problem appear when scanning, copying, printing, sending or receiving faxes
Heres some troubleshooting you can follow, its going to clear this error 49 most of the cases :
1. Turn off the product.
2. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
3. Wait until the message Permanent storage init. appears, and then release the buttons.
4. When the printer comes back to ready, go to hp.com and download the latest firmware update for this 1522nf
if you need more assistance you can contact me at :
eliteprintersolutions@gmail.com
Jun 26, 2010 | HP LaserJet M1522n MultiFunction Printer
Error 49 Cycle Power FFF
49 errors are possibly one of the most difficult to diagnose.
49 Indicates that a firmware error occurred that caused the processor on the formatter to abort an operation.
This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some cases, electrical noise in the cable can corrupt data during transmission to the printer.
Other causes include poor quality parallel cables, poor connections, or home-grown applications.
On some occasions, the formatter is at fault, but this is usually
indicated by a 79 Service Error.
I see you state a 49FFF? any other letters or digits displayed?
Specifically 49 FFFF can be a problem if the ribbon cable from the DC controller to the interconnector board is not connected. The control panel display will also be dark.
Other 49 FFx errors can be:
NEC firmware chip error - replace the Firmware
Unsupported EDO Memory installed - Remove unsupported RAM
Fuser life test error during Boot cycle - Replace the Formatter
A Large print Job (>800 pages) or complex graphics can cause the device to quit printing. - Simplify the Print Job, lower DPI etc.,
Good luck
May 02, 2010 | HP Color LaserJet 4500 Printer
Hp 2420 error 49 3c1a
If the printer is displaying 49.xx error message, followng the following document
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c00280149&jumpid=reg_R1002_USEN
Upgrading the firmware should resolve the issue.
Please let me know one you perform the above upgrade.
- Nikhil
Nov 20, 2008 | HP LaserJet 2420 Printer
Error message 49,ff81
it is temporary printing error, turn off the machine and wait 10 sec and turn it on again it should clear.
Oct 15, 2008 | Office Equipment & Supplies
HP LaserJet M3027 MFP Printer Logo
527 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
