Question about Pro RX65 Radar Detector
When i plug in my rx 65 it says service required
I had a similar problem.... don't leave it in your vehicle(I think it is really sensitive to humidity changes.... take it into your house and let it "dry out" you may find it works.... mine did.
Posted on Jul 10, 2009
  • 365 Answers
It's stolen, or doesn't recognize the POWER supply.
Posted on Jun 14, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
RX-8 & DSC
Hi Melissa,
I had a similar problem with my 2005 RX8 but didn't try using the DSC button. I had to have my engine rebuilt....I'm in So Cal and found a great private mechanic, are you local???
May 14, 2014 | 2005 Mazda RX-8
Rx Fax info mismatch
Fax with Popfax with no more sending errors, busy signals, paper jam or faxes lost. So easy to setup Popfax service: no phone line installation or hardware purchasing required. Usually it takes only a few minutes to decide which package to choose and to subscribe to an internet fax service. The only things required are a device (Laptop, PC, Tablet or Smartphone) and an Internet connection. Try for free!
Jul 30, 2013 | Office Equipment & Supplies
What maintenance do I do at 60,000 miles for an rx-7
The 30/60/90/120K or 3 year services are major services. All fluids are changed, oil, brake, coolant, all filters and plugs wheel bearings packed, transmission and rear gear oils changed. To download a mazda factory service manual go to foxed.ca.
Apr 19, 2013 | 1994 Mazda RX-7
COBRA 21 GTL NO MODULATION NO RX. BUT IT WILL TX AT 3 WHATTS.I HAVE TRIED 3 DIFFERENT.MIC ON THIS RADIO CAN YOU HELP ME
That's usually a defective amc stage that produces RX audio and TX modulation. It's an integrated circuit that will require a tech fixing it. You will have a transmitted carrier with no modulation, and no sound in your speaker. However, make sure you have a good mike plugged in first, and substitute a known good mike to verify it's not the mike.
Jul 30, 2010 | Radio Communications
Hi i have a brivis eh 30 unit that comes up with error 65 and 30 the display inside the unit says fan limp, if i reset it from the unit it works for about 1 hr then the same thing can anyone help please
Hi. Here are the error codes for your Brivis Heater. Error Codes 30 - relating to speed sensor, 40 - overheating, 65 - motor lock-out. Usually resetting the unit will resolved the issue. In your case, you already reset the unit and problem came back. This will require immediate attention by Brivis technician.
Jul 12, 2010 | Heating & Cooling
I need a new cord that plugs in to charge the batteries,or so i wont need to use batteries they are dead
Here are the specifications for the power chord for your notebook.
417220-001 : AC adapter (65 watt) - Input voltage 110-240VAC, 50-60Hz, 2.4A - 18.5VDC output voltage, 65-watt - Requires a separate 3-wire AC power cord with C5 connector
You can purchase from impact computers
Mar 28, 2010 | HP Pavilion ze2000 Notebook
What does the maintenance required light mean on my 350 rx
It means you have reached the mileage for service. Once the service has been done, they will have to reset the light.
Jan 12, 2010 | 2007 Lexus ES 350
What is the cost of a 90000 mile service for a Lexus RX 300?
$700
timing belt
idler pulley
water pump
timing belt tensioner
valve cam gasket
coolant flush
spark plug
oil change
pcv valve
tranny oil change
differential fluid cahnge
drive belt
upper/lower radiator hose
brake system flush
air filter
good luck,i hope this help pls dont forget to rate me thanks
Jun 05, 2009 | 2001 Lexus RX 300
Pro RX65 Radar Detector Logo
581 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
John Nolan
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
