Question about HP EPDJ5943SLED DeskJet 5943 Color Inkjet Printer Sled Carriage
This test page briefly demonstrates the printer's ability
Define reflexive competence
A person's demonstrated ability to perform a specified set of tasks. The ability to integrate actions with an understanding of what you are doing.
Jan 17, 2017 | Health & Beauty
Factory reset
This type of problem is typically caused by one of the ink cartridges which is suffering from marginal electrical performance - either the HP92 (black) or HP93 (color) ink cartridge.
Can you perform the 'Self Test Page' test (see below). If this test is successful then this demonstrates the printer is 'generally operational', but if normal printing is still not permitted then either the HP92 (black) or HP93 (color) ink cartridge is likely electrically damaged and may need to be replaced*.
Perform Self Test Page:
1. Press and hold the CANCEL button.
2. Press the COLOR COPY button. Release both buttons.
3. The self test prints. The printed pattern will verify printer is generally functional. Inspect color bars to verify proper nozzle/jetting health.
-- Inspect printed nozzle stair step patterns - verify all ink nozzles are properly firing. Generally, if the Self Test Page prints ok then the printer is functioning correctly and the problem is with the ink cartridges - replace the suspect ink cartridge and retest. Refer to 2nd video procedure at the following link on how to read the Self Test page test (NOTE: HP74/75 cartridges are electrically identical to the HP92 thru 98 cartridges).
http://inkjet411.com/?page_id=579
*Many cartridges eventually do encounter problems or failures. Severe cartridge errors are primarily caused by an electrical breakdown at the cartridge's nozzle plate. Ink *********** or corrosion into the nozzle plate will cause a failure of the tiny micro-electronics resulting in a variety of different error messages being displayed - see picture at bottom of this page: http://inkjet411.com/?page_id=1216
It is suggested to install a new HP92 and/or HP93 ink cartridge in it to resolve the current issue.
May 02, 2013 | HP PhotoSmart C4180 All-in-One Color...
I wish to know on how we can get the page count of our newly purchased Canon LBP2900. we already tried printing the test page, but no data of page count on it. please advise the best solution. thanks!
Hello, These home oriented host based printers does not have the ability for the user to check the page counter. Sorry. You can install additional software on your pc which can count the pages from now on, but will not show the information from the beginning.
Sep 23, 2011 | Canon LASER SHOT LBP-2900 Printer
Can i switch off in service mode ability to switch "demonstration" in menu
Clicking Menu, SetUp, Reset will reset the television and take it out of demonstration mode. You may have to re-program your channels & labels however, but you will get out of demonstration mode.
May 05, 2011 | Sharp LC-26SD1E 26 in. LCD Television
How can i manage my deskjet810C inkjet, then there is command from the pc but the printer could not print, but when we pressed the 2nd botton it can print out but onl the HPDESKJET810C, HEWLETT PACKARD
Since it can print, the printer is probably ok. To check the ability of the printer to receive commands from the pc; locate "Devices and Printers" that has a list of the printers attached to your computer. If the HP 810C is on the list right click on it and select the "printer properties" On printer properties there will be a "Print Test Page" - click on that. If the test page prints, your system is operational and something must be wrong with the program that you tried to print from. If the HP 810C is not on the list, then the printer might not be properly installed so you could try reinstalling.
May 04, 2011 | HP DeskJet 810c InkJet Printer
How to print test page on HP DesignJet 450C
There are various pre-defined prints which are built-in with the printer. To test the printer, you can get the Demonstration Print by pressing SETUP and CANCEL keys simultaneously. You also can get more information by reading the HP 430/450/488 User's Guide page 5-2.
Dec 18, 2010 | HP DesignJet 450c InkJet Printer
Print test
Step Press Displayed Result Notes
1. Install the ribbon, load paper, and power on the printer.
2. NOT READY Printer must be in NOT
READY mode to access
the tests.
3. OPERATOR MENU
UNLOCKED
Unlocking ENTER key
allows you to test the
printer.
4. OPERATOR MENU
PRINTER CONTROL
First of series of
configuration menus.
5. OPERATOR MENU
OPERATOR PRINT TESTS
Advances to the Operator
Printer Tests menu.
6. OPERATOR PRINT TESTS
PRINTER DEMONSTRATION*
Advances to first option in
Operator Printer Tests
menu.
7. OPERATOR PRINT TESTS
[TEST NAME]
Cycles through list of
tests. Stop when your test
displays.
8. OPERATOR PRINT TESTS
[TEST NAME]
The test you selected
starts printing.
9. NOT READY The printer test stops
printing.
Stop
Scroll­ + Scroll¯
Menu
Scroll­ UNTIL
Enter
Scroll­ UNTIL
Enter
Stop
Let me know if you need any other help with this. I carry all parts and refurbished units and offer free techincal support as long as the parts ordered thru us.
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 X240
rcardenas@mrp.to
Jun 24, 2009 | IBM 6400-I2S Matrix Printer
No display and no light indicators when powered on
If the printer control panel is blank when you turn on the printer, check the following items.
1. Make sure that the printer is plugged into an active electrical outlet that delivers the correct
voltage.
2. Make sure that the on/off switch is in the on position.
3. Make sure that the fan runs briefly, which indicates that the power supply is operational.
4. Make sure that the control panel display wire-harness is connected.
The control-panel wire-harness connector can easily be disconnected when you install the top
cover. If the control panel does not work after the top cover is installed, verify that the wire-harness
connector is fully seated into its DC controller PCA connector.
5. Make sure that the firmware DIMM and the formatter are seated and operating properly.
6. Remove any HP Jetdirect or other EIO cards, and then try to turn the printer on again.
If the printer control-panel display is blank, but the main cooling fan runs briefly after the printer
power is turned on, try printing an engine test page to determine whether the problem is with the
control-panel display, formatter, or other printer components.
Engine test page
To verify that the printer engine (all printer components except the formatter, formatter DIMMs,
EIO products, and the stacker or stapler/stacker) is functioning, print an engine test page. Use a
small, non-metallic, pointed object to depress the test-page switch, which is located on the right
side of the printer
The test page should have a series of vertical lines. The test page will print from the last tray you
printed from. However, if the printer has been turned off and then back on since the most recent
print job, the page will print from tray 2. The printer will continuously print test pages as long as
the test-page switch is depressed. The printer will not print a test page if it is in PowerSave
mode.
A damaged formatter might interfere with the engine test. If the engine test page does not print,
try removing the formatter and performing the engine test again. If the engine test is then
successful, the problem is almost certainly with the control panel, or the cable that
connects it.
Hope this helps
May 24, 2008 | HP LaserJet 4250n Printer
Canon BJC 4300 InkJet Printer
i assume the cleaning method that you perform is offline (taking the cartridge our and clean them). I suggest you clean the head during the printer on.. try to perform below steps per the manual Cleaning the printer Printing the test pages Cleaning the print head I assume you do not have the manual anymore (no DVD) i list down the step below Its a bit long manual I suggest you download them from the canon website.. if you still have problem I can send to you the BJC 4300 manual Cleanning printer Make sure the printer is turned off before cleaning it. It is a good idea to unplug the AC adapter also. Do not clean the exterior of the printer with volatile liquids such as thinners, benzine, or any spray-type or chemical cleaners; doing so will damage the surface of the printer. When cleaning the printer, avoid the area near the print head on the BJ cartridge. Do not touch the print head. Ink may leak out and cause stains. Clean the printer regularly to avoid printing problems. Remove any ink mist or paper debris from the interior of the printer using a soft cloth moistened with water. Clean especially well around the platen area. If the rollers become dirty, you can clean them using a small soft brush. Clean the exterior of the printer with a soft cloth moistened with water. Clean away smudges and dust. Do not use paper products (such as paper towels or tissues) to clean the inside of the printer. Printing the Test Pages You can print these test pages to check the operation of your printer and your print quality. Test A This test prints a repeating pattern of characters. Demonstration This test prints a sample page describing the printer's features. Printing the Test Page From Windows You use the Test option on the Control tab in your BJC-4300 Printer Driver for Windows to print a self test, demonstration page, or a nozzle test pattern. Before selecting a Test option, make sure paper is properly loaded in the sheet feeder (see Automatically Feeding Paper starting on page 3-7). Click on the Test option and then click on the Print button. Printing the Test Pages Using the Operators Panel To print a test page, make sure the printer is turned off and paper is loaded. Press and hold the POWER button until you hear the number of beeps that correspond to the test page you want to print. Test Page Number of Beeps Pages Printed Demonstration 1 Continuous Printing Status Information 2 1 Page Test A 3 Continuous Printing Nozzle Test 4 1 Page When you release the POWER button, the test page starts to print. *All self-test prints require Letter or A4 size paper. Using a smallersize paper for a self-test print will result in parts of the printoutbeing printed directly on the platen. All self-test prints are printed in accordance with the current printing settings (font, printing mode, etc.) *Red- Information for technician not included in the user manual Cleaning the Print Head Your printer is equipped with a print head cleaning function to ensure constant high quality printing. Cleaning the Print Head From Windows If you are using Windows, you can execute print head cleaning from the Control sheet in the printer driver. Simply click on Clean Ink Head. 4300 Chapter 4 Page 6 Cleaning the Print Head Using the Operators Panel If you want to clean the print head from the operator panel, follow these steps: 1 Make sure the printer is turned on. Make sure the green POWER light is on. 2 Press and hold the RESUME button for at least two seconds until the printer beeps twice. The POWER light will blink for several seconds while the print head is being cleaned. Perform the print head cleaning only when you encounter a print quality problem. Unnecessary and repetitious cleaning will waste ink. If you execute the print head cleaning while paper is manually loaded, the printer will eject the paper and then perform the cleaning. 4300 Chapter 4 Page 7
Aug 24, 2007 | Canon BJC 4300 InkJet Printer
HP EPDJ5943SLED DeskJet 5943 Color Inkjet Printer Sled Carriage Logo
155 people viewed this question
Seeker5211
Seeker5211
