Question about Samsung Galaxy Y Gt-s5360 - Black unlocked Smartphone
My phone keeps turning ON AND OFF.. If it's on it will not last longer then it will turn off
Its power button doesn't function
    Master:
  • Samsung Master
  • 561 Answers
Check the battery status. Try to replace it with a working one.
Posted on Jul 28, 2014
Droid Razr won't turn back on.
For my two bits, try holding the power button a little longer, it might engage.
Jan 22, 2014 | Motorola Mobility DROID RAZR MAXX HD
I replaced an old Malibu 300 watt powerpack with a new digital 300 watt Malibu power pack and when I turn it on it runs for about a miniut and then shuts down. I have 15 11watt light on it, the same as the...
300 watt power pack should have 300 watt load.
You have 165 watt load.
Copy following link for general tips to get Malibu power pack to last longer.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Problem might be the photo eye.
http://waterheatertimer.org/images/Malibu-8100-9045-01-large.jpg
Rotate manual dial to ON position and see if lights turn ON.
Keep in mind the digital power pack has photoeye that is light sensitive, and must be exposed to dark light to activate.
For timed functions. Rotate manual dial until it points at timer. Press clock set function button, and use up-down buttons to set current time. Press timer ON button, and then use up-down to set ON timer. Then press timer OFF button , and use arrow keys to set OFF time.
This product has 1 year limited warranty, contrast with old-type analog power pack with 5-year warranty.
Malibu does not even post a manual on their site, which might have troubleshoot section to illuminate why your system has problem,
http://malibu.brinkmann.net/customer_service/owners_manuals.aspx
Nov 29, 2012 | Hardware & Accessories
Malibu transformer ml44p doesn't turn off
Check if trippers are worn.
Check if dial rotates and keeps good time.
Plug transformer into cheap wall timer.
Copy following link for trippers, 5-year warranty info, tips to make power pack last longer, and other troubleshoot resources:
Oct 30, 2012 | Intermatic Malibu 121W Power Pack...
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
Trying to unlock google password and it want let me get out of it
leave the phone on take the battery out this should reboot the phone
Oct 07, 2011 | HTC EVO 4G Smartphone
I turned off the power prior to changing a bulb controlled by a Leviton true touch dimmer. Now, the touch functions no longer work. the light is stuck on bright (dimmer doesn't work) and I can only...
The switch has a protected memory and will go to the default setting in case of power failure or shut off. Make sure you swapped it with the same watt/type bulb. You can always shut off the power to the dimmer for a few min. and turn it back on to force a reset.
Sep 04, 2011 | Hammering
It keeps turning itself off! How do I keep it going 24/7?
Well that seems like a waste of energy.
Anyway that is your problem.
The Power/Sleep button has a dual function: Power ON/OFF and Sleep.
A short press will turn the timer on and you will see numbers like 90, 75, 60,...10, 01. pPressing again will cycle to the next sleep duration. If your radio has a short duration timer it will seem that it is turning itself off.
To activate a normal Power up, your first press should last longer (I cannot tell you how long, you will have to try it on your own.) You should not see the timer durations, just the frequency of the station its was last tuned to. In addition, no loudspeaker should be displayed at the lower right corner.
Sep 03, 2010 | Grundig S350 AM/FM/SW Radio
My i9+++ phone wont turn on
HI,
problem can be solved. How long has it been in the box and when last did you charge the battery of the phone?.
The longer you keep a phone and don't use it, it is likely to affect the phone somehow.
The battery has not been charged for a long period of time and the cell of the battery is weak, that's why the phone is not coming.
You need to charge the battery for longer hour for it to regain the strength to power the phone on again. After longer hours charging of the battery, the phone will come .
Have a pleasant day.
Mar 20, 2010 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
Jan 24, 2010 | Vizio VX37L Television
Samsung Galaxy Y Gt-s5360 - Black unlocked Smartphone Logo
19 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
