Question about Epson Office Equipment & Supplies
Workforce pro 4530 is leaking yellow ink on the path of paper feeding and while printing there is yellow ink on the paper please I need solution how I solve this problem.
    Sergeant:
    Champion:
  • Epson Expert
  • 387 Answers
Replace yellow cartridge, if that doesn't fix it printer head is the problem. Use genuine cartridges.
Posted on Apr 29, 2014
SOURCE: Paper does not feed and E3 error code is flashing
I have one of these printers and have found the problem, crappy enigineering and inferior parts. Looking at the printer from behind, on the left side (where the motor is located) There are two white gears, located at the bottom and behind a larger black gear. One is of medium size and has a spring. The other is smaller and slides into the medium gear. If you can get these two gears back together and in their proper location, then you're set. But, if you're like me and get frustrated easily, DON'T TRY IT! I broke mine :( A repair will cost as much as a cheap printer, so bite the bullet and hit-up your local rite-aid, they have printers that wont bust the bank. Keep your MP 150, after all the scanner/copier will still work without its attached printer.
Posted on Nov 06, 2007
  • 52 Answers
SOURCE: My LaserJet4250n Printer keeps printing a page
I think what is happening is when you get the error, the printer automaticaly reprints the page it was on when it got an error condition that makes it think it didn't print the page correctly. The clearing paper path message comes up after it thinks it had a jam. Displaying load plain paper could be because either the printer is not configed for the correct type of paper you have in the tray you are trying to prin form(push the green check button, arrow downt to paper handling and see what your trays are set for.) Also there is a blue switch on the tay(looking for front of tray it will be on the right hand side of tray rail) the switch says standard or custom. The switch should be in the standard position.
Are you getting any errors or jams, if so, tell me what they are.
Posted on Mar 05, 2009
websnail
  • 419 Answers
SOURCE: HP Officejet Pro L7780 sucking out ink of new ink cartridge
Is this a refillable cartridge you're using or a genuine HP OEM...
If it's a CIS, refillable or some kind of cartridge which is not made by HP then chances are the ink nozzle has failed and allowed the yellow ink to leak everywhere...
There are a lot of problems with these 3rd party cartridges and I would never recommend using anything other than a refilled HP cartridge or a genuine one.
Hope that helps.
Martin
Posted on Jul 11, 2009
SOURCE: epson workforce 600. says it has paper jam but
FIXES FOR EPSON RX600 PAPER JAM
Posted on Jan 18, 2010
  • 225 Answers
SOURCE: I just replaced my ink
Try "Nozzle cleaning" and if the problem persist, try "Deep nozzle cleaning". Try them only once or else the ink will run out very quickly.
If the ink cartridges are not genuine Epson, remove them and buy genuine cartridges. If needed, repeat the procedure with them.
Non-original consumables very often clog the printhead.
Posted on Aug 07, 2010
Prints 1" wide blue streak from top to bottom of page
If you're holding the paper so the narrow side is up, and the blue streak is vertical, then it's not a bad print head. If the stripe is from side to side with the paper held that way, then possible that the head is bad. The 4530 is an office type printer with large carts that connect to the print heads with hoses. It's possible that a hose has come off and is dumping ink that way, or that the hose is leaking...
Apr 17, 2015 | Epson Pro Wp-4530 All-in-1 Inkjet Wireless...
Correct setting for Epson Workforce 7520 printing on gloss paper
You need to start with photo glossy paper that's designed for an Epson printer. HP paper may not work well, and some other papers don't work either. Try some Epson paper, and that should work fine.
You can also try other paper settings, such as "transparency" or "matte paper", as the paper setting governs how much ink is laid down. I think getting the right paper is really what you need, though. Ink "puddling" is a common Epson complaint, and it's almost always the paper.
Nov 02, 2014 | Epson WorkForce WF-7520 Wide Format...
How do i get my printer to print last page first
Any special reason? They will always print in the right order, so you can read in correct order. You organice your printing on Page set-up.
Jul 24, 2014 | Epson Workforce Pro Wp-4530 All-in-one...
Leaking ink
Bad printer head or cartridge
Mar 12, 2014 | Epson Workforce Pro Wp-4020 Color Inkjet...
Epson pro wp4540 printer is spraying a band of yellow ink down the page
remove cartidge- using a flashlight look at its "seat " in printer- sounds like you have a dust bunny- clean with q-tip
Dec 22, 2013 | Epson Workforce Pro Wp-4540 All-in-one...
HP Photosmart 3200 All-In-One not printing yellow
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Aug 20, 2008 | HP PhotoSmart InkJet Printer
169 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
