Question about Whirlpool Dishwashers
Etna dishwasher e4
Leaking
Our dishwasher has the message e4 on display
You don't say which dishwasher you have..
But e4 is normally antiflood... At the bottom of most dishwasher is a plastic tray that catches leaks and condensation, If water builds up in it the float switch trips.
Depending upon your abilities, it is possible to get the water out using a sponge or cloth... if you are successful and it happens again in a short space of time you might have a leak which will require further investigation.
Apr 16, 2017 | Dishwashers
How to get into bottom section of dishwasher to find a leak
i had the e4 code today. fixed it, thank god.
Sep 09, 2016 | Dishwashers
My dishwasher is showing the sign E4 on the display panel. What does this mean?
What's the make and model of the unit in question, please?
Mar 08, 2015 | Dishwashers
Hi... I just bought Electrolux Dishwasher ESF2433W. When i first time turn it on, light at "Normal" button keep on flashing with beeping sound. After checking the trouble shooting manual, it actually refer...
E4 Overflow
Sometimes during trasport it is possible that styrofoam float mechanicaly activated overflow microswitch. So, you should check complitely overflow system.
At any time, if overflow micro-switch act and keep for longer than 2 seconds, the E4 would occur. When E4 occurs, the drain pump will run until flowmeter keep motionless for 2 minutes (if the model with the pressure switch (83/63),drain pump would run till the pressure switch reset and continue draining for 60 seconds.) and all the other components will be stopped immediately. At the same time, the buzzer will alarm for 30 seconds and error 4 will be shown. Note: Priority level of E4 is the highest. E4 operation is valid after other error operations have done. When E4 operation has done, all the others are invalid.
Dado
Feb 20, 2015 | Electrolux Dishwashers
E4 showing on the panel KDW60X10
The Kenwood KDW60X10 shows the E4 code when there is a water leak or a problem with the float switch (or it's PCB board connection). This could be a leak at the tank, the hose, or that the drain pump's anti-flooding system has been tripped.
Disconnect the dishwasher from power and the water line. Look for signs of a water leak under the unit. If the hose is leaking, you may be able to replace or reseat the drain hose. (Also make sure that there are no kinks in the hose.) Note: sometimes the leak is in the plastic where the drain hose connects to the dishwasher. That is harder to fix.
If the tank is leaking, replace the entire unit. For the other possible problems, you should consult a repair tech to narrow down the issue. Float switches are easy enough to replace; the PCB board and the anti-flooding system are not as easy to reset.
The manual for your dishwasher is available here: http://www.partmaster.co.uk/company/partmaster/manuals/Kenwood%20KDW60X10.pdf .
I hope this helps.
Apr 12, 2012 | Kenwood Dishwashers
Belling dishwasher IDW604 error code E4 on control panel
I found the solution myself. Underneath the machine, there is a plate. On the plate, there is a float and a microswitch, when the water leaks onto the bottom plate it raises the float and activates the microswith which shuts down the machine and shows E4 on display. To get rid of the fault, you have to pull out the dishwasher, then tilt it, and drain the water from the bottom plate. Also make sure that there is no leak in the internal piping, if there is, the fault will come back as soon as the recess in the bottom panel fills with water.Hope it helps.
Feb 25, 2010 | Dishwashers
Error code e4 flashes on belling dishwasher idw604 , washer is empty cant get any programs to work
Dec 27, 2009 | Dishwashers
Kenwood dishwasher kdw8st2a
I had E4. Initially couldn't get it to clear.
In desperation, switched it off, turned it on it side and drained it onto the floor.
The E4 disappeared and the dishwasher is working normally.
Jan 22, 2008 | Smeg 24 in. DWF614SS Stainless Steel...
BDW45.1 Baumatic Dishwasher E4 alarm
Check and clean the filters on the inlet water line (both sides). Good luck!
Sep 03, 2007 | Baumatic 18 in. BHD45 Slim-Line Built-in...
Dishwashers Logo
24 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
