Question about Dunlop Dun-15-1 Power One Key Heart Rate Monitor
Heart rate monitor
Will not show heart rate om HMR mode
Watch turns self off after disconnect from HRM belt. After a few hours comes back on again by itself and have to reset up time date etc.
RTM. Read the manual. You can always do a google for your watch name make model and manual and you should get a .pdf to download and read it. It is a heart rate monitor so that heart should be on there.
Dec 01, 2014 | Timex Ironman Triathlon Heart Rate Monitor
Need a new heart rate monitor for my timex ironman watch
You can go to any timex or watch republic stores.. show your watch, fill up request form.. and the branch will send the form to their head office.. and wait for their call. hope this will help.. this is their customer service nos. 8942035 loc 217 or 219
Feb 03, 2013 | Timex Ironman Triathlon Heart Rate Monitor
I need to set the heart rate monitor to on
Press OK until the watch is in exercise mode.
Does this solve your problem?
Jul 03, 2010 | Polar F11 Heart Rate Monitor
Bpm isn't showed, i have changed the batery and bpm doesn't apear
I just helpped some one else with same probelm, try this see if it works.
In the battery compartment there’s a gold contact that touches the top of the battery (+ve) which was in a position that would never make contact with the battery. I bent it out slightly, made sure the battery was seated correctly (i.e. flat) and as if by magic my heart rate appeared on the large Garmin display!
Also found this..........
I Have had the same problem couple of times (and forgotten each time how I solved it). I figured it out just now and this is what I did.
1) turn on unit and put on heart monitor (make sure battery is good and wet heart strap)
2) using the mode button navigate the menus to: Settings: General: Accessories: Heart Rate Monitor
3) Once in the Heart Rate Monitor option make sure "Yes" is selected and then use the arrow buttons to highlight "Restart Scan" . Press the enter button to rescan for your heart monitor. (I had to rescan twice)
Go back to the main monitor screen to see if you are recieving heart rate signals.
I am not sure why a manual rescan needs to be done every time but it would be nice if Garmin fixed this issues in a unit software update (my unit has software version 2.80
Hope this helps......
Jan 17, 2010 | Garmin Forerunner 305 GPS Receiver
Heart rate reading low
try this link for the manual.
polar f11 heart rate monitor manual Google Search .
However, you may wish to reset the unit and start over with new settings. You can resetyour Polar F11 by following a few easy steps. Press any button to activate the Polar F11 Fitness heart monitor unit. Press all buttons on the Polar F11 Fitness heart monitor simultaneously, except the "Light" button.
How to Reset a Polar F11 ' Healthfully
https://healthfully.com/reset-polar-f11-7176556.html reset polar f11 heart rate monitor Google Search
Oct 29, 2017 | Polar F11 Heart Rate Monitor
Pressing the senors and my heart rate doesnt show !
Before pressing the sensors you need to dampen your skin a bit.
May 15, 2009 | Reebok Fit Watch 10M Strapless Heart Rate...
Heart rate monitor reading "lo"
to shutoff HR out of range alarm - when selecting the ranges in the HRM Steup mode - press the START/SPLIT button to toggle the alarm on and off. (use the start/stop button on the pro fitness model). page 14 in my manual
Dec 12, 2008 | Timex Ironman Triathlon Heart Rate Monitor
Dunlop Dun-15-1 Power One Key Heart Rate Monitor Logo
24 people viewed this question
Top Dunlop Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Dunlop Exercise and Fitnes Expert? Answer questions, earn points and help others
