Question about Baby Gear
Quinny buzz clip to open missing
I recently bought a second hand quinny buzz. I didn't pay too much attention to how it opened until I brought it home, and not realise that the "clip" you need to unhook to open it is missing, and there is no sign of where it used to be. I can still open the pram just by pulling up on the handle and pushing down on the frame. I have a bit of resistance and something "clicks" before it opens. It opens automatically but I am worried I will damage it. It's a 2008 model. Am I likely to damage it? Is the clip just a safety thing to keep it closed or does it connect to something on the inside?
  • Baby Gear Master
  • 1,629 Answers
Hi Ellen
The transport clip is a safety measure to ensure the chassis remains closed in transit - like when it's in your car boot, to make sure it doesn't unfold while you're driving. It is available as a spare part item, RRP 10GBP (full info can be found on our Note for Buzz spares)
The click noise you hear when you unfold the chassis is not related to the fold lock. This is a safety measure designed to warn you not to continue forcing the chassis open as the locks are not completely disengaged ready for the chassis to be unfolded. By forcing beyond this noise you may cause damage to the fold / unfold mechanism. If you hear the click, allow the chassis to fold again and try again. Ensure the button is fully depressed / the other side button is fully pulled forward before attempting to unfold again and you should not hear a click. If you do, it would be advised to book the chassis in for inspection & repair required.
Quinny Buzz Quinny Buzz Xtra Spare Parts
Repair Charges Effective Immediately
Posted on May 12, 2014
jackiaria
  • 350 Answers
SOURCE: Quinny Buzz Frame Problem
Try contacting them directly!
This may be a manufacturing problem that they are not aware of !
Click on the link below.Copy and Paste your problem into the email if you like.
http://www.quinny.com/quinny/forms/contact.aspx?mode=contact&language=nl-nl
Hope this is helpful.
Good Luck!
Posted on Jan 22, 2009
SOURCE: does the quinny buzz seat 2006 and carrycot fit the 2008/9 frame
Hi new frame should be ok, the only frame that is different is the older 2005 frame, if you remove your seat unit and check the posts on your seat unit (the bits that slot onto the buzz chassis) if they are both the same and have rounded ends then this is the older model and wont fit the newer frames, but if one of the posts is rounded and the other is shaped like a turret then all the frames 2006 onwards will be ok. :)
Posted on Sep 06, 2009
  • 419 Answers
SOURCE: Hi, I have a Quinny Buzz pram that has an
HI,
This sounds like you need a replacement gas cylinder. This is not something that you can do yourself and would need to be undertaken by a qualified person. You need to contact either your retailier or www.dorel.co.uk
I hope this helps.
Posted on May 21, 2010
  • 223 Answers
SOURCE: clip to keep a quinny pram frame folded down
Hi you can use a velcro stap to hold it together or Dorel may sell them.
Posted on Aug 07, 2010
Testimonial: "thank you and good thinking i'll do that"
Dorel UK
  • 1629 Answers
SOURCE: Hello, I recently bought a quinny
Good Evening
It sounds as though you're not quite depressing the fold buttons fully when trying to collapse it, so you're pushing against the natural spring of the chassis which is making it difficult.
The Buzz is easiest to fold when you're standing in front of it. Either remove the seat unit, or make sure it is forward facing and in the upright position before you start. Swivel the front wheel straight and lock it into position. Standing in front of the Buzz, push the left side button in until you can't make it go any further, then roll the right button toward you as far as possible. It should only require a small amount of pressure to fold the unit, but remember, due to the style of the automatic unfold you are working against it to fold it up. If you hear any clicks, pops or creaks, don't force it as you'll break the fold knuckles.
If this still doesn't work, give the chassis a good, thorough clean to make sure no dirt or debris is causing the problem. Use a dry Teflon spray (found in the laundry aisle of most supermarkets) or normal furnature polish with a soft dry cloth and give the whole chassis a thorough cleaning. Then as you're folding it down, follow the black plastic down the central tube as it goes toward the front wheel unit to make sure its totally clean. This should make it smoother to fold.
Failing that, the product will need to be returned to the engineers for inspection - which country are you in?
Posted on May 23, 2011
I bought a second hand Quinny Buzz, and the clip for the frame lock is broken
Hi
The transport lock is available as a spare part item - who did you speak with that advised you it wasn't?
RRP for the transport clip is 10GBP and you can order via your local Quinny retailer or direct from the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays)
Sep 11, 2012 | Quinny Buzz Baby Gear
I have bought a second hand Quinny Buzz 3 and it will not fold. It is really stiff and I just cannot fold it, even with help. Is there anything I should be doing or can do or should I just buy a...
Hi Lisa
It may be that a good clean will resolve the situation. Use furniture polish or dry Teflon spray (found in the laundry aisle of larger supermarkets) and a soft cloth to clean thoroughly. Pay special attention to the central tube where the mechanism slides up and down for fold / unfold as any dirt there will cause friction and make fold / unfold difficult.
If this does not help please visit www.quinny.com and select the country you're in, then choose the "Contact Us" tab on the right side of the page for your enquiry to be sent through to the customer care team who can best assist.
Aug 10, 2011 | Quinny Buzz Three Wheel Stroller
Quinny buzz stroller keeps collapsing when in use
Hi if you bought it within 60 days you can open up a claim on ebay & get a full refund. i sell them in perfect condition & would never sell 1 that is faulty. The only other option is if you are putting bags on the handle this will make if fold up on itself. contact me @ marie-lowe@hotmail.co.uk
May 10, 2010 | Quinny Buzz Three Wheel Stroller
My quinny buzz 3 chassis sometimes starts to partly collaspe when in use, especially when weight put on it, i.e when going up kerbs. Any suggestions to mend? I bought it second hand but it is only 18...
the bolts on the side where the lower section meets the arm need to be checked and tightened as these lossen i have had this happen my self very scary x
i found that every time i opened my pram it would not be fully locked together so i put my foot on the bottom bar and pulled the bar up untill it clicked into place and no longer had issues with it trying to fold itself while in use hope this helps x
Dec 10, 2009 | Quinny Buzz Jogger
I have a quinny buzz and the catch that keeps the frame shut is not working, so when driing it can pop up! I brought this second hand so no idea what to do.
If this is a first generation Buzz, you should be able to get the nylon clip style catch that attaches onto the frame and keeps it closed. I would suggest that you contact http://www.quinny.com/quinny/forms/contact.aspx?mode=contact&language=gb-en as they will be able to assist with this.
I hope this helps.
Sep 11, 2009 | Quinny Buzz Jogger
I have a quinny buzz 3 wheel pushchair. i brought it 2nd hand. iT COMES With 2 parts a crib and a child seat. i do not know how to fit the crib on to the frame as i think that there is something missing....
There is a plastic adapter part that is supposed to come with the bassinet. There's one for each side where the Bassinet attaches. It's the same part that's also used to attach the car seat. I suggest seeing if you can purchase just that adapter on the Quinny website.
Apr 24, 2009 | Quinny Buzz Three Wheel Stroller
Opening the Quinny Buzz
It sounds like your gas is running low. if you registered with Quinny when you bought it they will fill this up for you free of charge, best to contact them on their website.
Feb 04, 2009 | Quinny Buzz Jogger
Good Luck!
Jan 22, 2009 | Quinny Zapp - Olive Green Umbrella...
Baby Gear Logo
115 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
