Question about Whirlpool Dryers
Whirlpool dryer model number lgr7648kq1 won't get
Whirlpool dryer model number lgr7648kq1 won't get hot
  • Anonymous Mar 15, 2014
    manual for whirlpool dryer model number wed8300sw0
    President:
  • 512 Answers
Sounds like one of the cavity switches is bad. Open back of dryer, you will see wires that attach to little clip next to each other. Try jumping wire from one side to the other, do one switch at a time and try dryer to see if heats, if you get heat replace that switch. These switches burn out if dryer gets to hot, usually from to much lint in duct work. Also vacuum out duct work in wall and on back of dryer.
Posted on Jun 14, 2009
Whirlpool dryer model wed5600sq0 won't cool down
If it does not shut off during the cool down part of the cycle then the issue is with the electronics
Mar 10, 2012 | Whirlpool Dryers
Dryer timer won't shut off at end of cycle. Dryer runs, but no heat. It is a Whirlpool model number LGR4634JQ2.
Since you say that the dryer runs but have no heat, plus the timer won't shut off the odds are the timer is bad. The timer would tell the burner when to be on and when to shut down.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=265840&diagram_id=28265980#d28265980
21 partimage.aspx?imgid=z3bqljbfahrfndg1njc5my9mufcvc290b2hwdhjhcc8%3d
Enlarge Photo
Timer
Part Number: AP3037407 made by WHIRLPOOL $91.55 In Stock
Order now and it will ship Today
Jun 09, 2011 | Dryers
Whirlpool Duet Dryer: In any program the Dryer is not producing any hot air.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 12, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer spins but does not dry brand is whirlpool model #LE7680XSW2 can you tell by model number what the capacity is. Thank you
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 11, 2010 | Whirlpool LER4634J Electric Dryer
I would like to obtain the user manual is it
Sure. Just click on the below link to access your user manual. Be sure to print it out for safe keeping, and storage.
CLICK HERE
Jan 06, 2010 | Whirlpool Dryers
Whirlpool dryer wont get hot
heatman101
Oct 19, 2009 | Whirlpool GGQ8831L Gas Dryer
Old avocado green Whirlpool Dryer, door switch?
dryer gets hot 4 awhile then gets cold
Aug 16, 2009 | Whirlpool Dryers
I have a Whirlpool gas dryer model #LGR7648KQ1. When I first start it it heats but after a short time it stops heating. It sounds like it is trying to start again but it will not.
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working.
You need a flame sensor
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 03, 2009 | Dryers
My whirlpool dryer model number LER4634JQ1 is not getting hot
You need a 30 amp breaker in my neck of the woods. South Alabama, US
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 28, 2009 | Dryers
LGR7648KQ1 model, dosen't seemd to have in lint in
The thumping noise is a stress crack from poor construction when thr drum was made. I have the exact same problem and found the crack when I removed the top cover by removing the rear upper brace support screws and bracket, then sliding the top dryer panel towards the rear about 3.5" and then lifting it off for complete drum inspection. Rotate the drum by hand and you will see the crack...Mine is at the front, next to the drum seam.... We should all get together and file a class action suit...I'm sure this is a manufacturer fault related problem with this model..
The crack is probably allowing air to bypass the normal air flow through the filter too... Richard
Jun 27, 2009 | Whirlpool Dryers
Dryers Logo
244 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
