Question about Tunturi T20 Folding Programmable Treadmill
Oil on my running belt
Oil has got on my running belt
What would cause the oil to leak after getting warmed up?
when engine get warm oil get thinner so it can leak from a small hole
belt will make noise on dry pulley change belt
Jul 23, 2014 | 2000 Buick LeSabre
Timing belt
why do you think its off, , eyes on marks? or strobe light or? what?
old oil turns black , on purpose. so it dont fill the engine full of gunk.
dont run oil for 5k miles. 3k on high mileage engines. max.
the belt can fail because >
1: over 60kmiles?
2: not a gate belt but in fact a fleabay-china $5 belt.
3: cam cog bent.
4: someone set the tension wrong, (top cause , RTM)
5:oil leaks to belt , belt dies early death.
6: running no cover, or cover is cut to ribbons, letting sand and gravel kill the belt in short order
7: spraying belt with belt dressing, bad to the bone that.
8:: im sure there are are other ways to kill it early, but i give up.
9: oops one more , the last joker, failed to put the head to block guide pins back, now the 2 cogs are misaligned, and belt dies. early.
seem all ways, ask me...
what engine, there are many used, over the world on RAV4.
my guess
2.0 L 3S-FE I4 (petrol)
2.0 L 3S-GE I4 (petrol)
Jan 19, 2014 | 1999 Toyota RAV4
Oil gettin on my belts n squicky n the guy told me that i need a new oil pan gasket...would that make it squick
the belts are glazed rub a bar of soap on the belt and run it see if it stops this sometimes removes the glazing i wouldent think the oil pan gasket would throw oil on the belts though its on the bottom of the motor check to see if valve cover gaskets are leaking they are on top
Aug 23, 2011 | 1998 Chevrolet Lumina
HOW DO YOU REMOVE A POWER STEERING MOTOR AND REPLACE IT WITH A NEW ONE FOR A 2006 MALIBU?
its a pump not a motor, you need to remove the drive belt from the pump, unbolt the pump from its mounting position, drain the oil out, remove the hydraulic oil line from the pump and remove the oil line.
bolt new pump on, connect oil line and drive belt, tension the drive belt, fill with oil to the right level, turn steering lock to lock with engine running to remove all air from the system and recheck oil level
Jun 10, 2010 | 2006 Chevrolet Malibu
Kenmore sewing machine mod 1703 motor runs but
By 'The wheel the belt is on' you mean the motor pully? If that is so obviously some oil has some how made way on the pully and the belt. Try to remove the belt and clean both wheels and the belt free of oil. This shd slove the problem.
If it doest then please send a photo of the arrangement showing pully and belt. U didnt mention if the machine is old or new. Did u oil it recently before trouble developed?
Oct 17, 2009 | Kenmore Sewing Machines
Broken bottom alternator belt
Check those pulleys that the Alternator belt runs on and make sure that they are ok. Make sure that oil is NOT getting on this belt (form oil leaks ) that's one of the most common reasons for belts to break that often. Good Luck
Dec 29, 2008 | 1992 Eagle Talon
Tunturi T20 Folding Programmable Treadmill Logo
16 people viewed this question
Top Tunturi Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
