Question about A4tech Computers & Internet
Zig x7 wiring diagram
I am looking for the wiring order on the main board of the mouse. the wires are - red ,copper,red-copper, blue,green; but I do not know which wire should go where since my cable was torn off :(
  • Micha Lewandowski
    Micha Lewandowski Mar 20, 2014
    the mouse model is a4tech x7 x-750 BF
bigg t
  • 640 Answers
SOURCE: 2 many ceiling wires
ok lori connect the fan wires like this-----white from fan to both white wires---blue from fan to red---black from fan to both black wires then copper wires to a ground.let me know.
Posted on Jan 17, 2008
  • 45 Answers
SOURCE: optical mouse wiring
should be a black wire and it goes to the casing of the port that mouse plugs in
Posted on Jul 27, 2008
frcs68
  • 1605 Answers
SOURCE: Targus RF PAUM005 Mouse Not Working
do you have the CD that came with the hardware???
seems like the PC can't communicate with the hardware. although it see something out there, but it doesn't recognize what it is.
even the machine is says this device is working porperly, you still need to install the driver, and the configuration for the device. that's why the receiver doesn't flash.
try to install the drivers and the configuration application.
Posted on Oct 23, 2008
SOURCE: Logitech s510 keyboard
I had this problem for a very long time as well. Turns out this is an encryption issue. It's off-balance. You need to reset the encryption, and here's how:
On the LEFT side of your wireless keyboard press and hold Ctrl+Alt, and press F12, then release all three buttons. Now push the Connect button on your Wireless Receiver, then the connect button on your wireless keyboard. Now press Esc. Try it. See if it works. It did for me.
Posted on Oct 30, 2008
  • 8 Answers
SOURCE: Centrios X7 gaming mouse
It should work on Vista 32-bit. It says explicitly in the manual that it WILL NOT work with 64-bit Vista. I think you're out of luck, dude.
Posted on Jan 05, 2009
2000 KIA SPORTAGE STEREO WIRING DIAGRAM
You can use the attached diagram for assistance, but here goes:
1. Blue/Yellow (Pin 1) - Illumination (+12V) (when headlights on)
2. Black/Yellow (Pin 1) - Main Power (+12V)
3. Light Green/Black (Pin 2) - Memory Power (+12v)
4. Black (Pin 11) - Ground
5. Blue/Red (Pin 9) - Left Front Spkr Return (-)
6. Green (Pin 19) - Left Front Spkr Signal (+)
7. Brown (Pin 10) - Right Front Spkr Return (-)
8. Light Green/Yellow (Pin 20) - Right Front Spkr Signal (+)
9. Blue/Orange (Pin 7) - Left Rear Spkr Return (-)
10. Green/Yellow (Pin 17) - Left Rear Spkr Signal (+)
11. Green/Red (Pin 8) - Right Rear Spkr Return (-)
(Note here that the wire color at the rear speaker is
Green/Blue - not sure if this is a misprint (see diagram))
12. Yellow (Pin 18) - Right Rear Spkr Signal (+)
Nov 10, 2013 | Vehicle Parts & Accessories
Hampton Bay fan wiring
this is everything u need to no
'http://www.ceiling-fans-n-more.com/ceiling-fan-wiring.php
it has all the colors and a diagram for you
Sep 29, 2008 | Hampton Bay 52 In. Brushed Nickel Romano...
Radio wiring diagram
hope this helps
Radio Battery Constant 12v+ Wire: Green/Yellow
Radio Accessory Switched 12v+ Wire: Yellow/Black
Radio Ground Wire: Black/Light Green
Radio Illumination Wire: Blue/Red
Stereo Antenna Trigger Wire: Orange/Blue
Left Front Speaker Positive Wire (+): Orange/Green
Left Front Speaker Negative Wire (-): Black/White
Right Front Speaker Positive Wire (+): White/Green
Right Front Speaker Negative Wire (-): Black/White
Left Rear Speaker Positive Wire (+): Pink/Green
Left Rear Speaker Negative Wire (-): Pink/Blue
Right Rear Speaker Positive Wire (+): Pink/Blue
Right Rear Speaker Negative Wire (-): Green/Orange
Jun 01, 2013 | 1993 Ford Thunderbird
Logitech headset usb wiring diagram?
Is this what you are looking for?
Jul 10, 2012 | Logitech USB HEADSET H390
Just need a diagram showing how to install the
If you need step by step instructions to wire something, you shouldn't really attempt to install a security system, as it will tie into almost every important electrical system in the car i.e. starter, door locks, lights, etc.
However, if you know how to get the lower portion of the drivers side dashboard off, and how to cut/splice a wire correctly and aren't color blind, you should be able to follow the installation instructions that came with the system. The wiring diagram for your car is:
What/ Color/ Where:
Constant 12V+ White Ignition Switch Harness
Starter Black/White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Accessory Yellow Ignition Switch Harness
Tach Blue Distributor
Brake Switch Green/White Brake Switch
Trunk Pin Green/Black (-) Above Fuse Panel
Parking Lights Red/Black Above Fuse Panel
Head Lamp Red/White Steering Column
Door Trigger Green/Red (-) Driver's Running Board (One of Two Wires)
Door Lock Green/White (-) In Driver's Door at Door Lock Module or at Anti-Theft Module under Driver's Seat
Door Unlock Green/Red (-) Driver's Running Board
Horn Wire Blue/Red (-) Steering Column, use Relay
Windows Up LF=Red/Blue, RF=Blue/Yellow
Windows Down LF=Red/Yellow, RF=Blue/Green
Jan 13, 2010 | XX-67A II LED/Valet Switch Pod
Cooktop - maytag cse9000 - wiring
white goes to neutral, bare copper to ground, red and yellow to one phase ( red L1 wire) and the black and blue to the other phase ( black L2 wire)
Dec 20, 2009 | Maytag 30 in. CSE9000 Electric Cooktop
Aftermarket radio does not work
The wires in the radio are more likely:
RED : Main Battery Power
YELLOW : From Ignition Switch
BLACK; Ground
BLUE: Output for Accesory (Antenna o Amp)
Car;
Blue/Red: Main Battery Power
Pink/Black : From Ignition Switch
Yellow/Gray: Illumitation(Don't use)
Green/Black: Same
I may be able to email you a copy of the diagram (just to be safe...)
Sep 13, 2009 | Car Audio & Video
Wiring diagram s3755 hoover
Today I shortened my hose by 4" to get around a tear problem. You can use an Ohm meter to find the right 4 wires. When looking from the top of the canister with the hose heading to your left, the wires should be:
White (furthest connector away from you)
Black - to the switch
Red
Blue
With the Red and Blue going to the speed con trol curcuit board.
Aug 05, 2009 | Hoover S3755 WindTunnel Bagless Canister...
LOOKING FOR WIRING DIAGRAM FOR STOCK HEADUNIT
Radio Constant 12V+ Wire: White/Green
Radio Switched 12V+ Wire: Yellow/Red
Radio Illumination Wire: Red/Black
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: Yellow/Green
Left Front Speaker Wire (+): Green/Black
Left Front Speaker Wire (-): Light Green
Right Front Speaker Wire (+): Green/Yellow
Right Front Speaker Wire (-): Gray/Red
Left Rear Speaker Wire (+): Blue/White
Left Rear Speaker Wire (-): Blue/Black
Right Rear Speaker Wire (+): Pink
Right Rear Speaker Wire (-): Blue/Yellow
pls rate
Apr 04, 2009 | 2003 Honda Accord
Need wiring diagrams for headset
I have the circuitry guide for the DSP box. I'm going to consider the top of the board the part with five connections, and the bottom is the part with eight connections.
From left to right on the top, the insulation colors are: red, white, green, black, no insulation.
From the left to right on the bottom, the insulation colors are: white, copper, copper/green, blue/green, red/green, red, copper/blue, green.
May 24, 2007 | Plantronics GameCom Pro 1 Headset
Computers & Internet Logo
65 people viewed this question
Top A4tech Computers & Internet Experts
micky dee
Tony
Are you an A4tech Computer and Internet Expert? Answer questions, earn points and help others
