Question about Xerox Office Equipment & Supplies
Xerox workcentre 6505 reset drum
Reset imaging drum procedure
    Novelist:
  • Xerox Expert
  • 297 Answers
You will need to replace the chip on the drum unit with one like this that is available for purchase.
2pcs Drum Reset Chip Imaging Drum Unit for use in Xerox Phaser 6500...
Posted on Jul 06, 2014
  • 2072 Answers
SOURCE: reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
Posted on Apr 03, 2008
SOURCE: Is there a Mac workaround driver for the Xerox WorkCentre PE16
Recently I had to configure a 17" Aluminum PowerBook and a Xerox Workcentre PE 16. That multifunction laser monochrome printer is not supported by MacOS X, but I tried all the same.... and no glue for that, until I went on the Samsung webpage and noticed their SCX-4216F printer. This machine is the same as the PE 16.
So I downloaded the lastest drivers from Samsung's download centre (drivers for Tiger too), installed the drivers on the PowerBook (running 10.3.4), connected the printer and when I selected the printer ... tada! It automatically selected the Samsung driver, so I clicked on OK and started printing. Everything was OK!
But it doesn't end here: even the Lexmark X215 MPF has the same chassis as the Xerox and Samsung. Yet, on Lexmark's website there are no Mac OS X drivers, but Samsung's drivers work just the same. I hope this hint will help others...
Posted on Jan 26, 2009
  • 110 Answers
SOURCE: Xerox Imaging Drum reset ? for Xerox Phaser 2135
The only way to reset the image unit drum is installing a new one. The new image unit has a fuse which once blown it resets the counter on the machine. You can call www.iteminconline.com I have their information in my ad place. They are good techs. I once called for a 7300 image unit reset and they said it was almost the same as a 2135 and they gave me this information. well goodluck.
Posted on Jul 24, 2009
  • 17 Answers
SOURCE: Need printer driver for Windows Vista 64 bits for Xerox WorkCentr
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=GLOBALPRINTDRIVER&ripId=&Xtype=download
You can try this driver. It may be quirky at first but it should work for basic printing needs. There is a PCL6 and post script try both sometimes it will take one but not the other. Its vista flip a coin :) -Phil
Posted on Apr 03, 2010
SOURCE: how to install Xerox WorkCentre PE16 scaner? i ...
How to install Xerox workcentre PE16 scaner?i install twin & driver but not work . Please help...
Posted on Jun 20, 2010
Xerox 6505 Scanner Sensor Error 062-360
Check out the Xerox.com website.
Good luck..
Oct 03, 2014 | Xerox Office Equipment & Supplies
How to reset xerox m118 drum
Hi, I have a solution to your problem click on the link below which will direct you to a step-by-step guide to fix your problem!
Xerox Workcentre 123 128 Reset Drum Life Free
Aug 26, 2014 | Xerox WorkCentre M118 Black and White...
Xerox black developer fade printing
Try this: http://www.fortwayneprinterrepair.com/wordpress/2014/03/17/xerox-phaser-6500-workcentre-6505-light-print-issues
Apr 25, 2014 | Xerox 6500/N Phaser Laser Printer
Scan documents on the 6505/DN using my pc or mac, what do I need from xerox
copier/scanner should do the trick and the new product will contain all the equipment.
Oct 17, 2013 | XEROX - COLOR PRINTERS 6505DN 6505/DN...
We have a Xerox Workcentre Pro575; it has an error that says drum life warning; we replaced the drum with another drum that we know works, but the error stays on. What else can this error mean
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode.
Nov 04, 2009 | Xerox Office Equipment & Supplies
I have a Xerox XD125F Workcentre. The J2 toner
1. turn off XD125f
2. Turn on
3. within 4 seconds press, clear, auto, clear, auto. LED Should go blank,
if not try again
4. use copy quantity keys to enter 24, then push start
5. Again use copy quantity keys to enter 7, then push start
6. turn off
when you restart the cartridge count will be set to zero
I have done this twice and never replaced the drum cartridge.
Jul 24, 2009 | Xerox Office Equipment & Supplies
WorkCentre 555 Fax Drum
This will reset it for you. strange !!!!!
    1. Yes
    2. No
Mar 14, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
447 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
