Question about Whirlwind FH-778 Air Conditioner
Power outage/AC not cooling
Power was out for 3 days from storm; fan is now blowing, but no cooling. I've checked breaker inside and at condenser; thermostat appears to be working. what else should I check?
  • 116 Answers
Ok if you have split system if indoor fan runs then transformer is working you have 2 breakers 1 for indoor and 1 for out door also disconnect at unit may have fuse in it if all seem ok remove side cover and look at capacitor if sweeled up bad take an insulated object and push in contactor if runs check for 24v from common to yellow stat wires also look for reset button next to freon lines hope this helps
Posted on Jun 14, 2009
Unit has no power, we had a power outage, power coming to unit is good.
Break A Breaker No Power To Air Conditioner Tripped AC ...
? 5:08
https://www.youtube.com/watch?v=nS2pBg2QbnM
Jun 2, 2013 - Uploaded by KungFuMaintenance
Break A Breaker No Power To Air Conditioner Tripped AC Can I Get A ... I have a GE model # AEM14aQL1 air conditioner wallunit 14,200 BTU ...
HVAC HELP! Unit has no power and Fan, Heat and AC are all ...
www.city-data.com > City-Data Forum > General Forums > House
Jul 1, 2012 - 10 posts - ‎8 authors
Now, when I attempt to turn on the AC I get no response from the unit. Nothing is blowing out of vents, even when fan mode is set to on. So far I ...
No power to outside AC unit - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 5, 2005 - I have an outside AC unit that appears to not get power. The circuit breaker is OK, and the fuse "appears" to be fine, but do not know if there is ... A/C problem, thermostat has no power
Aug 5, 2009
central a/c unit has no power
Sep 29, 2004
More results from www.doityourself.com
Dec 29, 2015 | Heating & Cooling
AC trips circuit breaker not long after a recent power outage.
Sounds like your compressor is shorted to ground. If you are able, unhook compressor, wrap wires and restart. If breaker doesn't trip than u know.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 07, 2017 | DeLonghi Heating & Cooling
Our Ruud ac won't come on after a storm and power outage? I have flipped the breaker with no luck. Any suggestions?
there is a fuse on the circuit board on the inside unit. Typically a power surge will pop it. checking that fuse is the best place to start
Sep 29, 2012 | Ruud Heating & Cooling
Power went out for 3 seconds electric storm warnings but did not see/hear any lightning strikes. Central air-conditioning fans spins But the compressor doesn't turn on. There is one condenser and looks...
During these storms power gets shut down fora sec and comes back with a tsunami type surge. why? Because the generators are going full blast at the electrical plant in your area. No load is applied anf they sky rocket into Zapland babes! Any slight glitch or momentary outage causes a surge. It goes away but it comes back with a fury. So if your AC's run cap is a little old and tired from workin that condenser like it ain't not thang, Then the resulting surge will zap that puppy and it will look like this:
themobilian_2930.jpgRemove the power from the outside unit and look at that capacitor. It prob has went under. If it is leaky or preggers, it is bad. Replace it and party on! More here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 28, 2011 | Heating & Cooling
Emerson tv lost the ability to power on after a storm
I would probably look at the internal fuse that protects the power supply inside the tv. The storm probably sent a power surge through your outlet, your breaker may not always work correctly, especially if the breaker is old. The fuse should be inline with the hot side of the AC power to the power supply circuit. You would have to open up the tv, but you would be able to spot the fuse very easily. Fuses are cheap, but getting to it may be a problem
Aug 20, 2009 | Emerson Televison & Video
AC unit runs inside but not outside! help
check breaker thermostat set cooling auto call for service.allso get it cleaned both coils.. Tom
Jun 19, 2009 | Ruud UAKA042 Air Conditioner
AC Fan doesn't blow cold air, frozen coil noticed outside, resetting power resolves temporarily
You need to call a reputable service technician.  The freezing up usually is associated with a low refrigerant charge or low air flow.  Check your return air filter and replace as needed.
May 30, 2009 | Heating & Cooling
My LG LRBN20514ST Fridge is not cooling
where to look for the defrost timer on the LG top freezer modle
GR-S392GCA
Aug 26, 2007 | LG LRBN20510WW Bottom Freezer Refrigerator
Heating & Cooling Logo
175 people viewed this question
Top Whirlwind Heating & Cooling Experts
AJMAL KHAN
Dennis Boxerman
Bill Long
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
